Serial comunication problem
Results 1 to 23 of 23
    Dec 2010
    Default Re: Serial comunication problem
    Based on your description, the data is either inverted, or being sent at the wrong speed. Verify setting match in both your code and on the PC, (for example 9600,8,N,1) and then check your clock on the PIC is correct. The speeds specified in PBP are only valid with a certain clock (4 MHz off the top of my head). You should not need to set DTR, or DCD. Final thing to check is that the RS232 cable is connected properly. If you have not crossed TX to RX, sometimes noise with give screens of garbage.
    Sep 2005
    Campbell, CA
    Also, make certain that Hyperterm is set for Flow Control = None
    Charles Linquist
    Are you adding the '#' before the variable?
    And if you are using the built-in oscillator on the 16F676, are you sure your OSCCAL value is correct?
    Anand
    Sep 2011
    Firs one thanks to all for fast answer.
    Yes I have checked all things posted and a lot of times.
    But nothing work.
    Maybe is a problem with a Breadboard thet collect noise ?
    I know it hard to say what check, but all seem fine and at
    same time nothing work!
    I am very confused because I have made a lot o circuit
    with PIC in assembler and basic, with motor, with display,
    with PWN dimmed ligght, and ever have worked fine,
    but now with a silly serial debugging purpose nothing
    work.
    I am very frustated!
    Post you code and configs along with a schematic.
    Everyone is guessing as is.
    Sep 2011
    Hello,
    Thank for reply and sorry for the late to answer but I was away for job.
    I don't have much to to make experiment but I have try to change the
    cable and the main circuit.
    All is same I will get back the same garbage but...
    Now i try to send the word "Hello" and now I get back on screen PC the
    exact number of chars but with non ascii format like '¨µ¼´¿".
    Yesterday I don't know how, maybe some change to prog or same hack
    on circuit, for a short time I have get back the correct string on screen!
    "hello"hello"hello"...
    After that I have made some change and now all is come back in the
    same garbage!
    In anyway this is the source:
    ANSEL=0
    CMCON=7
    TRISA = %11110000 ' Set PORTA to all input
    TRISC = %00000000 ' Set PORTA to all input
    Include "modedefs.bas"
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 1
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_PACING 1000
    Clear
    Pause 1000
    Cont var Byte
    Cont = 0
    Mainloop
    PAUSE 1000
    Cont = Cont + 1
    Debug "Hello"
    PORTC.2 = 1
    PAUSE 1000
    PORTC.2 = 0
    goto Mainloop
    And this the circuit:
    Aug 2010
    Maryland, USA
    I see you have a LED set to blink on for 1 sec, then off for 1 sec. Is the LED blinking and at the correct speed?
    -Bert
