A REALLY accurate clock.
Results 1 to 25 of 25
    Sep 2005
    Campbell, CA
    Default A REALLY accurate clock.
    Need to know the time - accurately for your next project?
    The code below allows your PIC to log into a network timeserver and it (eventually) writes the time to a Dallas RTC (code not supplied).
    The PIC checks the NET TIME every power-up and thereafter every 4 hours. If it doesn't make connection, it tries an alternate time server. If THAT doesn't work (after retries) it gives up and tries again 4 hours later. A Lantronix XPort handles the connection to the net.
    The PIC normally reads the time from the Dallas RTC. The clock is self-setting and self-correcting, as long as you have a network connection.
    And all of you using 16F chips, time to upgrade! This sub requires LONGS.
    Net Time' is the number of seconds since Jan 1 1900
    This sub accomodates for leap years, GMT offsets and Daylight Savings Time.
    The sub assumes you are in the present century, so it takes a shortcut by pre-subtracting the number of seconds from Jan 1 1900 to
    Jan 1 2009.
    It should be self-explanatory.
    Hoffset is the hours offset from GMT
    Sign = "1" or "2" depending on whether you are earlier or later than GMT
    DST = 1 if you are in Daylight Savings Time (Another part of the PGM changes that value when appropriate).
    GETNETTIME:
    NETRETRYCOUNT = 0
    GETNETTIME2:
    HSEROUT [13,10,"TIMESERVER ",#TSIP1,".",#TSIP2,".",#TSIP3,".",#TSIP4,13,1 0]
    PAUSE 100
    THEADER[0] = $2 ' STX
    THEADER[1] = TSIP1 ' DESTINATION IP
    THEADER[2] = TSIP2
    THEADER[3] = TSIP3
    THEADER[4] = TSIP4
    THEADER[5] = 0 ; DESTINATION PORT HIGHBYTE
    THEADER[6] = 123 ; DESTINATION PORT LOWBYTE
    LRC1 = 0
    LRC2 = 0
    For X = 1 to 6
    LRC1 = LRC1 ^ THeader[x]
    next X
    THEADER[7] = LRC1
    THEADER[8] = 0
    THEADER[9] = 48 'Data Length lowbyte
    ;Send the header
    HSEROUT [13,10]
    For X = 0 to 9
    HSEROUT2 [THeader[X]]
    Next X
    LRC2 = LRC2 ^ THeader[8]
    LRC2 = LRC2 ^ THeader[9]
    ;Send the data
    HSEROUT2 [$1B]
    LRC2 = LRC2 ^ $1B
    For X = 0 To 46
    HSEROUT2 [0]
    LRC2 = LRC2 ^ 0
    NEXT X
    ;Send the Checksum (LRC)
    HSEROUT2 [LRC2]
    getresponse:
    HSERIN2 1000,NoResponse,[Wait($2)]
    hserin2 200,NoResponse,[SKIP 41,TimeNow.Byte3,TimeNow.Byte2,TimeNow.Byte1,TimeN ow.Byte0]
    READ 851,HOFFSET
    IF sign = "1" then
    if DST = 1 and HOffset = 0 THEN
    Sign = "2"
    GOTO OtherSide
    TimeNow = Timenow - ((HOffset - DST) * 3600)
    OtherSide:
    IF Sign = "2" THEN
    TimeNow = TimeNow + ((Hoffset + DST) * 3600)
    SINCEJAN2009 = TIMENOW - 3439756800 ; 3439756800 is the #of sec from Jan1 1900 to Jan1 2009
    RUNNINGSECONDS = SINCEjAN2009
    YR = 2009
    GETYEAR:
    LEAP = (YR//4) ; = 0 if leap year
    if LEAP = 0 then
    SecondsInYear = 31622400 ;366*60*60**24
    SecondsInYear = 31536000 ;365*60*60*24
    If RunningSeconds > SecondsInYear Then
    RunningSeconds = RunningSeconds - SecondsInyear
    YR = YR + 1
    GOTO GetYear
    Mo = 1 ; Start with Month = 1
    GETMONTH:
    IF LEAP > 0 THEN
    lookup2 MO,[0,2678400,2419200,2678400,2592000,2678400,2592000, 2678400,2678400,2592000,2678400,2592000,2678400],SecondsInMonth
    LOOKUP2 MO,[0,2678400,2505600,2678400,2592000,2678400,2592000, 2678400,2678400,2592000,2678400,2592000,2678400],SecondsInMonth
    If RunningSeconds >= SecondsInMonth THEN
    RunningSeconds = RunningSeconds - SecondsInMonth
    MO = MO + 1
    GOTO GETMONTH
    FINDDAYS:
    DA = RUNNINGSECONDS/86400
    RUNNINGSECONDS = RUNNINGSECONDS//86400
    HR = RUNNINGSECONDS/3600
    RUNNINGSECONDS = RUNNINGSECONDS//3600
    MN = RUNNINGSECONDS/60
    RUNNINGSECONDS = RUNNINGSECONDS//60
    SC = RUNNINGSECONDS
    Da = Da + 1
    HSEROUT [13,10,13,10,DEC2 HR,":",DEC2 MN,":",DEC2 SC," ",DEC2 MO,"/",DEC2 DA,"/",#YR,13,10]
    Charles Linquist
    Default Re: A REALLY accurate clock.
    Cool stuff,
    did you keep a few vars to hold "last update" or last update time ?
    And, wouldn't it be convienent to have a time server to give;
    simple to read bytes........ yr,month,day-of-week, month day,hr,min,sec,AM/PM .......8 specific bytes in some order,
    The request could be like .........Give Simple uP Time for EST (eastern standard time) and the server could do all calculations.
    Don
    Apr 2003
    Cambridge - UK
    Promoted to an article in the WIKI - Code Examples section
    Sep 2005
    Campbell, CA
    I have a LOT of other variables. Most of my 18F8723's chips are 98% full (~10K lines of code). For a lot of reasons, I can't post the whole thing here.
    Believe it or not, I also have a complete SNMP V2 agent running in PBP!
    Charles Linquist
    Dec 2005
    Do you have an SMTP routine with authentication that you could post?
    Sep 2005
    Campbell, CA
    I have an SMTP routine, but I have posted enough stuff lately that I have to "back off". I do owe my employer a lot, and I have to respect the property that is rightfully theirs.
    Charles Linquist
    Dec 2005
    Here's a link to some SMTP with Authentication code that those with the need can translate to PBP.
    Sep 2005
    Campbell, CA
    Dave,
    I have a complete SNMP (V2) agent in PBP as well. Three different encoding schemes in every packet!
    Charles Linquist
    Aug 2010
    Maryland, USA
    But Charles, is that part of the "not allowed to post" code?
    -Bert
    Sep 2005
    Campbell, CA
    Unfortunately, yes. I shouldn't have even mentioned it. I'm pretty proud of it, though!
    Charles Linquist
    Aug 2010
    Maryland, USA
    Well it does at least prove it can be done, so for that you get a point. but wait- you started picking on the 16f guys again, so I must subtract half a point. So you are still half good- LOL
    -Bert
    Sep 2005
    Campbell, CA
    I'm actually slowly rewriting my SNMP routines to take advantage of ArrayRead and ArrayWrite. They simplify things a bit, and it also makes the code more understandable and maintainable.
    And I'm not really picking on people who use 16F chips. It isn't their fault that they are misinformed.
    Charles Linquist
    California, USA
    We're not necessarily misinformed... we just have a lot of old stock to burn up still.
    Aug 2005
    Michigan, USA
    May I ask what you mean by 'misinformed', please?
    Sep 2005
    Campbell, CA
    It is just my continuous jab at those who continue to use 16F parts. There are not many times when a 16F part is the best for an application. 18F parts have advantages in speed, code efficiency, better peripherals, if you run out of program space, there are (usually) larger parts in the same family that you can easily move to.
    They can deal with large arrays and you can use LONG integers with PBP.
    And, they generally cost no more than their "little brothers".
    Charles Linquist
    Aug 2005
    Michigan, USA
    I understand what you're saying and I agree (generally) with your premises but you shouldn't dismiss or exclude the 12F and 16F "enhanced" midrange devices. They're pretty potent with a 32-MHz clock, linear RAM address mapping, an interesting assortment of peripherals (some not found on 'legacy' 18F devices), and an excellent price/performance ratio. In fact, I can think of one case where the new FVR (fixed voltage reference) module is found on some 18F "K" series devices and on some 12F/16F "enhanced" devices, but the "K" series devices can't use the FVR output as the ADC +vref input as can be done on the 12F/16F "enhanced" devices.
    Sep 2005
    Campbell, CA
    Noted. Those parts have some really nice features, and I do use the 12F parts from time to time for such menial tasks as 555 replacements, but I am still amazed at the huge number of people using 16F parts. In many cases, the solutions would be easier if they simply switched to an 18F part. The reluctance to change baffles me.
    Charles Linquist
    Aug 2005
    Michigan, USA
    May I ask, in what context? Are you talking about easier with respect to programming in PBP which may lack some features on the 16F parts?
    Sep 2005
    Campbell, CA
    The 18Fs have more/better peripherals, allow for LONGs and big arrays and almost all run at 40Mhz. They also allow for near seamless upgrades when your needs exceed 32K of FLASH.
    Charles Linquist
    Aug 2005
    Michigan, USA
    Charles, please forgive me for pressing. I've got a Philosophy class this semester and I guess I'm trying to frame your comment into premises and conclusion.
    I certainly wouldn't argue that the 18F' parts have "more" of just about everything (flash, RAM, clock speed, peripherals, etc.). I'm just not sure how you would quantify "in many cases", and, unless PBP is missing capabilities or features for 16F targets compared to 18F targets, I'm not sure how writing programs might be "easier" for one or the other. I've got LONG data types for 12F, 16F, and 18F targets with the BoostC compiler I'm using. Is that not the case with PBP?
    Sep 2005
    Campbell, CA
    PBP does not support LONGs in 16F chips.
    Charles Linquist
    Feb 2005
    Kolkata-India
    Default Can vouch for the 18Fs but can't ignore the newer 16Fs
    Hi Everybody,
    Couldn't resist commenting. Microchip is actually trying to bridge the gap between the 18Fs and 16Fs with the inclusion of features already in the 18Fs.
    I believe with the acquisition of Hi-Tech they would finally settle down the 8 bit tool chain into the Hi-Tech compiler stable. So need for a C optimized chip is obvious and thus the grown up 16Fs (enhanced mid range).
    Since I started up with the 18Fs I always prefer them cause you got plenty of headroom to blow up your application into the next level. Interestingly the new exciting features are not available on the 18s or very limited, seems 16Fs would not stand the competition with the 18Fs.
    Here are some interesting features introduced on the new 16Fs
    1. CWG (Complementary Waveform Generator)
    2. NCO (Numerically Controlled Oscillator)
    3. CLC (Configurable Logic Cell)
    4. DSM (Data Signal Modulator)
    5. SetReset Latch
    6. Comparator with Hysteresis
    7. Fixed Voltage Reference 1.024/4.096
    8. 5 Bit DAC
    9. Multiple number Enhanced PWM with some features like PWM steering.
    Charles, I am seriously thinking of using the 16Fs as a co-processor and still fiddling around the idea of developing the co-processor in C (better support perhaps with the newer libraries like mTouch) with SPI connectivity doing specific hardware tasks relieving the main processor (obviously an 18F) to do more. Think of the possibilities.
    Sougata
    Sep 2005
    Campbell, CA
    Default Re: Can vouch for the 18Fs but can't ignore the newer 16Fs
    Those new features in the 16Fs are certainly neat!
    And regarding your idea:I could use a good floating point co-processor! I think you could do other neat things as well.
    I have done something similar for my own use. I always use all the pins on the processor, I guess I keep adding peripherals until all the pins are used. In any case, someone always wanted something else - something that my circuit didn't have.
    I needed an "intelligent peripheral" that would do all sorts of different things, so I started with an 8F2321's (in I2C mode). I defined a command set that will take a '2321 and let you configure virtually anything 'on the fly'. It allows you to:
    Set up all the TRIS registers
    Write to any pin
    Read any pin
    Set up any A/D channels
    Read pins (as analog or digital) once, or continuously (in a continuous loop).
    Polls all digital pins on a timer interrupt (1 or 5ms rate)
    Latches INT0 (It captures the transition so I don't miss it)
    Can become an I2C master on certain events (INT0, for example), so that the other PIC can respond almost immediately.
    This '2321 then becomes a part of a new board layout. I add the peripherals (level shifters, voltage dividers, thermocouple amps, etc) and connect it to the main '8723 with 4 wires (SDA,SCL,Vdd and GND). The '2321 is always programmed with the same code and the main PIC configures it on power
    up. The '2321 has a default configuration (also modifiable) that it loads from EEPROM on startup.
    This arrangement works well for me - especially since I can (field) bootload the main chip (8723), but not the peripheral ('2321), so having a part that I can
    - under command, change the way it works has been invaluable. I have added features simply by telling the customer to add a wire to a pin on the board and
    then emailing him the hex file that processes it.
    I can't sell my part. But I think there is a need for something similar (with even more features). Do it!
    Charles Linquist
    Feb 2005
    Kolkata-India
    Still can't ignore the sub-dollar pricing (10K) for the newer 16F parts !!!!
    Sougata
    Dec 2008
    Los Angeles, CA
    Hello Charles,
    I know that you have extensive experience with XPORT, so would like to ask you a question. Is 115200 the maximum baud rate when using this device? What is the fastest baud rate possible using PBP in general, either ethernet or RS422/485? I have a note here that I saw reference to 5 Mbaud RS422 in a forum post, but can't find any such thing. Maybe that was just a good dream?
    Thanks very much,
    Len
