Serial comunication problem
Results 1 to 23 of 23
    Sep 2005
    Campbell, CA
    Default Re: Serial comunication problem
    Also, make certain that Hyperterm is set for Flow Control = None
    Charles Linquist
    Are you adding the '#' before the variable?
    And if you are using the built-in oscillator on the 16F676, are you sure your OSCCAL value is correct?
    Anand
    Sep 2011
    Firs one thanks to all for fast answer.
    Yes I have checked all things posted and a lot of times.
    But nothing work.
    Maybe is a problem with a Breadboard thet collect noise ?
    I know it hard to say what check, but all seem fine and at
    same time nothing work!
    I am very confused because I have made a lot o circuit
    with PIC in assembler and basic, with motor, with display,
    with PWN dimmed ligght, and ever have worked fine,
    but now with a silly serial debugging purpose nothing
    work.
    I am very frustated!
    Post you code and configs along with a schematic.
    Everyone is guessing as is.
    Sep 2011
    Hello,
    Thank for reply and sorry for the late to answer but I was away for job.
    I don't have much to to make experiment but I have try to change the
    cable and the main circuit.
    All is same I will get back the same garbage but...
    Now i try to send the word "Hello" and now I get back on screen PC the
    exact number of chars but with non ascii format like '¨µ¼´¿".
    Yesterday I don't know how, maybe some change to prog or same hack
    on circuit, for a short time I have get back the correct string on screen!
    "hello"hello"hello"...
    After that I have made some change and now all is come back in the
    same garbage!
    In anyway this is the source:
    ANSEL=0
    CMCON=7
    TRISA = %11110000 ' Set PORTA to all input
    TRISC = %00000000 ' Set PORTA to all input
    Include "modedefs.bas"
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 1
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_PACING 1000
    Clear
    Pause 1000
    Cont var Byte
    Cont = 0
    Mainloop
    PAUSE 1000
    Cont = Cont + 1
    Debug "Hello"
    PORTC.2 = 1
    PAUSE 1000
    PORTC.2 = 0
    goto Mainloop
    And this the circuit:
    Aug 2010
    Maryland, USA
    I see you have a LED set to blink on for 1 sec, then off for 1 sec. Is the LED blinking and at the correct speed?
    -Bert
    Sep 2011
    Hi Bert,
    I have fogot to say, it is only a luminose control to see if all work well(I don't have put it on the scheme).
    And yes it seem blink 1 sec and 1 sec no. It's hard to say just lookin at it
    but the time seem correct yes.
