Problem with servos
Results 1 to 7 of 7
    Sep 2011
    Post Problem with servos
    Can anyone help me...
    my problem is that, i have this tower pro 9g servo and as I connect it to the circuit which I made, It instantly started without putting the PIC microcontroller to its socket. I've already checked the circuit connections and there were no shorted... So, i really don't have an idea now...
    Lots of thanks to those who will give help..
    Oct 2009
    Utah, USA
    Default Re: Problem with servos
    when you say it "instantly started"... what do you mean? Did it just twitch? or did it change position?
    typically... in order to control a servo you need to supply +5 volts to the red wire, gnd the black wire and supply a PWM (pulse width modulated) signal to the white wire. The pulse must be repeated approx every 20ms (see the article below). So you must use a timing loop, or an interrupt based on a timer, or some other method of making sure you are repeating the pulse at the proper rate. Is your servo Digital or Analog?
    Here is a description of how servos work (both digital and analog servos)
    http://www.acroname.com/robotics/inf...rvo/servo.html
    Dwight
    Aug 2010
    Maryland, USA
    It is pretty normal for R/C type servos to move as soon as they have power. Usually they just move to the smallest position.
    -Bert
    Sep 2011
    Yes, it supposedly work that way, but it moves continuously... Maybe it's calibration has its problem. Thank you for the reply.
    I'd suggest you check the wiring again; the color code can be confusing, I've had a servo with brown, red and orange wires! And for certain combination of incorrect wiring, the rotor does stutter.
    Anand
    Sep 2011
    Thanks for the response
    Sep 2011
    it is digital... I haven't placed the microcontroller yet, still it moves.. Maybe its calibration has its problem.. Thanks for the reply.
