Decimal value
Results 1 to 6 of 6
Thread: Decimal value
    Feb 2005
    Portugal
    Default Decimal value
    If I have one ADC value of 819 thatīs one value of 15.9 in my corrent whatīs the code to measure with one decimal my corrent. Iīm having a little difficulties to measure with one decimal. Iīm using PIC16F872 and 10 ADC bits.
    If ADC value of 819 equals say 15.9mA then just do some math to convert 819 into 159 and remember there is one decimal place in your answer which needs attention whenever you display...
    819*1942/10000=159
    so...
    The variables...
    ADCValue var Word
    TempA var Word
    TempB var Word
    Result var Word
    The Calculation (see PBP manual section 4.17.8 DIV32 command)...
    TempA=1942
    TempB=ADCValue*TempA
    Result=DIV32 10000
    The display (see PBP manual 4.17.7 DIG command)...
    LCDOut $FE,1
    If Result>99 then LCDOut #Result DIG 2
    LCDout #Result DIG 1,".",#Result DIG 0,"mA"
    Your display will show... 15.9mA
    Feb 2005
    Portugal
    Smile Thankīs
    Ok thankīs a lot.
    I was forgetting DIG command. I was using / and // to give me the values, but itīs much simple DIG command.
    Leonel Monteiro
    Feb 2005
    Portugal
    Default 32 bits multiplication
    I have one problem:
    I achieve my best performance in low corrents doing this code:
    ADCIN 0, ADC_corrente
    pause 10
    x = ADC_corrente * 2360
    res = DIV32 10000
    if res > 99 then
    unid_corrente = res DIG 0
    dec_corrente = res / 10
    unid_corrente = res DIG 1
    dec_corrente = res DIG 0
    but when ADC value * 2360 is biggest then 65535 i lost my upper 16bits, because the operator * returns the lower 16 bits of a 32 bits result.
    What i have to do to doesnīt lost bits?
    I know ** returns the upper 16 bits but there are any way to have the result in one variable?
    Yes, the ONE VARIABLE answer is in RES.
    Look...
    The maximum value for your 10-bit ADC is 1024...
    Multiply this by 2360 gives 2416640...
    divide this by 10,000 gives 241
    everything is within range of PBP's capabilities...
    The dummy WORD value 'x' when used as x=ADC*2360 is irrelevant, you follow that immediately with your DIV32 statement so the correct value of 241 ends up in RES.
    Remember that RES is a factor of TEN greater... ie RES=241 is actually 24.1 so just do the math to extract what you need.
    You can't have floating points in integer math, sometimes you have to "think outside of the box" in order to achieve what you want.
    Feb 2005
    Portugal
    Talking Wrong code
    Your right. I had a wrong code, so i though it was because multiplication has an 32 bits result.
    The correct code is:
    pause 10
    res = DIV32 10000
    if res > 99 then
    unid_corrente = res / 10
  1. variable + decimal
    Last Post: - 18th August 2009, 15:21
  2. Binary Coded Decimal
    By -Dan- in forum mel PIC BASIC Pro
    Last Post: - 25th May 2009, 10:23
  3. hex ascii help please
    By ffr58kk90 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2006, 22:09
  4. 16bit variable and degrees conversion
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2005, 18:27
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 21:02
