can the ADC in the pics test a circuit that only changes resistance in 3 ohm increments?
3ohm on what? Input Voltage matter, not the impedance step....How about Vref VS Vdd?
The PIC measures voltage, not resistance. There is not enough information here to give an intelligent answer.
Charles Linquist
ok, sorry, i know it measures voltage and resistance effects voltage. so, i guess i will try to explain what im trying to convey. lol
basically i need to test a circuit, to see if its open or closed. the item that closes the circuit is an ematch and they are only 3 ohms, and there could be multiple ematches in series or parallel, i was thinking it would be nice to be able to tell by the adc reading, how many and maybe how they are wired. i was also thinking of using just a simple ressistive voltage divider, where R2 would be the ematch and R1 would be 10k. Vdd 3.3 , Vref 3.3 maybe less. Vout would go to the adc pin. there would also be a diode in series with R1 and R2, the adc pin would connect after R1, have to shield the pic (18lf6622 ) from the 24Vdc that would also be there every now and then. When i do the math, it is a drastic change when going from R2 being 0 and R2 being 3 ohms, but a very small change when R2 changes from 3 to 6 ohms or even 9 ohms. So what im wondering is will the adc even register this small of a change?
Simple answer: If full scale =0 - 3.3V, and the adc is 10 bit, LSB = 3.3/1024 = 3.22265mV. I would think you should plan for 1LSB error so you could detect ~6mV worst case. Now there are plenty of debate around here about 1024 vs 1023, but I live in 1024 world
-Bert
Even though the A/D is 10 bits, you won't get a lot of accuracy unless you have a dedicated Vref and you average a lot of readings. You might get 9 bits of accuracy in that case.
You can do a lot better if you amplify the signal with a rail-to-rail input / rail-to-rail output op amp.
If you don't want to go that route, you are going to have to get a bigger voltage change than you will get with your setup. First, R1 will have to be smaller than 10K. I don't know how many "ematches" you plan to have, but 330 ohms would seem to be a good value. Of course, the resistor would have to be a 5W type. This will give you 72mA through the resistor, and .218V across 3 ohms. You will also need a 2K 1/2W resistor between the junction of R1 and R2 and the PIC input to protect it when the switches are open. That should give you enough signal to work with.
Charles Linquist
