Epoch time, Do most people know ?
Results 1 to 9 of 9
    Default Epoch time, Do most people know ?
    I just learned this (59 yrs old and still learning, who'd have thunk) . Do people know about Epoch Time ?
    Simply, its the time in seconds (32 bit value) since 1/1/1970. It expires or rolls over in 1938 or sometime about then.
    I know anyone can figure this out , when I started tracking seconds on PIC with longs, that will go for 68 years before rollover !!!! Just thought that was pretty cool.
    With the Epoch time value, its GMT and apparently (obviously) they subtract the seconds-in-a-hour to match your time zone. Don't know yet how to retrieve this val from someware.
    Also, (I know anyone can figure this out) there are only about 8000 hours in a year, and if you sleep and eat for 10 hrs a day your down to 4 to 5000 hrs left. And work takes up min 2000/yr.
    The point is, not a lot of time left after necessities to enjoy.
    Don
    Miami, Florida USA
    Default Re: Epoch time, Do most people know ?
    Unless I'm making some dumb mistake, I think 32 bits will give enough seconds to go for 136 years.
    (2^32) / (3600*24*365) = 136 years
    And, yes life is too short for all the things that we would like to do.
    Anonymous
    Hi Robert,
    You bring up a good point, an issue thats not always clear. Indeed 32 bit is some 4 Billion count unless it is Signed, then its half + & -.
    The PBP manual says Longs are treated as signed. Info on the web said that Epoch time was a signed value, but on the Epoch info web you can put bigger values than 2.5 billion in the calc date and get a future date in what should be the (-) values.
    I think it just shows that you have to know the intended use and MIN and MAX values of what your working with.
    I tried out incrementing a long when it rolls over from 2^31, it displays continued count using DEC, but using SDEC, it rolls to -2^31 then counts down minus on increment. I know thats what it should do, just makes it a little clearer.
    This is with SDEC modifier:
    Don
    amgen
    This thread came up pretty convenient as I've been working on my W5100 code to do SNTP - and now it does - just.
    The difference between epoch and SNTP is apparently that with epoch we start counting at 1/1-1970 while with SNTP we start at 1/1-1900. So going from SNTP timestamp to epoch is just a matter of subtracting 70 years worth of seconds
    I'm stuffing the 32bit timestamp from the server into two words which I now would like to convert to a more understandable format - like time of day and perhaps even date. If anyone has PBP code etc for this I'd love to see it.
    Sep 2005
    Campbell, CA
    But if you are trying to translate NETWORK time, that is the time from Jan 1, 1900
    The code below takes a "brute force" approach, but works. I'm sure some math whiz could
    certainly come up with a better formula.
    HOffset = Local offset from GMT
    Sign = 1 if you are EARLIER than GMT
    Sign = 2 if you are LATER than GMT ("+")
    DST = 1 if you are using DST
    The program takes a "shortcut" in that it calculates time since Jan 1, 2000
                   IF sign = "1" then
                      if DST = 1 and HOffset = 0 THEN
                           Sign = "2"
                           GOTO OtherSide
                         TimeNow = Timenow - ((HOffset - DST) * 3600)
    OtherSide:
                   IF Sign = "2" THEN
                      TimeNow = TimeNow + ((Hoffset + DST) * 3600)
                    SINCEJAN2009 = TIMENOW - 3439756800   ; 3439756800 is the #of sec from Jan1 1900 to Jan1 2009
                    RUNNINGSECONDS = SINCEjAN2009
                    YR = 2009
    GETYEAR:
                        LEAP = (YR//4)    ; = 0 if leap year
                        if LEAP = 0 then
                            SecondsInYear = 31622400 ;366*60*60**24
                            SecondsInYear = 31536000 ;365*60*60*24
                        If RunningSeconds > SecondsInYear Then
                            RunningSeconds = RunningSeconds - SecondsInyear
                            YR = YR + 1
                            GOTO GetYear
                     Mo = 1 ; Start with Month = 1
    GETMONTH:
                    IF LEAP > 0 THEN
                       lookup2 MO,[0,2678400,2419200,2678400,2592000,2678400,2592000,2678400,2678400,2592000,2678400,2592000,2678400],SecondsInMonth
                       LOOKUP2 MO,[0,2678400,2505600,2678400,2592000,2678400,2592000,2678400,2678400,2592000,2678400,2592000,2678400],SecondsInMonth
                    If RunningSeconds >= SecondsInMonth THEN
                       RunningSeconds = RunningSeconds - SecondsInMonth
                    MO = MO + 1
                    GOTO GETMONTH
    FINDDAYS:
                    DA = RUNNINGSECONDS/86400
                    RUNNINGSECONDS = RUNNINGSECONDS//86400
                    HR = RUNNINGSECONDS/3600
                    RUNNINGSECONDS = RUNNINGSECONDS//3600
                    MN = RUNNINGSECONDS/60
                    RUNNINGSECONDS = RUNNINGSECONDS//60
                    SC = RUNNINGSECONDS
                    Da = Da + 1
                   HSEROUT [13,10,13,10,DEC2 HR,":",DEC2 MN,":",DEC2 SC,"   ",DEC2 MO,"/",DEC2 DA,"/",#YR,13,10]
    Charles Linquist
    Hi Charles,
    Exactly, with SNTP "time began" at 1/1-1900.
    I see your code uses LONGS which I'm trying to avoid but I'll digest it and see what might come out, thanks for sharing, I appreciate it!
