Serial comunication problem
Results 1 to 23 of 23
    Sep 2011
    Default Re: Serial comunication problem
    Firs one thanks to all for fast answer.
    Yes I have checked all things posted and a lot of times.
    But nothing work.
    Maybe is a problem with a Breadboard thet collect noise ?
    I know it hard to say what check, but all seem fine and at
    same time nothing work!
    I am very confused because I have made a lot o circuit
    with PIC in assembler and basic, with motor, with display,
    with PWN dimmed ligght, and ever have worked fine,
    but now with a silly serial debugging purpose nothing
    work.
    I am very frustated!
    Post you code and configs along with a schematic.
    Everyone is guessing as is.
    Sep 2011
    Hello,
    Thank for reply and sorry for the late to answer but I was away for job.
    I don't have much to to make experiment but I have try to change the
    cable and the main circuit.
    All is same I will get back the same garbage but...
    Now i try to send the word "Hello" and now I get back on screen PC the
    exact number of chars but with non ascii format like '¨µ¼´¿".
    Yesterday I don't know how, maybe some change to prog or same hack
    on circuit, for a short time I have get back the correct string on screen!
    "hello"hello"hello"...
    After that I have made some change and now all is come back in the
    same garbage!
    In anyway this is the source:
    ANSEL=0
    CMCON=7
    TRISA = %11110000 ' Set PORTA to all input
    TRISC = %00000000 ' Set PORTA to all input
    Include "modedefs.bas"
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 1
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_PACING 1000
    Clear
    Pause 1000
    Cont var Byte
    Cont = 0
    Mainloop
    PAUSE 1000
    Cont = Cont + 1
    Debug "Hello"
    PORTC.2 = 1
    PAUSE 1000
    PORTC.2 = 0
    goto Mainloop
    And this the circuit:
    Aug 2010
    Maryland, USA
    I see you have a LED set to blink on for 1 sec, then off for 1 sec. Is the LED blinking and at the correct speed?
    -Bert
    Sep 2011
    Hi Bert,
    I have fogot to say, it is only a luminose control to see if all work well(I don't have put it on the scheme).
    And yes it seem blink 1 sec and 1 sec no. It's hard to say just lookin at it
    but the time seem correct yes.
    Aug 2010
    Maryland, USA
    Well that would seem to rule out any OSC issues. The Pic is running and running at 4Mhz as you have programmed for. At this point, I think I would just have it run and start touching stuff. Maybe there is a breadboard problem or something like that. If it worked yesterday, even just for a few times, it seems like the code is good. So the only thing left is hardware.
    Wiggle the caps while watching the PC to see if "hello" magically appears. also all the wires. Do this 1 at a time to try and isolate the problem.
    Maybe even try a different output pin, Or move the parts around on the BB. I have had BB's fail on a pin here and there from the socket not making good contact.
    -Bert
    Sep 2011
    Yes I think the problem is there, but maybe in the code or maybe I dont' sent
    some registry of 16f676 IC.
    I say this because I have change the PIC circuit in a 1000hole board and I get
    the same garbage.
    I think to have change something in the code about OSC define or something
    aroud and the serial work.
    I anyway I can wrong, but the only thing ever same is the MAX232 circuit,
    but there is only some condensator so I can see any thing wrong.
    Maybe some one have made the same circuit with PIC 16f676 and Max232
    and he can check if the code, expeccialy the Oscillator define, is correct ?
