18f26k22 - setting fuse in program
Results 1 to 8 of 8
    Oct 2011
    Default 18f26k22 - setting fuse in program
    I'm working to a project with 18f26k22 using PBP3.0.
    I need internal osc 64mhz , analogic input 1-2-3-4-5-10-12, 3 output c3-c2-c1, 4 digital iput c7-c6-c5-c4.
    I'm not able to configure pic, can anyone help me?
    (Better in program than in .inc file)
    Many Thanks
    Default Re: 18f26k22 - setting fuse in program
    In your PBP 3.0 directory open the directory "DEVICE_REFERENCE" and find the PIC18F26K22.INFO file, open with notepad.
    Here you will find an example for setting the configs.
        CONFIG  OSC = HS
        CONFIG  WDTE = ON
    Then you will see a list of all the possible config options.
    Oct 2011
    [QUOTE=mackrackit;108426]In your PBP 3.0 directory open the directory "DEVICE_REFERENCE" and find the PIC18F26K22.INFO file, open with notepad.
    Many Thanks mackrackit, First problem solved
    Now 2° Problem input/output/adc settings
    My code :
    TRISA = %00101111 ' Set PORTA to all input
    TRISB = %00000011 ' Set PORTB to all input + 6 output
    TRISC = %11110000 ' Set PORTC to all input + 4 output
    ANSELA= %11101111
    ANSELB= %00000011
    ADCON1 = %10001000
    ADCON2 = %10000000 ' ...and right justify result
    ADCON0 = %10001001
    It seems ok, But..
    ADCIN report always 0..
    Any Idea?
    Aug 2010
    Maryland, USA
    Maybe if we could see your entire code, or if this is all of it, you only have the settings set up.
    -Bert
    Steve, You forgot the PMD2: PERIPHERAL MODULE DISABLE REGISTER 2. It enables or disables the A/D module for the 18F26k22.
    The new 18 F series use these new registers to enable and disable most all of the module functions. It's in the data sheet.....
    EN82fn
    Steve, also read this...
    17.2.10 A/D CONVERSION PROCEDURE
    This is an example procedure for using the ADC toperform an Analog-to-Digital conversion:1. Configure Port:• Disable pin output driver (See TRIS register)• Configure pin as analog2. Configure the ADC module:• Select ADC conversion clock• Configure voltage reference• Select ADC input channel• Select result format• Select acquisition delay• Turn on ADC module3. Configure ADC interrupt (optional):• Clear ADC interrupt flag• Enable ADC interrupt• Enable peripheral interrupt• Enable global interrupt
    (1)
    4. Wait the required acquisition time
    (2).5. Start conversion by setting the GO/DONE bit.6. Wait for ADC conversion to complete by one ofthe following:• Polling the GO/DONE bit• Waiting for the ADC interrupt (interruptsenabled)7. Read ADC Result8. Clear the ADC interrupt flag (required if interruptis enabled).
    EN82fn
