ADC'ing higher DC voltage dilemna
Results 1 to 8 of 8
    Default Re: ADC'ing higher DC voltage dilemna
    Hi Hank,
    As far as I know all I/O pins have internal clamp diodes, Vss->Pin->Vdd. As long as the top end resistor of the divider is large enough to limit the current going into the pin and up thru the diode to a safe level you should be fine. Use a logic level MOSFET and "disconnect" the bottom of the divider from GND/Vss.
    If you look at the SERIN command in the PBP manual they are actually using this scheme, a 22k resistor in series with the TX-line from the PC makes it work just fine even though the TX-line toggles between something like +/-12V or there abouts.
    Give it a try.
    Aug 2011
    I see a lot of references to using the internal clamp diodes of chips for a number of purposes.
    Those interested may want to read the following Microchip documents:
    TB3009 (http://ww1.microchip.com/downloads/e...tes/93009A.pdf)
    TB3013 (http://ww1.microchip.com/downloads/e...tes/93013a.pdf)
    And then see if they still want to recommend doing this.
    That's an excellent read, thank you for the links!
    As with most things the way you choose to do something may differ from time to time and recommendations changes. There are limitations to using the internal diodes, as described in those docs but, depending on the application it may still work fine.
    However, passing current thru the internal diode kind of defeats the purpose (I didn't think it thru properly). The idea was to disconnect the voltage divider from ground to lower the current consumption but if we're passing current thru the pin diode (or external diode) into Vcc we haven't gained much....ooops.
    Perhaps a second MOSFET or analog switch in series with the pin....
    Hank, take a look at http://www.electricstuff.co.uk/picav...tery%20voltage
    Its precisely what you are looking for. And while there, do check out the other neat things on the home page!
    Anand
    Mar 2009
    Hank, take a look at http://www.electricstuff.co.uk/picav...attery voltage
    Anand
    Thanks Anand mate ....a clever low parts count solution - job done! (curious as to how long that tranny is switched on to allow an ADC sample of the potenetial divider junction voltage to take place though!)
    (thanks Henrik & tumbleweed for the input too)
    I'm glad it worked for you. Did you actually try it out yet?
    Anand
    Mar 2009
    No not yet....another 2-3 days before I get around to knocking up the associated circuit on breadboard - I'll report back.
