Counting led blinks..
Results 1 to 40 of 93
    Jun 2011
    Philippines
    Default Re: Counting led blinks..
    Hi, I have only one 4550 and I want to try it to another chip, I only have pic18f2550..I followed some instructions to comment the default config fuse in PBP INC files. I tried to compile this part of the code..
        '<FL_PIC18F2550>'    '<FL_PBPL>'
        DEFINE OSC 48
        @ __CONFIG   _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        @ __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
        @ __CONFIG   _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
        @ __CONFIG   _CONFIG2L, _PWRT_ON_2L & _VREGEN_ON_2L
        @ __CONFIG   _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
        @ __CONFIG   _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
        Include "modedefs.bas"
            ' Alias PIC pins and registers for SD/MMC card
        SD_WE        VAR    PORTA.4    ' SD card write protect
        SD_WE_TRIS   VAR    TRISA.4    ' SD card write protect direction
        SDI          VAR    PORTA.5    ' SPI data in SD #7
        SDI_TRIS     VAR    TRISA.5    ' SPI data in direction
        SCL          VAR    PORTA.3    ' SPI clock  SD #5
        SCL_TRIS     VAR    TRISA.3    ' SPI clock direction
        SD_CS        VAR    PORTC.2    ' SD card chip select SD #1
        SD_CS_TRIS   VAR    TRISC.2    ' SD card chip select direction
        SD_CD        VAR    PORTC.0    ' SD card detect
        SD_CD_TRIS   VAR    TRISC.0    ' SD card detect direction
        SDO          VAR    PORTC.1    ' SPI data out   SD #2
        SDO_TRIS     VAR    TRISC.1    ' SPI data out direction
    But gives me the following compilation error...
    regards,
    tacbanon
    Use the same configs for the 2550 as you did for the 4550.
    The only thing you need to do to move to the 2550 is change some pin assignments if you were using some on the 4550 that the 2550 does not have.
    Make sure you have all of the needed files in the new project directory.
    Jun 2011
    Philippines
    Thanks mackrackit, I just found out that the sdcard module I ordered will take a while(2weeks from china). The sdcard I borrowed did not work either.In the meantime...I will be working on the keypad codes for accessibility feature of this project...be back soon.
    Jun 2011
    Philippines
    Hi, I got my new sdcard just the other day...now I've been trying to make following code work... I did tried to connect to another ports/pins but was not able to make it run.
    asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
        endasm
    DEFINE    OSC 48
    ' Include the SD/MMC subroutines (found in http://melabs.com/resources/samples/pbp/sdfs3.zip)
    cnt var word
    cnt = 0
        Include "SDFS.PBP"
        SDC_UseHardSPI = TRUE    ' Use hardware SSP port for SPI.
        ADCON1 = 15        ' All I/O pins digital
        Pause 100
        ' FSInit initializes the card and reads all the preliminary information from it
        Gosub FSInit
        Serout2 PORTC.6, 84, ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a]
        If (FAT_error != 0) Then Stop
    ' This section defines a specific short (8.3) filename
    '  Note that spaces are use in empty elements and must be upper case for Windows
        FAT_FileName[0] = "R"
        FAT_FileName[1] = "E"
        FAT_FileName[2] = "C"
        FAT_FileName[3] = "O"
        FAT_FileName[4] = "R"
        FAT_FileName[5] = "D"
        FAT_FileName[6] = "S"
        FAT_FileName[7] = " "
        FAT_FileName[8] = "T"
        FAT_FileName[9] = "X"
        FAT_FileName[10] = "T"
        FAT_seconds = 5
        FAT_minutes = 30
        FAT_hours = 8
        FAT_day = 1
        FAT_month = 1
        FAT_year = 28
    ' Open a file for write
        FAT_mode = "A"        ' Write mode
        Gosub FSfopen        ' Open file pointed to by Byte array FAT_FileName
        Serout2 PORTC.6, 84, ["Open for write: ", Dec FAT_error, $d, $a]
     cnt = cnt + 5
    ' Write to file
        FAT_src[0] = $30+cnt
        FAT_src[1] = "M"
        FAT_src[2] = "I"
        FAT_src[3] = "C"
        FAT_src[4] = "R"
        FAT_src[5] = "O"
        FAT_src[6] = "T"
        FAT_src[7] = "E"
        FAT_src[8] = "S"
        FAT_src[9] = "T"
        FAT_src[10] = 10
        FAT_count = 11
        Gosub FSfwrite
        Serout2 PORTC.6, 84, [ "Write ", Dec FAT_error, $d, $a]
    ' Close file
        Gosub FSfclose
        Serout2 PORTC.6, 84, [ "Close ", Dec FAT_error, $d, $a]
    Haredware: Pic16F4550, PBP2.60, crystal 20Mhz
    The alias PIC pins and registers for SDcard is a copy from Macrackit, Can you tell me what I'm doing wrong?
    The alias pins below works with no problem..
    SD_WE        Var    PORTA.4    ' SD card write protect
    SD_WE_TRIS    Var    TRISA.4    ' SD card write protect direction
    SDI        Var    PORTB.0    ' SPI data in
    SDI_TRIS    Var    TRISB.0    ' SPI data in direction
    SCL        Var    PORTB.1    ' SPI clock
    SCL_TRIS    Var    TRISB.1    ' SPI clock direction
    SD_CS        Var    PORTB.3    ' SD card chip select
    SD_CS_TRIS    Var    TRISB.3    ' SD card chip select direction
    SD_CD        Var    PORTB.4    ' SD card detect
    SD_CD_TRIS    Var    TRISB.4    ' SD card detect direction
    SDO        Var    PORTC.7    ' SPI data out
    SDO_TRIS    Var    TRISC.7    ' SPI data out direction
    But I want to move the pins off from PortB.
    Thanks and regards,
    tacbanon
    What errors are you getting?
    Jun 2011
    Philippines
    Hi macrackit, I do not have any errors, I've been playing with it the whole night last night but no progress...
    I also tried the following alias pins configurations from a book..(uising pic18F452) but no luck.
        SDI          VAR    PORTC.5    ' SPI data in SD #7
        SDI_TRIS     VAR    TRISC.5    ' SPI data in direction
        SCL          VAR    PORTC.3    ' SPI clock  SD #5
        SCL_TRIS     VAR    TRISC.3    ' SPI clock direction
        SDO          VAR    PORTC.4    ' SPI data out   SD #2
        SDO_TRIS     VAR    TRISC.4    ' SPI data out direction
    Hmm..I don't understand, CS -> RB3, MOSI -> RC7, SCLK -> RB1 and MISO -> RB0 works fine without a problem, but assigning them to another port/pins giving me trouble.
    (BTW I'm using Pic18F4550, crystal 20Mhz)
    regards,
    tacbanon
    Jun 2011
    Philippines
    @mackrackit
    Hi, Sorry I spoke too soon, this is what I get when I'm trying to transfer to another port/pins "’nit: 6 2 0"
    From the SDFS file, the 6 and 2 from the generated errors.
    CE_INIT_ERROR Con 6 ' An initialization error has occured
    sdcCardNotInitFailure Con 2
    From section 10.3 18F4550 data sheet.
    On a Power-on Reset, these pins, except
    RC4 and RC5, are configured as digital
    inputs. To use pins RC4 and RC5 as digi-
    tal inputs, the USB module must be dis-
    abled (UCON<3> = 0) and the on-chip
    USB transceiver must be disabled
    (UCFG<3> = 1).
    And do you have the Capture / Compare turned off for PORTC?
