A % will sometimes be stripped and upper case is turned to lower case. When I code in PBP I have caps lock on so it is not a MCS thing.Code:ANSEL=%00000000 ' ADC SET FOR DIGITAL CMCON=7 ' COMPARATOR SET FOR DIGITAL SWITCH_OFF VAR GPIO.1 ' PUSH BUTTON FOR PUMP OFF SWITCH_RUN VAR GPIO.2 ' PUSH BUTTON FOR PUMP ON LED_RUN VAR GPIO.0 ' INDICATE RUN SIGNAL SENT LED_OFF VAR GPIO.5 ' INDICAT STOP SIGNAL SENT TX VAR GPIO.4 ' DATA SEND PIN BAUD CON 18030 ' 18030 = 600 BAUD
EDIT--- in preview the format was all wrong but the post is not so bad??
