Counting led blinks..
Results 1 to 40 of 93
    Default Re: Counting led blinks..
    I see missing % on these
    ADCON1 = 001111
    T0CON = 111000
    And each one should have 8 bits.
    Go back and look at post #19 of this thread.
    Jun 2011
    Philippines
    ' Name        : Coin_Internet_CDC.pbp' Compiler    : PICBASIC PRO Compiler 2.6
    ' Assembler   : PM or MPASM
    ' Target PIC  : PIC18F4550
    ' Hardware    : Easypic6 Experimenter Board
    ' Oscillator  : 4MHz external crystal (only???)
    ' Thanks      :  To Henrik, and other PBP experts
    ' Description : PICBASIC PRO program to show virtual serial comm. Working
    asm
       __CONFIG    _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
        endasm
    DEFINE    OSC 48
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    PAUSE 100
    Include    "cdc_desc.bas"    ' Include the HID descriptors
    Buffer    VAR BYTE[10]
    Buffer2    VAR BYTE[10]
    Cnt       VAR BYTE
    b0   var byte
    B1   VAR BYTE   ' Working buffer 1 for button command
    sel   VAR BYTE   ' Working buffer 2 for button command
    B3   VAR BYTE   ' Working buffer 3 for button command
    i    var byte
    Clear        ' Clear buffers
    INTCON2.7 = 0        ' Enable PORTB pull-ups
    TRISB = 110000          ' Enable all buttons
    ADCON1 = 15               ' Set all I/Os to Digital
    CMCON = 7                 ' Disable Comparators
    Cnt = 5
    i = 0
    TRISA.4 = 1 ' RA4/T0CKI = input to TMR0 counter
    TRISA.0 = 0 ' RA0 = output for LED
    CMCON = 7   ' All digital
    'If you prefer, then increment on low-to-high transitions
    T0CON   = %11111000
    USBInit                   ' Initialize USART
    ' Main Program Loop
    Loop1:
    Lcdout $fe, 128, "Counter: ", #i
    USBService ' Must service USB regularly
    TMR0L = 0     ' Clear TMR0 count before start
    '**************ADDED COde
    'gosub usbtx
    'goto Loop1
    Loop2:
        USBService
        WHILE TMR0L = 0 ' Wait for high-to-low transition
        USBService
        WEND           ' on RA4/T0CKI
        pause 5
        PORTB.0 = 1    ' LED on to indicate transition seen
        i=i+1       ' Clear screen
        USBService
        buffer[0] = 49
        Buffer[1] = 13
        USBOut 3, Buffer, cnt,Loop2
        'PAUSE 30
        PORTB.0 = 0    ' LED off
        goto Loop1
    Hi mackrackit, the above code works. Now what I'm trying to do is add a ntoher line of code to send "c" in the main loop but I can not seem to make it work.
    asm   __CONFIG    _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        endasm
    DEFINE    OSC 48
    DEFINE LCD_DBIT 0
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    PAUSE 100
    Buffer    VAR BYTE[10]
    Cnt       VAR BYTE
    b0   var byte
    i    var byte
    Cnt = 5
    i = 0
    T0CON   = %11111000
    ' Main Program Loop
    Loop1:
    gosub usbtx   ' transmit character c to pc
    Loop2:
        USBService
        USBService
        WEND           ' on RA4/T0CKI
        pause 5
        USBService
        buffer[0] = 49
        Buffer[1] = 13
        'PAUSE 30
        goto Loop1
    usbtx:
    USBService
    Buffer2[0] = 99
    Buffer2[1] = 13
    USBOut 3, Buffer2, cnt,usbtx
    The above code I use to attempt sending to pc...BTW I dont know what happened (T0CON = %11111000 and ADCON1 = %00001111) to the bits (but I think I did not alter it).
    thanks,
    tacbanon
    Does the Loop2 part still work in the code with the usbtx sub routine? It looks to me like it should work. Or maybe it is too long between USBservices.
    If that is the case include the routine to service the USB in the background like the example gave for testing.
    Jun 2011
    Philippines
    Hi, yes Loop2 still works(i increments), but I wonder why usbtx does not sends the "c" character to pc?
    regards,
    tacbanon
    Give this a shot. It works here.
    INCLUDE "cdc_desc.bas"
    INCLUDE "USB_ASM_Service.pbp"    ' Base Interrupt System
    LED       VAR PORTB.0
    Buffer    VAR BYTE[10]
    Cnt       VAR BYTE
    i    var byte
    Cnt = 5
    i = 0
    T0CON   = 111000
    LOW LED
    Loop1:
    Loop2:
    WEND           ' on RA4/T0CKI
    pause 5
    PORTA.2 = 1    ' LED on to indicate transition seen     LED PORTA.2
    buffer[0] = 49
    Buffer[1] = 13
    USBOut 3, Buffer, 2,Loop2
    LOW LED   ' LED off
    goto Loop1
    usbtx:
    TOGGLE LED
    Buffer2[0] = 99
    Buffer2[1] = 13
    USBOut 3, Buffer2,2,usbtx
    Jun 2011
    Philippines
    Hi, thanks for the time. I run your code...but the character "c" appears only when a pulse is detected in my setup. Hmm it should be running as expected...
    regards,
    tacbanon
    That is what I thought you wanted?
    If you want it to send "C" continuously
      GOSUB usbtx
      PAUSE 100
    WEND           ' on RA4/T0CKI
