Counting led blinks..
Results 1 to 40 of 93
    Default Re: Counting led blinks..
    What errors are you getting?
    Serout2 PORTC.6, 84, ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a]
    Jun 2011
    Philippines
    Hi macrackit, I do not have any errors, I've been playing with it the whole night last night but no progress...
    I also tried the following alias pins configurations from a book..(uising pic18F452) but no luck.
     ' Alias PIC pins and registers for SD/MMC card
        SD_WE        VAR    PORTA.4    ' SD card write protect
        SD_WE_TRIS   VAR    TRISA.4    ' SD card write protect direction
        SDI          VAR    PORTC.5    ' SPI data in SD #7
        SDI_TRIS     VAR    TRISC.5    ' SPI data in direction
        SCL          VAR    PORTC.3    ' SPI clock  SD #5
        SCL_TRIS     VAR    TRISC.3    ' SPI clock direction
        SD_CS        VAR    PORTC.2    ' SD card chip select SD #1
        SD_CS_TRIS   VAR    TRISC.2    ' SD card chip select direction
        SD_CD        VAR    PORTC.0    ' SD card detect
        SD_CD_TRIS   VAR    TRISC.0    ' SD card detect direction
        SDO          VAR    PORTC.4    ' SPI data out   SD #2
        SDO_TRIS     VAR    TRISC.4    ' SPI data out direction
    Hmm..I don't understand, CS -> RB3, MOSI -> RC7, SCLK -> RB1 and MISO -> RB0 works fine without a problem, but assigning them to another port/pins giving me trouble.
    (BTW I'm using Pic18F4550, crystal 20Mhz)
    regards,
    tacbanon
    Jun 2011
    Philippines
    @mackrackit
    Hi, Sorry I spoke too soon, this is what I get when I'm trying to transfer to another port/pins "’nit: 6 2 0"
    From the SDFS file, the 6 and 2 from the generated errors.
    CE_INIT_ERROR Con 6 ' An initialization error has occured
    sdcCardNotInitFailure Con 2
    From section 10.3 18F4550 data sheet.
    On a Power-on Reset, these pins, except
    RC4 and RC5, are configured as digital
    inputs. To use pins RC4 and RC5 as digi-
    tal inputs, the USB module must be dis-
    abled (UCON<3> = 0) and the on-chip
    USB transceiver must be disabled
    (UCFG<3> = 1).
    And do you have the Capture / Compare turned off for PORTC?
    Jun 2011
    Philippines
    Thanks for helping me out mackrackit..but I'm still having trouble running the following(I'm really sure if I'm getting the settings correctly).
    Include "modedefs.bas"
    asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
        endasm
    DEFINE    OSC 48
    ' Include the SD/MMC subroutines (found in http://melabs.com/resources/samples/pbp/sdfs3.zip)
    cnt var word
    cnt = 0
        Include "SDFS.PBP"
        SDC_UseHardSPI = TRUE    ' Use hardware SSP port for SPI.
        ADCON1 = 15        ' All I/O pins digital
        '--Added Pic settings
        UCON.3 = 0        'USB module disabled
        UCFG.3 = 1        'USB transceiver disabled
        CCP1CON=0       '  Capture/Compare OFF
        CCP2CON=0       '
        Pause 100
        ' FSInit initializes the card and reads all the preliminary information from it
        Gosub FSInit
        If (FAT_error != 0) Then Stop
    ' This section defines a specific short (8.3) filename
    '  Note that spaces are use in empty elements and must be upper case for Windows
        FAT_FileName[0] = "R"
        FAT_FileName[1] = "E"
        FAT_FileName[2] = "C"
        FAT_FileName[3] = "O"
        FAT_FileName[4] = "R"
        FAT_FileName[5] = "D"
        FAT_FileName[6] = "S"
        FAT_FileName[7] = " "
        FAT_FileName[8] = "T"
        FAT_FileName[9] = "X"
        FAT_FileName[10] = "T"
    ' Set file time to 8:30:10 and date to 1/1/2008
        FAT_seconds = 5
        FAT_minutes = 30
        FAT_hours = 8
        FAT_day = 1
        FAT_month = 1
        FAT_year = 28
    ' Open a file for write
        FAT_mode = "A"        ' Write mode
        Gosub FSfopen        ' Open file pointed to by Byte array FAT_FileName
        Serout2 PORTC.6, 84, ["Open for write: ", Dec FAT_error, $d, $a]
     cnt = cnt + 5
    ' Write to file
        FAT_src[0] = $30+cnt
        FAT_src[1] = "M"
        FAT_src[2] = "I"
        FAT_src[3] = "C"
        FAT_src[4] = "R"
        FAT_src[5] = "O"
        FAT_src[6] = "B"
        FAT_src[7] = "O"
        FAT_src[8] = "X"
        FAT_src[9] = 13
        FAT_src[10] = 10
        FAT_count = 11
        Gosub FSfwrite
        Serout2 PORTC.6, 84, [ "Write ", Dec FAT_error, $d, $a]
    ' Close file
        Gosub FSfclose
        Serout2 PORTC.6, 84, [ "Close ", Dec FAT_error, $d, $a]
    Kindly check my hardware Connections
    SDCARD MCU(4550)
    CS ------ RC2
    MOSI ------- RC5
    SCK ------- RC3
    MISO -------RC4
    I'm not having a display in the terminal to identify the error produced, What do you think I'm missing?
    Thanks in advance,
    tacbanon
    Should be FALSE
    Jun 2011
    Philippines
    That was it Dave, thank you for sharing your time...But I have another question, can I still make USB CDC with the setup we modified?regards,tacbanon
