Counting led blinks..
Results 1 to 40 of 93
    Default Re: Counting led blinks..
    Not sure but the usual thing to check:
    Does the pin you're trying to use have other functions mutliplexed to it, like ADC, Comparator, USB etc and does any of these peripherals need to be turned off for the pin to work in the mode you want. I see you've got the comparator covered but how about the ADC?
    What do you mean by there is no display? Do you mean it doesn't the display the result or do you mean it doesn't display anything?
    Again, check each pin against the datasheet, does have anything that may need to be turned off?
    Jun 2011
    Philippines
    Post Re: Counting led blinks..
    hi,
    No display on the Lcd
    I dont think I'm gonna need ADC so I will need this...
    ADCON0 = 000000 ' A/D converter off
    ADCON1 = 15 ' make it digital
    ucfg = 010100 ' I'm planning later on to use the usb
    I'm not really sure if I'm getting it right, I'm struggling with the datasheet. The above added code has no effect..
    tacbanon
    Jun 2011
    Philippines
    I got it, I have to remove ADCON0, just use ADCON1 = 15.
    Thanks for your precious time, and "Thank GOD for PBP forum"
    Next stop is to make this chip as usb cdc to pass the data to pc...
    regards,
    tacbanon
    Jun 2011
    Philippines
    Hi, now I'm trying to create a usb cdc together with the reading pulse code.
    asm    ;__CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
                                ;                  ;               ; Oscillator Switchover mode disabled
                                ;                  ; Fail-Safe Clock Monitor disabled
                                ; XT oscillator, PLL enabled, XT used by USB
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
    DEFINE OSC 48
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    PAUSE 100
    Include    "cdc_desc.bas"    ' Include the HID descriptors
    buffer    Var    Byte[16]
    Cnt       VAR BYTE
    Cnt = 16
    TRISA.4 = 1 ' RA4/T0CKI = input to TMR0 counter
    TRISA.0 = 0 ' RA0 = output for LED
    CMCON = 7   ' All digital
    ADCON1 = 001111      ' A/D converter off
    ' increment on low-to-high transitions
    T0CON   = 111000
    USBInit                   ' Initialize USART
    i var byte
    i=0
    Lcdout $fe, 128, "Counters: ", #i
    pause 20
        TMR0L = 0     ' Clear TMR0 count before start
        USBService        ' Service USB regularly
    Loop1:
        WHILE TMR0L = 0 ' Wait for high-to-low transition
        WEND           ' on RA4/T0CKI
        pause 10
        PORTB.0 = 1    ' LED on to indicate transition seen
        i=i+1       ' Clear screen
        buffer = i
        Lcdout $fe, 128, "Counter: ", #i
        'PAUSE 30
        PORTB.0 = 0    ' LED off
        USBService
        USBOut 3, Buffer, cnt, Main
    But I got this message "USB device not recognize". What could be causing this problem?
    regards,
    tacbanon
    I hope someone else will chime in and try to help you because I've never used USB and don't know what the usual culprits are. Only advice I can give is to look at other examples and compare. Perhaps start with a working example and then add your counting code in "on top".
    Jun 2011
    Philippines
    Okay thanks for the advice Henrik
    regards,
    tacbanon
    Jun 2011
    Philippines
    Hi everyone, now the usb device is recognized and its in Port COM2. My only problem is that my pulse counter variable i is reseting back to zero when a pulse(acctually I'm using a button on RA4 to simulate the pulse) is detected. In the code I did not yet insert the command "USBOut 3, buffer, cnt, Main" to send to pc.
        endasm
    DEFINE OSC 48
    DEFINE LCD_DBIT 0
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    PAUSE 100
    buffer    Var    Byte[16]
    Cnt       VAR BYTE
    Cnt = 2
    'If you prefer, then increment on low-to-high transitions
    T0CON   = 111000
    i var byte
    i=0
    ' Assign prescaler to WDT for 1:1 prescale on TMR0
    ' TMR0 clock will be from your external input on RA4/T0CKI
    ' Increment on high-to-low transitions
    'pause 20
        USBService    ' Must service USB regularly
    Loop1:
        USBService
        WEND           ' on RA4/T0CKI
        pause 5
        i=i+1       ' increment i
        USBService
    I appreciate any help...
    thanks in advance,
    tacbanon
