Epoch time, Do most people know ?
Results 1 to 9 of 9
    Default Re: Epoch time, Do most people know ?
    Hi Charles,
    Exactly, with SNTP "time began" at 1/1-1900.
    I see your code uses LONGS which I'm trying to avoid but I'll digest it and see what might come out, thanks for sharing, I appreciate it!
    Sep 2005
    Campbell, CA
    I guess that I left out some stuff in the code above.
    It is designed for use with a Lantronix XPort. It logs on to port 123 of timeservers and comes back with network time.
    And, yes, you ***MUST*** use 18F chips!
    The stuff that goes before it is -
    THEADER[0] = $2           ' STX
            THEADER[1] = TSIP1  ' DESTINATION IP
            THEADER[2] = TSIP2
            THEADER[3] = TSIP3
            THEADER[4] = TSIP4
            THEADER[5] = 0            ; DESTINATION PORT HIGHBYTE
            THEADER[6] = 123          ; DESTINATION PORT LOWBYTE
            LRC1 = 0
            LRC2 = 0
            For X = 1 to 6
                 LRC1 = LRC1 ^ THeader[x]
            next X
            THEADER[7] = LRC1
            THEADER[8] = 0
            THEADER[9] = 48                                             'Data Length lowbyte
    ;Send the header
              For X = 0 to 9
                HSEROUT2 [THeader[X]]
              Next X
              LRC2 = LRC2 ^ THeader[8]
              LRC2 = LRC2 ^ THeader[9]
    ;Send the data
              HSEROUT2 [$1B]
               LRC2 = LRC2 ^ $1B
              For X = 0 To 46
                HSEROUT2 [0]
                LRC2 = LRC2 ^ 0
              NEXT X
    ;Send the Checksum (LRC)
              HSEROUT2 [LRC2]
    getresponse:
             HSERIN2 1000,NoResponse,[Wait($2)]
             hserin2 200,NoResponse,[SKIP 41,TimeNow.Byte3,TimeNow.Byte2,TimeNow.Byte1,TimeNow.Byte0]
    Charles Linquist
    Thanks Charles,
    I'm using the 18LF46K22 and W5100 ethernet chip, the SNTP stuff are done and I get the seconds count from the server, no issues there. It's the conversion from seconds to true time that's bugging me and the reason I'm trying to avoid longs is that it adds a lot of overhead to the program even in sections not actually using longs.
    I'm on my way to convert your convert-routine to use 16 bit variables but it does get a bit messy...
    Thanks again for sharing!
    Sep 2005
    Campbell, CA
    It shouldn't be too bad - breaking it into 16 bit 'chunks' , you will just have an offset that is not just hours, but hours, minutes and seconds.
    Charles Linquist
