ADCIN giving inconsistent results
Results 1 to 14 of 14
    Sep 2005
    Campbell, CA
    Default Re: ADCIN giving inconsistent results
    My guess is that if you clear V_total, you won't need anything else.
    Consider:
    If the A/D returns a value of 410
    1st time through the loop
    V_Total = 200
    Second time through the loop
    V_Total = 202
    Third time through the loop
    V_Total = 204
    And it goes through those loops pretty fast. I can see how the results would look inconsistent
    Charles Linquist
    Mar 2009
    Quote Originally Posted by triton99 View Post
    What I was wanting to know, is there a better way of reading the voltage using an ADC on the 16F675.
    fwiw I've come to the conclusion that using the picbasic 'ADCIN' command = much badness (unstable ADC readings for me at least)
    Nowadays, if I've a spare CCP module going free, I always use the PIC's special event trigger - it's a very tidy effiicient way of collecting ADC samples in the background - Once it's setup (it's not hard to do this), whenever you want a sample - it's already therefore you ...just go and grab the contents of ADRESH. Job done, eg...
    v_in  = ADRESH
    'now go do cool stuff with v_in
    The 16f675 has a special event trigger option ...it uses CCP4 for it, so...if you're not intending utilising CCP4, then seriously consider dedicating it to the special event trigger....
    Sep 2005
    Campbell, CA
    Add one line and most of your problems will go away.
    fans_off:
        low low_fan
        low high_fan
    read_v:
        V_Total = 0    <--------------------------------------------------------------
        for i = 1 to sample_size
           pauseus 50
           ADCIN 3, v_in                ' Read channel 3 to V_in (0-1023)
           V_Total = (V_In + V_total)
        next i
        V_total = V_total/sample
    Charles Linquist
    Jun 2011
    St. Louis, MO
    mister-e: Thanks for the document on reducing system noise. I dont know how I missed that one.
    Charles Linquist: Thanks for pointing out reseting the V_Total variable. My brain sometimes gives me flawed logic...
    HankMcSpank: I orginally tried to use the ADC directly using ADRESH. For some reason I could not get it to work. Once I get back home I will mess with it again. It seemed like a better approach.
    Thanks again everyone, and I will be testing this again today on the car, so I will post the results when finished.
    "Reality is merely an illusion, albeit a very persistent one." , Albert Einstein
    Jun 2011
    St. Louis, MO
    After a few weeks of work and family things, I finally found the time to complete the project. The ACDIN results were inconsistent at first, but I etched a new board and instead of SMD components I used thru-hole. The new board worked perfect on the bench but failed on the car...until I realized I had used a NPN transistor instead of an PNP. Before I realized this I made a small relay board that the transistor would switch, which would then turn on the cooling fans. I salvaged the relay from an old TRS-80 motherboard that was ruined. Once the transistor was swapped out and the relay board added, everything worked perfect. We took some test runs, and the cooling fans turned on/off as expected. When the transistors were switched I also had to reverse the high/low settings on the relay outputs on my board. My personal blog has a little more info. http://triton9.wordpress.com/
    Thanks again to everyone for all the help!!
Size:  123.3 KBName:  FanController_3.jpg
Size:  138.7 KBName:  FanController_v2.jpg
Size:  142.5 KBName:  FanController_4.jpg
    I specialy like the custom MicroChip enclosure.....
    EN82fn
    Jun 2011
    St. Louis, MO
    Yeah...cant beat free!! I have a few of those sitting around gathering dust so it seemed like a perfect reason to get rid of one. First we cut a small rectangle in the top for the relay, then my friend drilled some holes for airflow.
