Problem with servos
Results 1 to 7 of 7
Threaded View
  1. #2
    Oct 2009
    Utah, USA
    Default Re: Problem with servos
    when you say it "instantly started"... what do you mean? Did it just twitch? or did it change position?
    typically... in order to control a servo you need to supply +5 volts to the red wire, gnd the black wire and supply a PWM (pulse width modulated) signal to the white wire. The pulse must be repeated approx every 20ms (see the article below). So you must use a timing loop, or an interrupt based on a timer, or some other method of making sure you are repeating the pulse at the proper rate. Is your servo Digital or Analog?
    Here is a description of how servos work (both digital and analog servos)
    http://www.acroname.com/robotics/inf...rvo/servo.html
    Dwight
