How to resolve assembler error 306?
Results 1 to 12 of 12
    Mar 2009
    Colorado
    Default Re: How to resolve assembler error 306?
    post your code,
    EDIT: open DT-INT file, usually you could need to comment out some lines...
    Here is my code, but not quite sure what lines in DT_INTS-14.bas I would need to comment out??
    '< FL_PIC16F886 >' ' First valid PIC found within the first 200 lines will
                        ' highlight AND set device.
    '< FL_PBPW >'       ' OR < FL_PBPL >
    '< FL_MPASM >'      ' OR  < FL_PM >
    '*  Name    : DS1337clockedTemp.pbp                                    *
    '*  Author  : John R. Ellis                                            *
    '*  Notice  : Copyright (c) 2010 LodeStar Associates, Inc.             *
    '*          : All Rights Reserved                                      *
    '*  Started : 07/26/2011                                               *
    '*  Version : 1.0                                                      *
    '*  Notes   : 1) This code was designed/devloped on an EasyPic6        *
    '*  Compiler: PICBASIC PRO Compiler 2.60C from microEngineering Labs   *
    '*  Device  : 16F886 w/ serial 2x16 or 2x8 LCD as installed on         *
    '*            ProtoBoard connected via Port Extension to an EasyPic6.  *
    '*  Memory  : 9,614 bytes of Program Memory required.                  *
    '*  Ref:    : 1) RTC portions of this code are adapted from code       *
    '*          : written by Tonigalea (see URL ref below), but modified   *
    '*          : to run on an EasyPic6 with 18F4550 MCU and a DS1337 RTC. *
    '*http://www.picbasic.co.uk/forum/showthread.php?t=662&highlight=DS1337*
    ' -----------------------[ Program Description ]------------------------
    ' PICBASIC PRO program to set RTC & demo operation of a LCD/4-bit mode *
    '  1) Initializes 2x16 or 2x8 LCD display (if installed) with EasyPic6.*
    '  2) Time/date/Alarm1 must have already been programmed into the      *
    '     DS1337 Real-time-clock before running this program.              *
    '     (IMPORTANT: user must use available SetTimeDate program to       *
    '      program DS1337 prior to programming this program into the MCU)  *
    '  3) Alarm1 from the DS1337 is used as RB2 interrupt on change by MCU.*
    '  4) Also displays date/time on LCD (if installed) every second.      *
    '  5) Measures temperature on every Alarm1 interrupt and displays it.  *
    '  6) If battery is so low to drop Vr<=3.39 vdc, LED_RED will blink 5x *
    '     as a low voltage warning monitor.                                *
    ' -----------------------[ Revision History ]---------------------------
    ' Version 1.0   Started on 07/19/11
    ' ------------[ NOTES for use with EasyPic6 development board ]---------
        ' Make sure that SW6.8 on the EasyPic6 is set to ON position before
        ' powerup for LCD's requiring backlight.
        'For use with 2x16 LCD (when installed):
    '     - Turn on Port Expander switches SW6.1,SW6.2,SW6.3,SW6.4 & SW6.5.
    '     - Turn on COG LCD 2x16 switches SW10.1, SW10.2, SW10.3, SW10.4,
    '       SW10.5 & SW10.6.
        'For interface to DS1337 RTC:
    '     - TO provide battery backup, place two Shottky diodes in 'or'
    '       configuration between the Vdd (pin-8) of the DS1337 and the Vcc
    '       source and the + terminal of the backup battery.
    '     - I2C communication lines should be connected to 4.7K pull-ups.
    '     - DS1337 INTA & INTB lines should be connected to pull-up resistsors.
    '     - Turn off LEDs connected to I2C communication lines.
    '-----------------[ 16F886 Port/PIN Connections ]------------------
    'I/O pin connections to the 18F4550 MCU are as follows:
    'PORTA.0 (02) output to LCD D4 & also multiplexed as input from LM34.
    'PORTA.1 (03) output to LCD D5.
    'PORTA.2 (04) output to LCD D6 & also mulitplexed as Vref+ input.
    'PORTA.3 (05) output to LCD D7.
    'PORTA.4 (06) output to LCD RS.
    'PORTA.5 (07) ouput to LCD E.
    'PORTB.0 (21) output as I2C SDA to DS1337.
    'PORTB.1 (22) output as I2C SCL to DS1337.
    'PORTB.2 (23) input as interrupt on change from pin-3 (_INTA) of DS1337 RTC.
                  ' Also senses pushbutton for manual interrupt for RangeFinder.
    'PORTB.3 (24) input from SQW/_INTB pin-7 of DS1337 RTC.
    'PORTB.4 (25) set as A/D Channel 11 for analog input from LM34 output
    'PORTB.5 (26) unconnected
    'PORTB.6 (27) connected as PGC for ICSP connection.
    'PORTB.7 (28) connected as PGD for ICSP connection.
    'PORTC.0 (11) output RC0 to control external power to SRF02 & LM34.
    'PORTC.1 (12) output RC1 to MSEL on WiFi Module
    'PORTC.2 (13) output RC2 to LCD R/W or to _RES_PD on WiFi module
    'PORTC.3 (14) reserved to connect as Vbus to 470 pf capacitor for USB
    'PORTC.4 (15) output RC4 to a Red LED for low voltage warning.
    'PORTC.5 (16) output RC5 to Green LED for routine entry indicator.
    'PORTC.6 (17) output as TX to WiFi module RXD.
    'PORTC.7 (18) output as RX to WiFi module TXD.
    '--------------[ Define EEPROM usage ]-----------------------------------
       '07  = mon      ' Month of program startup
       '08  = date     ' Day of month of program startup
       '09  = yr       ' Year of program startup
       '10  = J        ' Index for counting interrupts received
       '11  = hr       ' Hour time from RTC at MCU startup time
       '12  = MINs     ' Minutes time from RTC at MCU startup time
       '13  = sec      ' Seconds time from RTC at MUC startup time
       '14  = A1hr     ' Alarm1 hour time from RTC after setting RTC
       '15  = A1MINs   ' Alarm1 minutes time from RTC after setting RTC
       '16+J = hr      ' Log Hour of interrupt
       '17+J = MINs    ' Log Minutes of interrupt
       '18+J = sec     ' Log Seconds of interrupt
       '19+J = temp    ' Log temperature at time of intercept
       '236            ' Last legitimate EEPROM logging address
       '240 = ID(0)    ' LSB of device ID
       '241 = ID(1)    ' MSB of device ID
       '242 = mon      ' Month when clock was set
       '243 = date     ' Date when clock was set
       '244 = yr       ' Year when clock was set
    'INCLUDE "CodeSize.pbp"     'FOR TEST ONLY
    DEFINE Measure 1
    ;@ StartSize(LOOKUP)        'FOR TEST ONLY
    Pause 10     ' This statement is placed at beginning of code for ICD use
    @ ERRORLEVEL -306             ; turn off crossing page boundary message
    'Disable Debug                ' Uncomment for test only
    ' Set configuration fuses for the MCU
    ' To use standard config include file, comment out below statement
    @ __config   _CONFIG1, _HS_OSC & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    '--------------[ Define Hardware / Set Registers ]------------------------
        DEFINE OSC 16
        DEFINE I2C_SLOW 1   ' Set i2c to the standard speed
        DEFINE I2C_HOLD 1   ' Enable receiving i2c device to pause communication
        INCLUDE "Modedefs.Bas"    ' Mode definitions for Debug,Serin/out,
                                  ' Shiftin/out, Xin/out.
        INCLUDE "ALLDIGITAL.pbp"  ' Sets all registers for digital ops.
                                  ' User must make sure AllDigital.pbp file
                                  ' is in same or higher directory location as
                                  ' this source code before compiling.
            'DEFINE SHOWDIGITAL 1 ' When uncommented will show analog settings
                                  ' in Assembler Results window.
        INCLUDE "DT_INTS-14.bas"  ' Base Interrupt System
        INCLUDE "ReEnterPBP.bas"  ' Include if using PBP high priority interrupts
                                  ' Allows re-entry to PBP from a High Priority
                                  ' ASM interrupt. Must have DT_INTS-14.bas
                                  ' loaded first.
        TRISA = 0           ' Set all PortA initally to outputs for LCD use
        TRISB = %00011100   ' RB2 & RB3 set as RTC Alarm1 & Alarm2 inputs
                            ' PORTB.2 is also an interrupt from manual switch GND
                            ' PORTB.4 is set at A/D Channel 11
        TRISC = %10000000   ' Set PortC to all outputs except PortC.7 which is
                            ' reserved as RX input.
                            ' PortC.1 is output for MSEL to WiFi module
                            ' PortC.2 is used for the LCD R/W connection when
                            ' LCD present..otherwise as _RES_PD to Wifi Module.
                            ' PortC.4 is output to LED_RED
                            ' PortC.5 is output to LED_GRN
    CLEAR
    '--- Setup Interrupts ----------------------------------------------------
    INT_LIST  macro      ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler      RBC_INT,       _Alarm,   PBP,  yes
            INT_Handler      LVD_INT,     _VoltLow,   PBP,  yes
    'ENABLE DEBUG
    ' Per DT, DT_INTS already takes care of setting registers
    ' but this code doesn't work unles below registers set as indicated:
        IOCB = %00000100     ' Enable RB2 as Interrupt on Change pin for RTC Alarm
        WPUB = 0             ' Disable all PortB pull-ups
    '--- Variables & Aliases -------------------------------------------------
    CNT         VAR BYTE      ' Counter for timing
    CNT = 0
    D_LAY       VAR BYTE      ' Stores delay value
    ADR         VAR BYTE[9]   ' Array stores IP address
    deviceID1   VAR BYTE      ' Serial # of MCU (MSB)
    deviceID2   VAR BYTE      ' Serial # of MCU (LSB)
    ext_pwr     VAR PortC.0   ' MCU Controlled external power to SRF02 & LM34
    I           VAR Byte      ' Index for loop counters
    ID          VAR BYTE[8]   ' Array for storing device ID parameters
    J           VAR BYTE      ' Index to EEPROM address for logging
    LCD_Flag    VAR Bit       ' Flag when set indicates LCD is installed/used
    LED_RED     VAR PortC.4   ' Red LED
    LED_GRN     VAR PortC.5   ' Green LED used to indicate Routine entries
    logflag     VAR BYTE      ' Flag used in ISR to indicate to log time stamp
    LowVolt     VAR BIT       ' Flag that is set when MCU power source is low volt
    MSEL        VAR PORTC.1   ' iChip Mode Select
    _RES_PD     VAR PORTC.2   ' iCHIP RESET/Power-Down
    OK          VAR BYTE      ' Captures K in I/OK FTP return messages for testing
    SCL         VAR PORTB.1   ' I2C clock pin
    SDA         VAR PORTB.0   ' I2C data pin
    Spare_1     VAR PORTB.7   ' PGD for ICSP & Spare I/O for normal ops
    Spare_2     VAR PORTB.6   ' PGC for ICSP & Spare I/O for normal op
    temp        VAR WORD      ' Stores measured temperature
    TX          VAR PORTC.6   ' Serial interface to iWiFI module
    RX          VAR PORTC.7
    'ENABLE DEBUG
    '--- Initialize ----------------------------------------------------------
        ' User must set FLAGS for current configuration
            LowVolt = 0       ' Initalize low voltage Flag
            LCD_Flag = 0      ' Clear if LCD un-installed; set otherwise
        'CCPR1L = 0                 ' Not used in this app
        'CCPR2L = 0                 ' Not used in this app
        'CCP1CON =   %00001100      ' CCP1, PWM mode...not used in this app
        'CCP2CON =   %00001100      ' CCP2, PWM mode...not used in this app
        PR2     =   249             ' 0-1000 duty range
        T2CON   =   %00000101       ' TMR2 on, prescaler 1:4
    '--- Read MCU Serial Number is stored in 4 ea device ID Locations
    ' at memory locations Addresses $2000 to $2003 but can't be read at run time
        deviceID1 = ID(0)           ' MSB of MCU Device Serial Number
        deviceID2 = ID(1)           ' LSB of MCU Device Serial Number
        WRITE 240, ID(0)            ' Write fixed values to EEPROM for test
        WRITE 241, ID(1)
    '*******************SETUP FOR USING DS1337 Real Time Clock**************
        ' Setup Hardware for uart
            DEFINE HSER_BAUD 115200
            DEFINE HSER_RCSTA 90h
            DEFINE HSER_TXSTA 24h
            DEFINE HSER_CLROERR 1
        ' Aliased Variables for CLock
            Alarm1     VAR PORTB.2     ' Alarm1 input from DS1337 INTA (pin-3)
            'Alarm2     VAR PORTB.3     ' Alarm2 input from DS1337 INTB (pin-7)
            'SCL        VAR PORTB.1     ' I2C clock pin
            'SDA        VAR PORTB.0     ' I2C data pin
            RTCdevice CON $D0  ' Device write address = %11010000 for RTC
            ' This is a list of allowable clock contrl settings, one which
            ' must be setup in the SetTimeAndDate subroutine for intended use.
            '(see data sheet pgs 9-10 for explanation)
            'contrl   CON %00000000 ' Starts oscillar, sets the SQW/OUT to
                                    ' 1Hz pulse, no Alarm interrupts enabled.
                                    ' WORKS as intended!!
            'contrl   CON %00000001 ' Starts oscillator, sets the SQW/OUT to
                                    ' 1 HZ pulse, & enables INTA interrupt from
                                    ' A1F.  WORKS as intended!!
            'contrl   CON %00000010 ' Starts oscillator, sets the SQW/OUT to
                                    ' 1 HZ pulse, enables INTA interrupt from
                                    ' A2F. WORKS AS intended!!
            'contrl   CON %00000011 ' Starts the oscillator, sets the SQW/OUT
                                    ' to 1 Hz, enables INTA interrupt from A1F
                                    ' or from A2F.  WORKS as intended!!
            'contrl   CON %000xx100 ' Starts oscillator, no interrupts enabled.
            'contrl   CON %000xx101 ' Starts oscillator, enables INTA interrupt
                                    ' from A1F, INTB/SQW off. WORKS OK!
            'contrl   CON %000xx110 ' Starts oscillator, enables INTB interrupt
                                    ' from A2F. WORKS OK!
            'contrl   CON %000xx111 ' Starts oscillator, enables INTA interrupt
                                    ' from A1F or INTB from A2F. WORKS OK!
                                    ' Both interrupts staggered 30 secs apart.
            'contrl   CON %00011111 ' Starts oscillator, sets RS1 & RS2,
                                    ' enables INTA interrupt from A1F
                                    ' or A2F starts 32.768khz on SQW output.
                                    ' WORKS OK!
            'contrl   CON %00011001 ' Starts oscillator, sets RS1 & RS2,
                                    ' clears INTCN to enable INTA interrupt
                                    ' from A1F with 32.768kHz on SQW output.
                                    ' SQW output WORKS OK but INTA doesn't!
            'contrl   CON %00011010 ' Starts oscillator, sets RS1 & RS2,
                                    ' from A2F with 32.768kHz on SQW. WORKS OK!
        ' RTC Address definitions
            SecReg      CON $00   ' seconds address (00 - 59)
                                  ' Must set MSB of SecReg to a 0 to enable RTC
            MinReg      CON $01   ' minutes address (00 - 59)
            HrReg       CON $02   ' hours address (01 - 12) or (00 - 23)
            DayReg      CON $03   ' day address (1 - 7)
            DateReg     CON $04   ' date address (01 - 28/29, 30, 31)
            MonReg      CON $05   ' month address (01 - 12)
            YearReg     CON $06   ' year address (00 - 99)
        ' Alarm 1 Address definitions
            Alm1sec     CON $07  ' Alarm 1 seconds address (00 - 59)
            Alm1min     CON $08  ' Alarm 1 minutes address (00 - 59)
            Alm1hr      CON $09  ' Alarm 1 hours address (01 - 12) or (00 - 23)
            Alm1Day     CON $0A  ' Alarm 1 day address (1 - 7)
        ' Alarm 2 Address definitions..not used in this application
            'Alm2min     CON $0B  ' Alarm 2 minutes address (00 - 59)
            'Alm2hr      CON $0C  ' Alarm 2 hours address (01 - 12) or (00 - 23)
            'Alm2Day     CON $0D  ' Alarm 2 day address (1 - 7)
        ' Alias of Clock register addresses
           ContReg     CON $0E    ' CONTROL register address
           StatusReg   CON $0F    ' STATUS register address
        ' Clock Variables
            sec         VAR BYTE  ' seconds
            MINs        VAR BYTE  ' minutes
            hr          VAR BYTE  ' hours
            day         VAR BYTE  ' day of week (Sunday = 7)
            date        VAR BYTE  ' date in month
            mon         VAR BYTE  ' month
            yr          VAR BYTE  ' year
        ' ALARM1 VARIABLES
            A1sec       VAR BYTE  ' seconds
            A1MINs      VAR BYTE  ' minutes
            A1hr        VAR BYTE  ' hours
            A1day       VAR BYTE  ' day
        ' ALARM2 VARIABLES..not used in this application
            'A2MINs      VAR BYTE  ' minutes
            'A2hr        VAR BYTE  ' hours
            'A2day       VAR BYTE  ' day
    '*****************SETUP FOR USING LM34 Temperature Sensor**************
        'DEFINE osc 8           ' Using a 16 MHz oscillator..already defined
        DEFINE ADC_BITS 10      ' Set A/D for 10-bit operation
        DEFINE ADC_CLOCK 5      ' Set A/D clock Fosc/16
        DEFINE ADC_SAMPLEUS 50  ' Set A/D sampling time @ 50 uS
        samples VAR WORD        ' Multiple A/D sample accumulator
        sample  VAR BYTE        ' Holds number of samples to take
        value   VAR WORD        ' Holds LM34 measured temperature value
        samples = 0             ' Clear samples accumulator on entry
    'WRITE 3,3      'EEPROM test to see if program executes to here
    '*********SETUP FOR USING ConnectOne Mini Socket iWiFi module**********
    BOOT:   'iCHIP SET UP
      HIGH _RES_PD     ' Set high for normal ops
      PAUSE 500        ' Delay to stabilize coming out of power down mode
      LOW MSEL         ' Exit SERIALNET mode and return iChip to normal AT+i mode
      PAUSE 10000
      HIGH MSEL        ' Set high for normal AT+i ops
      'SEROUT2 PORTC.0,16468,["TEMP OUTSIDE ",DEC temp,$d,$a,$d ,$a] 'test not used
      PAUSE 500
      SEROUT2 TX,6,[ "AT+I",$d ,$a]
      WRITE 4,4       'EEPROM test to see if program executes to here..it does
      SERIN2 RX ,6,2500,BROKE,[ WAIT("I/OK")]
    'WRITE 5,5   'EEPROM test to see if program executes to here
         ' ABOVE TEST INDICATESInterface to iChip is NOT working!
      'SEROUT2 PORTC.0,16468 , [ "iChip OK",$d,$a ]  'test not used
      'SEROUT2 PORTC.0,16468 , [ "TEST_" , DEC3 CNT , 13 , 10 ]  'test not used
      SEROUT2 TX ,6 , [ "AT+iIPA?" , $d , $a ]
      SERIN2 RX ,6 , 2500 ,BOOT , [ DEC ADR[0] , DEC ADR[1] , DEC ADR[2] , DEC ADR[3] ]
      WRITE 10, ADR[0] ' Write the received IP address to EEPROM as a test
      WRITE 11, ADR[1]
      WRITE 12, ADR[2]
      WRITE 13, ADR[3]
      GOSUB DIP
      PAUSE 2000
      'SEROUT2 TX,6,["AT+iWLWM=1",$d,$a] ' Sets WEP enabled with 64bit key
      'SERIN2 RX ,6,2500,BROKE,[ WAIT("I/OK") ]
      'SEROUT2 TX,6,["AT+iWLKI=1",$d,$a] ' Sets the Wireless LAN transmission WEP-Key index
      'SEROUT2 TX,6,["AT+iWLKn1=xxxxxxxxxx",$d,$a] ' Sets the Wireless LAN WEP key
      SEROUT2 TX,6,["AT+iWLSI=Buckskin",$d,$a] ' Sets the destination Wireless LAN SSID
      SEROUT2 TX,6,["AT+iWWW",$d,$a]        ' Activates iChip's internal web server
      SERIN2 RX,6,1000,BOOT,[WAIT("I/(")]
    '########### END OF SETUPS ##################
    GOTO JumpPoint ' Jump over all subroutines so they don't execute on powerup
    ' ----------------------[ START SUBROUTINES ]--------------------------
    InitializeDisplay:  ' Subroutine to initialize 2X16 or 2x8 LCD display
      '-----SETUP FOR USING 2x16 or 2x8 LCD THAT IS INSTALLED IN EASYPIC6--------
         IF LCD_Flag = 1 THEN
               TRISA = 0   ' Set PortA for all outputs for use with LCD
         ' LCD DEFINES FOR USING 2x16 LCD with PortA in EASYPIC6
               DEFINE LCD_DREG PORTA    ' Use PORTA for LCD Data
               DEFINE LCD_DBIT 0        ' Use lower(4) 4 bits of PORTA
                                          ' PORTA.0 thru PORTA.3 connect to
                                          ' LCD DB4 thru LCD DB-7 respectively
               DEFINE LCD_RSREG PORTA   ' PORTA for RegisterSelect (RS) bit
               DEFINE LCD_RSBIT 4       ' PORTA.4 pin for LCD's RS line
               DEFINE LCD_RWREG PORTC   ' LCD read/write port
               DEFINE LCD_RWBIT 2       ' LCD read/write bit
               DEFINE LCD_EREG PORTA    ' PORTA for Enable (E) bit
               DEFINE LCD_EBIT 5        ' PORTA.5 pin for LCD's E line
               DEFINE LCD_BITS 4        ' Using 4-bit bus
               DEFINE LCD_LINES 2       ' Using 2 line Display
               DEFINE LCD_COMMANDUS 1500' Command Delay (uS)
               DEFINE LCD_DATAUS 44     ' Data Delay (uS)
        ' DEFINE LCD Control Constants
               Line1   CON 128          ' Point to beginning of line 1 ($80)
               Line2   CON 192          ' Point to beginning of line 2 ($C0)
        ' Test the LCD during initialization
               LCDOut $fe,1:FLAGS=0:Pause 250    ' Clear Display
               LCDOUT $fe,Line1,"POWER ON"       ' Display on 1st line
               LCDOUT $fe,Line2,"LCD TEST"       ' Display on 2nd line
               PAUSE 2000
    SetTimeAndDate:  ' Subroutine to set current time, date and alarms
        ' Blink LED_GRN 2X times to indicate entered SetTimeAndDate
               FOR I = 0 TO 1
                   HIGH LED_GRN
                   PAUSE 500
                   LOW LED_GRN
                   PAUSE 500
               NEXT
        ' Initialize the display & clock
            PAUSE 100           ' Wait for LCD to startup after power on
            ' Initialize clock variables to 0
                yr=0:date =0:mon =0:day=0:hr=0:MINs=0:sec=0
                A1sec=0:A1MINs=0:A1hr=0:A1day=0
                'A2MINs=0:A2hr=0:A2day=0
            ' The BCD constants below set the RTC to: 17:17:00 on 08-02-2011
                hr=$17
                MINs=$17
                sec=$00
                day=$03
                mon=$08
                date=$02
                yr=$11
            ' Per MAXIM TechSupport, proper sequencing requires setting
            ' INTCN = 1, & A2IE=A1IE=0 before setting alarms.
                I2CWRITE SDA, SCL, RTCdevice, ContReg,[%00000100]
                PAUSE 10
            'Define ALARM1 FOR 17:18:00 & to alarm when mins/secs match (1/hr).
                ' This requires A1M1=A1M2=0 and A1M3=A1M4=1
                ' (A1xxx + $80 or A1xxx + 128d sets bit 7 as A1Mx = 1)
                A1hr   = %10011010  '$17 + $80 = %10011010, for A1M3 = 1
                                    'Bit6 must be 0 for 24 hour clock
                A1MINs = %00011000  '$18 = %00011000, for A1M2 = 0
                A1sec  = $00        '$00 = %00000000, for A1M1 = 0
                A1day  = %10000110  '$06 + $80 = %10000110, for A1M4 = 1
                                    'DY/_DT Bit6 = 0 for using Day of month alarm
            'Define ALARM2 FOR 14:01:00 & to alarm once per minute (00 secs)
            'Disabled in this application
                ' This requires A2M2 = A2M3 = A2M4 = 1
                ' (A2xxx + $80 or A2xxx + 128d sets bit 7 as A2Mx = 1)
                'A2hr   = $14 + $80  '$14  + $80 = %10010100, for A2M3 = 1
                'A2MINs = $01 + $80  '$01 + $80 = %10000001, for A2M2 = 1
                'A2day  = $07 + $80  '$07 + $80 = $10000111, for A2M4 = 1
            ' Per MAXIM TechSupport, reset control register for desired Alarm
            ' after setting alarms.
                I2CWRITE SDA, SCL, RTCdevice, ContReg,[%00000101]
                PAUSE 10
            'Set the main Time
                I2CWRITE SDA, SCL, RTCdevice, SecReg,[sec,MINs,hr,day,date,mon,yr]
                PAUSE 10
            'Set the Alarm1 Time
                I2CWRITE SDA, SCL, RTCdevice, Alm1sec,[A1sec,A1MINs,A1hr,A1day]
                PAUSE 10
            'Set the Alarm2 Time  ' Alarm2 disabled for this application
                'I2CWrite SDA, SCL, RTCdevice, Alm2min,[A2MINs,A2hr,A2day]
                'PAUSE 10
            IF LCD_Flag = 1 THEN ' This code block for testing only
               'Test to see if Time set correctly by displaying on LCD
                    I2CREAD SDA, SCL, RTCdevice, SecReg,[sec,MINs,hr,day,date,mon,yr]
                    LCDOUT $fe,1 ' Clear Display
                    LCDOUT $fe,Line1,"SetTime"
                    LCDOUT $FE,Line2,HEX2 hr,":",HEX2 MINs,":",HEX2 sec
                    PAUSE 3000    ' Delay so user can view display
                'Test if Alarm1 set correctly by displaying stored Alarm1 time
                    I2CREAD SDA,SCL,RTCdevice,Alm1sec,[A1sec,A1MINs,A1hr,A1day]
                    LCDOUT $fe,Line1,"SetAlm1"
                    LCDOUT $FE,Line2,HEX2 A1hr,":",HEX2 A1MINs,":",HEX2 A1sec
            ' Clear STATUS and set CONTROL registers
                I2CWRITE SDA, SCL, RTCdevice, StatusReg,[$00]
                PAUSE 10
                PAUSE 10
    Temperature:        ' Subroutine to measure temperature from LM34
    ' This subroutine is an adaptation from below reference to 10-bit A/D
    '*  Name    : LM34.BAS                                          *
    '*  Author  : Bruce Reynolds                                    *
    '*  Date    : 10/23/2001                                        *
    '*  Notes   :  8-bit A/D temperature conversion with National   *
    '*          ;  LM34CAZ analog temperature sensor.               *
    '*          :  See http://www.rentron.com/PicBasic/LM34.htm     *
        ' Setup registers for A/D input per Sec 21.0 of datasheet
        '1. Configure the A/D module:
          '  Configure analog pins, voltage reference AND I/O (ADCON1)
              ADCON1 = %00000011 'Vdd as ref; all analog except AN12 (RB0)
          '  SELECT A/D INPUT channel (ADCON0)
              ADCON0 = %001011000  'Set AN11 (PORTB.4) as A/D input but disabled
          '  SELECT A/D acquisition time & A/D conversion clock (ADCON2)
              ADCON2 = %10110101  'Right justified;TAD=16;A/D clock=Fosc/16
          '  Turn ON A/D module (ADCON0)
            ADCON0.0 = 1        'Enable the A/D module
        '2. Configure A/D INTERRUPT (IF desired):
            '  CLEAR ADIF BIT
            '  Set ADIE BIT
            '  Set GIE BIT
        '3. WAIT the required acquisition time (IF required).
            'PAUSE 250          ' Wait approximately 1/4 seconds per loop
        '4. Start conversion-Set GO/DONE BIT (ADCON0 register)
            ADCON0.1 = 1
        '5. WAIT FOR A/D conversion TO complete, by either:
            '  Polling FOR the GO/DONE BIT TO be cleared
                'OR
            '  Waiting FOR the A/D INTERRUPT
        FOR sample = 1 TO 20    ' Take 20 samples
            ADCIN 11, value      ' Read channel 11 into temp variable
            'PAUSE 2
            ' or use alternative manual method to read A/D input
                'WHILE ADCON0.1 : WEND
                '6. READ A/D Result registers (ADRESH:ADRESL);
                    'CLEAR BIT ADIF, if required.
                   'value.HIGHBYTE = ADRESH
                   'value.LOWBYTE = ADRESL
             samples = samples + value ' Accumulate 20 samples
            '7. FOR NEXT conversion, go TO STEP 1 or STEP 2, as
                'required. The A/D conversion time per BIT IS
                'defined as TAD. A minimum WAIT of 3 TAD IS
                'required before the NEXT acquisition starts.
        NEXT sample
        value = samples/20      ' Determine average of 20 measurements
        'ADC Math for 10-bit A/D when using Vdd as referenc
            'ADC Resolution = 4.99 V/1024 COUNT = 4.912109 mV/COUNT
            '=> LM34DZ OUTPUT voltage (mV) = 2 x COUNT
            'Temperature ( F) = LM34 OUTPUT voltage in mV/10
            '=> Temperature ( F) = 4.912109 x COUNT/10 = 0.4912109*COUNT
            ' Therefore temp = 0.4912109*Count or approx. = Count/2.036
        ' To avoid floating point math, multiply by 1000 and then DIV32
        value  = 1000 * value
        temp = DIV32 2036
        'temp = value
        samples = 0             ' Clear old sample accumulator for next cycle
        ADCON1 = 255            ' Go to all digital ops
    Email:
          EMAIL_SET:
            SEROUT2 TX,6,["AT+iSBJ:iChip ADC TEMPERATURE",$d,$a] 'Permanently sets Email header s Subject field
            SERIN2 RX ,6,2500,EMAIL_SET,[WAIT("I/OK")]
            SEROUT2 TX,6,["AT+iTOA:[email protected]",$d,$a]  'Permanently sets Email addressee
            SEROUT2 TX,6,["AT+ito:jellis00",$d,$a]      'Permanently sets Email header s =To:  description
            SEROUT2 TX,6,["AT+iREA:[email protected]",$d,$a] 'Permanently sets the RETURN EMAIL Address
            SEROUT2 TX,6,["AT+iFRM:iChip",$d,$a]        'Permanently sets Email header =From: description.
            SEROUT2 TX,6,["AT+iSMTP:mail.comcast.net",$d,$a]'Sets the SMTP Server Name or IP.
            SEROUT2 TX,6,["AT+iSMA=1",$d,$a]            'Permanently sets SMTP authentication method
            SEROUT2 TX,6,["AT+iSMP:Kevin111",$d,$a]       'Permanently sets authenticated SMTP login
            SEROUT2 TX,6,["AT+iSMU:[email protected]",$d,$a]'Permanently sets Authenticated SMTP login User Name.
          ' Put code here to email low temperature warning via WiFi
            SEROUT2 TX,6,["AT+iEMA:",$d,$a]  'Defines a plain text e-mail body
            SEROUT2 TX,6,["HI, THIS IS FROM 206 N Veterans.",$d,$a]
            SEROUT2 TX,6,["SENT EVERY 2 minutes.",$d,$a]
            SEROUT2 TX,6,["THE TEMPERATURE IS.",$d,$a]
            SEROUT2 TX,6,[DEC temp," F Inside.",$d,$a]
            SEROUT2 TX,6,["GO TO:",$d,$a]
            SEROUT2 TX,6,["http://www.lodestarassoc.com/ichip/ichip.html",$d,$a]
            SEROUT2 TX,6,["FOR A ONE MINUTE UPDATE.",$d,$a]
            'After successfully sending the e-mail, IF the stay online flag (!) IS specified.
                   SEROUT2 TX,6,[$d,$a,".",$d,$a]
                   SERIN2 RX,6,[WAIT("I/ONLINE")]
            PAUSE 1000
            'SEROUT2 PORTC.0,16468,["EMAIL SENT ",$d,$a]  'test not used
            WRITE 5,$01       ' Write 1 to EEPROM as test if Email sent
            HIGH PORTC.5      ' blink green led as test to show email sent
            PAUSE 1000
            LOW PORTC.5
    DIP:
          'IF (!ADR[1]) AND )!ADR[1]) AND (!ADR[2]) AND (!ADR[3]) THEN
            HIGH PORTC.6      'blink red led as test if not connected
            PAUSE 1000
            LOW PORTC.6
          'ENDIF
          'SEROUT2 PORTC.0,16468,[" CONNECTED ",$d,$a] ' test not used
          'SEROUT2 PORTC.0,16468,["ADR - " ,DEC3 ADR[0],".",DEC3 ADR[1],".",DEC3 ADR[2],".",DEC3 ADR[3],$d,$a]
          PAUSE 1000
      BROKE:
            SEROUT2 PORTC.0,16468,["NOT WORKING",$d,$a] 'Commented out for now
            WRITE 16, "B"     'Record in EEPROM as test if Broke
            ' Blink LED_RED 2X times to indicate iChip not working
               FOR I = 0 TO 1
                   HIGH LED_RED
                   PAUSE 500
                   LOW LED_RED
                   PAUSE 500
               NEXT
            PAUSE 500
            GOTO BOOT
    ' ----------------------[ END OF SUBROUTINES ]--------------------------
    JumpPoint:
        'Setup before starting Main Program
        IF LCD_Flag = 1 THEN        ' only if LCD installed....
           GOSUB InitializeDisplay  ' initialize LCD before starting mainloop
        IF LCD_Flag = 1 THEN ' This code block FOR TESTING ONLY with LCD
            LCDOut $fe,1' Clear Display
            LCDOUT $fe,Line1,"Entered"
            LCDOUT $fe,Line2,"JumpPoint"
            Pause 2000
        'GOSUB SetTimeAndDate   'RTC presumably already set. Uncomment if not &
                                'set the current time and alarm settings in the
                                'SetTimeAndDate subroutine.
        'Initialize epoch indexes at time of powerup/reset
            PAUSE 20
            ' Write start date/time/Alarm1 to EEPROM at startup
              WRITE 7, mon
              WRITE 8, date
              WRITE 9, yr
              WRITE 11, hr
              WRITE 12, MINs
              WRITE 13, sec
              WRITE 14, A1hr
              WRITE 15, A1MINs
            Pause 20
            J = 0                ' Initialize EEPROM logging index
        ' Setup test for low voltage condition that causes Vdd to go below 3.3 vdc
          ' Setup registers for HLVD module to support low voltage interrupt
              ' Setup the interrupt and an ISR in your code and enable the interrupt
              ' where you want to test for low voltage
        'Initialize LEDs to off
            LOW LED_GRN
            LOW LED_RED
        ' Enable the interrupts that are to be active during main loop.
            ext_pwr = 1            ' Turn on external power to LM34 & SRF02
            logflag = 0            ' Clear flag before main loop
    @    INT_ENABLE   RBC_INT      ; enable RB Port Change interrupts
    @    INT_ENABLE   LVD_INT      ; enable LVD interrupt
    HIGH ext_pwr                   ' Turn external power on to SRF02 & LM34
    '--------------------[ Begin Main Program Loop ]-------------------------
    ;@ StartSize(MainLoop)    ; FOR TEST ONLY
    mainloop:
        ' Blink Green LED 1x at start of Main Loop
            HIGH LED_GRN
            PAUSE 250
            LOW LED_GRN
            PAUSE 250
        ' Read current time/date
            PAUSE 20
        ' Display current Date/Time if LCD installed
            IF LCD_Flag = 1 THEN ' Display only if LCD installed
                LCDOUT $fe,Line1,HEX2 mon,"/",HEX2 date,"/", HEX2 yr
        ' Read temperature and send email if below/above threshold
            GOSUB Temperature
            IF (temp <= $28) THEN  ' If temp <= 40 deg F send email
               GOSUB Email
            IF (temp >= $55) THEN   ' If temp >= 85 deg F send email
               GOSUB Email
            ADCON1 = %00001110
        ' Write current temperature to EEPROM ....for test only..comment out
            WRITE 10, temp
        ' If low voltage exists during main loop a HLVD interrupt will take place
        ' here and LED_RED will blink 3x warning of low voltage.
            IF LowVolt = 1 THEN ' Blink LED_RED 5X to indicate Low Voltage detected
                FOR I = 0 TO 2
                    HIGH LED_RED
                    PAUSE 250
                    LOW LED_RED
                    PAUSE 250
                    LowVolt=0     ' Reset LowVolt flag
                NEXT
        ' Put code here for actions to take due to RTC Alarm1 interrupt
            IF logflag = 1 THEN   'RTC interrupt has occured..start ISR
                FOR I = 0 TO 1    ' Blink Green LED 2x due to ISR entry
                    HIGH LED_GRN
                    PAUSE 250
                    LOW LED_GRN
                    PAUSE 250
                NEXT
                IF J > 220 THEN  ' If logging space is full start over with logging
                   J = 0     ' Reset logging index to start of logging space
                             ' Logging space covers time stamps for 220 interrupts
            'Put code here to measure/log temperature from LM34 analog sensor
                GOSUB Temperature
                WRITE 16+J, hr    ' Log timestamp for temperature to EEPROM
                WRITE 17+J, MINs
                WRITE 18+J, sec
                WRITE 19+J, temp
                J = J+4
              GOSUB Temperature
                 GOSUB Email
                 GOSUB Email
              ADCON1 = %00001110
            'If LCD installed reset to all digital ops before display of temperature
                    TRISA = 0          ' Reset PortA to all outputs for LCD use
                    TRISB = %00001100  ' RB2 & RB3 set as RTC Alarm1 & Alarm2 inputs
                                ' PORTB.2 is also an input from switch grounding
                    ADCON0 = %00101100   ' A/D idle and disabled
                    ADCON1 = %00101111   ' All Digital
                    LCDOUT $fe,Line1,"Temp:"  ' Display measured temperature
                    LCDOUT $FE,Line2, DEC temp, " DEG F"
                    PAUSE 1000
            ' Clear RTC STATUS and set CONTROL registers for next RTC interrupt
                PAUSE 10
                logflag = 0    ' clear flag after logging
        GOTO mainloop
    ;@ EndSize(MainLoop)    ; Uncomment FOR TEST ONLY
    '--------------------[ Begin Interrupt Handlers ]------------------------
    Alarm:
            logflag = 1     ' Set flag to trigger logging in mainloop
        ' Resume Program where Interrupt happened
    @ INT_RETURN
    VoltLow:
            LowVolt = 1     ' Set low supply voltage warning flag
    @ INT_RETURN
    '------------------{ End of Interrupt Handlers }-------------------------
    End     ' Safety measure to insure program stops if reaches here
    ;@ EndSize(LOOKUP)       ; FOR TEST ONLY
    ;@ LibrarySize           ; FOR TEST ONLY
    ;@ UserSize              ; FOR TEST ONLY
    ;@ TotalSize             ; FOR TEST ONLY
    Aug 2010
    Maryland, USA
    You have to read the error messages, they will tell you what to comment. then when you open the file, it is also well commented and says stuff like Comment this line if you get error such and such
    -Bert
    Mar 2009
    Colorado
    Here is a list of my error messages. I don't see what they are telling me that I have to comment out. Are you saying that the well commented lines are in the .lst file after assembly? I am confused as to what file I need to open to read where the lines that need to be commented out are listed.
    Error[113]   C:\PBP26\PBPPIC14.LIB 1181 : Symbol not previously defined (wsave)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 476 : ERROR: (wsave variable not found,)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 440 : ERROR: ("                     Add:"       wsave VAR BYTE $70 SYSTEM)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 497 : ERROR: (Chip has RAM in BANK1, but wsave1 was not found.)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 447 : ERROR: ("   Add:"       wsave1 VAR BYTE $A0 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 513 : ERROR: (Chip has RAM in BANK2, but wsave2 was not found.)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 454 : ERROR: ("   Add:"       wsave2 VAR BYTE $120 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 523 : ERROR: (Chip has RAM in BANK3, but wsave3 was not found.)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 461 : ERROR: ("   Add:"       wsave3 VAR BYTE $1A0 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 800 : ERROR: ("INT_Handler" -  Interrupt Flag ( PIR2,LVDIF ) not found.)
    Error[113]   C:\PBP26\PBPPIC14.LIB 449 : Symbol not previously defined (ADCON2)
    Error[113]   C:\PBP26\PBPPIC14.LIB 463 : Symbol not previously defined (ADCON2)
    Error[113]   C:\PBP26\PBPPIC14.LIB 477 : Symbol not previously defined (ADCON2)
    Error[113]   C:\PBP26\PBPPIC14.LIB 491 : Symbol not previously defined (ADCON2)
    Error[113]   C:\PBP26\PBPPIC14.LIB 899 : Symbol not previously defined (ADCON2)
    Error[101]   C:\PBP26\ELLIS_CODES\WIFI\16F886\0DS1337CLOCKEDTEMPWIFI.ASM 800 : ERROR: ("INT_ENABLE" -  Interrupt Flag ( PIR2,LVDIF ) not found.)
    Since version 1.00 of DT_INTS-14, it is best if you DO NOT comment or un-comment lines in the include file.
    Changing the include file can affect compiling with other chips that have different BANK configurations.
    Instead, copy the wsave variables block from the file into your source code, and un-comment the lines that the compiler refers to in the errors.
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    The errors you posted indicated to ADD wsave, wsave1, wsave2 and wsave3.
    It also indicated "OR" change to wsave VAR BYTE $70. If you add that line, you don't need the other wsaves.
    So a simple ...
    in your code will suffice.
    Also, the 16F886 doesn't have a Low Voltage Detect circuit (LVD). So LVD_INT cannot be used.
    Mar 2009
    Colorado
    Thanks, Darrel. That solved the problem.
    However, I might suggest that you flag this info on the DT_INTS-14 web site for others that may be having this problem. I checked there first to see if I could find anything related to these errors.
    John Ellis
    Mar 2009
    Colorado
    Thanks for pointing that out, Darrel. I see now that I have to find another way to detect low battery voltage. In that regard, I am wondering if their is some way to hook the battery output on my PCB to one of the comparator inputs and comparing it somehow to an internally generated reference voltage. I tried to study the Comparator section of the 16F886 data sheet to see if this was possible, but I got lost in the complexity of the comparator circuits and how to generate a CVref into it from internal circuitry.
    Can you point me to any posts or tutorial that might explain how to do this?
    Not sure, but maybe this thread will help.
    It might look familiar.
    http://www.picbasic.co.uk/forum/showthread.php?t=11489
    Mar 2009
    Colorado
    Thanks, Darrel. I am embarassed to say I had forgotten all about this thread
