Thank you for fast reply!
It's impossible to get to second read line because is no stop bit at first.
Code works but doesn't stop.
Example:
if i'm reding from adress "X" and i want to read 1 field , because lack of stop bit reading continues until bit 5 from "X+6" address and no chance for second read line to work correct(pause between is irrelevant).
All values that was read in the faulty process are correct.
