serial to ethernet device
Results 1 to 4 of 4
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default serial to ethernet device
    Anyone heard of a simple device that will allow 2 way comms between 2 pics over ethernet? I want to put serial in at one end and recover it as serial at the other end with some reverse data then sent. I have seen plenty of these sort of things that rely on having a PC at one end, not exactly what I want.
    There's gotta be something like this somewhere??
    Peter Moritz.
    New South Wales,
    Australia.
    Dec 2005
    Default Re: serial to ethernet device
    Here are links to several.
    Many of the WizNet devices (even those designed for PCB mounting) have RS232 transceivers onboard. The Wiz105SR has 0-3V levels and non-inverted logic. The WizFi210 is only $US30 if you want to go WiFi - it can do Ad Hoc (peer-to-peer) but I've no idea about range.
    Sep 2005
    Campbell, CA
    I use Lantronix XPorts. They work well.
    Charles Linquist
    Sep 2005
    France
    I use TIBBO devices... Working fine.... EM1206 have 1 ethernet port, 4 serials I/O
