Using the Arduino Eth shie wi AMIS18 (new thread so not so long scroll to end)
Results 1 to 5 of 5
    Default Re: Using the Arduino Eth shie wi AMIS18 (new thread so not so long scroll to end)
    Exactly, the W5100. My code targets the W5100 specifically though I think that it, with some minor changes, will work with the new W5200....
    I took for granted you were using a module containing the W5100, like the Wiz810, 811 or 812. If you're using one of their more intelligent modules my code is of little use to you.
    However, mechanisms and routines to store HTML in the PIC and "pushing it" to the chip/module (be it via USART or MSSP module) can likely be done in the same way for both types - and any other ethernet module, like the X-port for example.
    DHCP for setting PIC Server inside some LAN. You may already be clear this.
    To access PIC Server from outside of its LAN, it needs to be on a specific PORT and set the Router to pass packets destined for PIC from the internet based on that PORT number. On my router, I had to enter a static PIC address and specific PORT that allows packets to pass through. That doesn't change so from outside, IP and PORT # access to PIC stays the same. I'm not sure if some routers can add that routing based on the HOST NAME,instead of IP, that you may set in the 5100.
    IPV6 will change this but thats still evolving as more devices handle the addressing protocols. I think.
    The HTML pages parts stored locally would be because the PIC Server can only handle so much HTML, so that could make pages more functional and appealing while still getting timely data from PIC.
    Don
