Counting led blinks.. - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 93
  1. #41
    Jun 2011
    Philippines
    Default Re: Counting led blinks..
    Hi, thanks for the responce. I successfully run this sample sd program.
    asm    __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
        endasm
    DEFINE    OSC 48
    ' Name        : sdfs3.pbp
    ' Compiler    : PICBASIC PRO Compiler 2.6 (PBPL only)
    ' Assembler   : MPASM
    ' Target PIC  : PIC16F4550
    ' Hardware    : Schematic available in http://melabs.com/resources/samples/pbp/sdfs3.zip
    ' Oscillator  : 20MHz
    ' Keywords    : SD Card, SD/MMC, FAT16
    ' Description : 10/02/08 - PICBASIC PRO 2.50L test program to talk to FAT16
    ' formatted MMC/SD cards with PIC18F4550.  This is only a test program that
    ' is part of a larger project.  The complete fileset with schematic, includes,
    ' and details can be found at download:
    ' http://melabs.com/resources/samples/pbp/sdfs3.zip
    ' Alias PIC pins and registers for SD/MMC card
    SD_WE        Var    PORTA.4    ' SD card write protect
    SD_WE_TRIS    Var    TRISA.4    ' SD card write protect direction
    SDI        Var    PORTB.0    ' SPI data in
    SDI_TRIS    Var    TRISB.0    ' SPI data in direction
    SCL        Var    PORTB.1    ' SPI clock
    SCL_TRIS    Var    TRISB.1    ' SPI clock direction
    SD_CS        Var    PORTB.3    ' SD card chip select
    SD_CS_TRIS    Var    TRISB.3    ' SD card chip select direction
    SD_CD        Var    PORTB.4    ' SD card detect
    SD_CD_TRIS    Var    TRISB.4    ' SD card detect direction
    SDO        Var    PORTC.7    ' SPI data out
    SDO_TRIS    Var    TRISC.7    ' SPI data out direction
    ' Include the SD/MMC subroutines (found in http://melabs.com/resources/samples/pbp/sdfs3.zip)
        Include "SDFS.PBP"
        SDC_UseHardSPI = TRUE    ' Use hardware SSP port for SPI.
        ADCON1 = 15        ' All I/O pins digital
        Pause 100
        ' FSInit initializes the card and reads all the preliminary information from it
        Gosub FSInit
        Serout2 PORTC.6, 84, ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a]
        If (FAT_error != 0) Then Stop
        ' Display card directory
        Gosub FINDfirst        ' Find first file on card
        While (FAT_error = 0)
            Serout2 PORTC.6, 84, [Str FAT_FileName\11, $d, $a]
            Gosub FINDnext    ' Find next file on card
        Wend
    ' This section defines a specific short (8.3) filename
    '  Note that spaces are use in empty elements and must be upper case for Windows
        FAT_FileName[0] = "T"
        FAT_FileName[1] = "E"
        FAT_FileName[2] = "S"
        FAT_FileName[3] = "T"
        FAT_FileName[4] = "1"
        FAT_FileName[5] = " "
        FAT_FileName[6] = " "
        FAT_FileName[7] = " "
        FAT_FileName[8] = "T"
        FAT_FileName[9] = "X"
        FAT_FileName[10] = "T"
    ' Set file time to 8:30:10 and date to 1/1/2008
        FAT_seconds = 5
        FAT_minutes = 30
        FAT_hours = 8
        FAT_day = 1
        FAT_month = 1
        FAT_year = 28
    ' Open a file for write
        FAT_mode = "w"        ' Write mode
        Gosub FSfopen        ' Open file pointed to by Byte array FAT_FileName
        Serout2 PORTC.6, 84, ["Open for write: ", Dec FAT_error, $d, $a]
    ' Write to file
        FAT_src[0] = "A"
        FAT_src[1] = "B"
        FAT_src[2] = "C"
        FAT_count = 3
        Gosub FSfwrite
        Serout2 PORTC.6, 84, [ "Write ", Dec FAT_error, $d, $a]
    ' Close file
        Gosub FSfclose
        Serout2 PORTC.6, 84, [ "Close ", Dec FAT_error, $d, $a]
    ' Open a file for read
        FAT_mode = "r"        ' Read mode
        Serout2 PORTC.6, 84, ["Open: ", Dec FAT_error, $d, $a]
    ' Read and display the whole file
        FAT_count = 1        ' Read 1 byte to buffer at a time
        Gosub FSfread
            Serout2 PORTC.6, 84, [FAT_dest[0]]
            Gosub FSfread
        Wend
        Serout2 PORTC.6, 84, [ "Read: ", Dec FAT_error, $d, $a]
    I also have my rtc module available. but at this time I do know how to use your code or connect it the developmemt board.
    regards,
    tacbanon
  2. #42
    Jun 2011
    Philippines
    Hi, I was able to test my RTC from this thread http://www.picbasic.co.uk/forum/showthread.php?t=12918...so far so good
    regards,
    tacbanon
  3. #43
    COOL!!!!!
    The next piece of the puzzle is to get familiar with DT's instant interrupts. If you have not already done so.
    The short USB example earlier will need to be re-written to use DT's instants in place of the USB service include.
    Then put all of the pieces together. Modular type programming....
  4. #44
    Jun 2011
    Philippines
    Hi, sorry this question is related to previous post #27...I need to to send a character "c"(dec 99) constantly to the pc in the main loop(loop1). Then send 1(dec 49) if any coin pulse is detected.
    ' Main Program LoopLoop1:
    'Lcdout $fe, 128, "Counter: ", #i
    USBService ' Must service USB regularly
    '**************ADDED COde
     Buffer2[0] = 99
     Buffer2[1] =13
     TMR0L = 0
     USBOut 3, Buffer2, cnt,Loop1
     goto Loop1
    TMR0L = 0     ' Clear TMR0 count before start
    Loop2:
        USBService
        WHILE TMR0L = 0 ' Wait for high-to-low transition
        USBService
        WEND           ' on RA4/T0CKI
        pause 5
        PORTB.0 = 1    ' LED on to indicate transition seen
        i=i+1       ' Clear screen
        USBService
        buffer[0] = 49
        Buffer[1] = 13
        USBOut 3, Buffer, cnt,Loop2
        'PAUSE 30
        PORTB.0 = 0    ' LED off
        goto Loop1
    When I run the program..it displays "c" to the pc but never detect pulse when coin is dropped. Can you help me out what I'm doing wrong?
    thanks,
    tacbanon
  5. #45
    Post the whole code.
  6. #46
    Jun 2011
    Philippines
    Hi, here is the code...
    ' Name        : Coin_Internet_CDC.pbp
    ' Assembler   : PM or MPASM
    ' Target PIC  : PIC18F4550
    ' Hardware    : Easypic6 Experimenter Board
    ' Oscillator  : 4MHz external crystal (only???)
    ' Thanks      :  To Henrik, and other PBP experts
    ' Description : PICBASIC PRO program to show virtual serial comm. Working
    asm
       __CONFIG    _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        endasm
    DEFINE    OSC 48
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    PAUSE 100
    Include    "cdc_desc.bas"    ' Include the HID descriptors
    Buffer    VAR BYTE[10]
    Buffer2    VAR BYTE[10]
    Cnt       VAR BYTE
    i    var byte
    INTCON2.7 = 0        ' Enable PORTB pull-ups
    TRISB = 110000          ' Enable all buttons
    ADCON1 = 15               ' Set all I/Os to Digital
    CMCON = 7                 ' Disable Comparators
    Cnt = 3
    TRISA.4 = 1 ' RA4/T0CKI = input to TMR0 counter
    TRISA.0 = 0 ' RA0 = output for LED
    CMCON = 7   ' All digital
    ADCON1 = 001111      ' A/D converter off
    'If you prefer, then increment on low-to-high transitions
    T0CON   = 111000
    USBInit                   ' Initialize USART
    ' Main Program Loop
    Loop1:
    Buffer2[0] = 99
    Buffer2[1] =13
     'goto Loop1
    Loop2:
        USBService
        USBService
        WEND           ' on RA4/T0CKI
        pause 5
        USBService
        buffer[0] = 49
        Buffer[1] = 13
        'PAUSE 30
        goto Loop1
    regards,
    tacbanon
  7. #47
    I see missing % on these
    ADCON1 = 001111
    T0CON = 111000
    And each one should have 8 bits.
    Go back and look at post #19 of this thread.
  8. #48
    Jun 2011
    Philippines
    ' Name        : Coin_Internet_CDC.pbp' Compiler    : PICBASIC PRO Compiler 2.6
    asm
        endasm
    DEFINE    OSC 48
    DEFINE LCD_DBIT 0
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    PAUSE 100
    Buffer    VAR BYTE[10]
    Cnt       VAR BYTE
    b0   var byte
    B1   VAR BYTE   ' Working buffer 1 for button command
    sel   VAR BYTE   ' Working buffer 2 for button command
    B3   VAR BYTE   ' Working buffer 3 for button command
    i    var byte
    Clear        ' Clear buffers
    Cnt = 5
    i = 0
    T0CON   = %11111000
    ' Main Program Loop
    Loop1:
    'gosub usbtx
    'goto Loop1
    Loop2:
        USBService
        USBService
        WEND           ' on RA4/T0CKI
        pause 5
        USBService
        buffer[0] = 49
        Buffer[1] = 13
        'PAUSE 30
        goto Loop1
    Hi mackrackit, the above code works. Now what I'm trying to do is add a ntoher line of code to send "c" in the main loop but I can not seem to make it work.
    asm   __CONFIG    _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        endasm
    DEFINE    OSC 48
    DEFINE LCD_DBIT 0
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    PAUSE 100
    Buffer    VAR BYTE[10]
    Cnt       VAR BYTE
    b0   var byte
    i    var byte
    Cnt = 5
    i = 0
    T0CON   = %11111000
    ' Main Program Loop
    Loop1:
    gosub usbtx   ' transmit character c to pc
    Loop2:
        USBService
        USBService
        WEND           ' on RA4/T0CKI
        pause 5
        USBService
        buffer[0] = 49
        Buffer[1] = 13
        'PAUSE 30
        goto Loop1
    usbtx:
    USBService
    Buffer2[0] = 99
    Buffer2[1] = 13
    USBOut 3, Buffer2, cnt,usbtx
    The above code I use to attempt sending to pc...BTW I dont know what happened (T0CON = %11111000 and ADCON1 = %00001111) to the bits (but I think I did not alter it).
    thanks,
    tacbanon
  9. #49
    Does the Loop2 part still work in the code with the usbtx sub routine? It looks to me like it should work. Or maybe it is too long between USBservices.
    If that is the case include the routine to service the USB in the background like the example gave for testing.
  10. #50
    Jun 2011
    Philippines
    Hi, yes Loop2 still works(i increments), but I wonder why usbtx does not sends the "c" character to pc?
    regards,
    tacbanon
  11. #51
    Give this a shot. It works here.
    INCLUDE "cdc_desc.bas"
    INCLUDE "USB_ASM_Service.pbp"    ' Base Interrupt System
    LED       VAR PORTB.0
    Buffer    VAR BYTE[10]
    Cnt       VAR BYTE
    i    var byte
    Cnt = 5
    i = 0
    T0CON   = 111000
    LOW LED
    Loop1:
    Loop2:
    WEND           ' on RA4/T0CKI
    pause 5
    PORTA.2 = 1    ' LED on to indicate transition seen     LED PORTA.2
    buffer[0] = 49
    Buffer[1] = 13
    USBOut 3, Buffer, 2,Loop2
    LOW LED   ' LED off
    goto Loop1
    usbtx:
    TOGGLE LED
    Buffer2[0] = 99
    Buffer2[1] = 13
    USBOut 3, Buffer2,2,usbtx
  12. #52
    Jun 2011
    Philippines
    Hi, thanks for the time. I run your code...but the character "c" appears only when a pulse is detected in my setup. Hmm it should be running as expected...
    regards,
    tacbanon
  13. #53
    That is what I thought you wanted?
    If you want it to send "C" continuously
      GOSUB usbtx
      PAUSE 100
    WEND           ' on RA4/T0CKI
  14. #54
    Jun 2011
    Philippines
    Hi, sorry if was not making clear..it's working now. acctually the reason I need to send "c" is to identify if the usb device is connected to the my pc application. My next step is to incorporate rtc and sdcards for record keeping. I will post my code later... thanks mackrackit.
    regards,
    tacbanon
  15. #55
    glad I could help.
  16. #56
    Jun 2011
    Philippines
    Hi, sorry for the delay. I managed to send and display the content of the rtc to communication terminal using CDC.
    Next I tried to incorporate the SDcard using macrackit's codes. As I understood the code, once powered it should write a filename(timestamp) to sdcard. But When I checked the sdcard there was none.
    This is the code...
    asm    ;_PLLDIV_2_1L         EQU  H'F9'    ; Divide by 2 (8 MHz oscillator input)
       ; __CONFIG    _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        ;__CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        ;__CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
                                ;              ;                      ; USB clock source comes from the 96 MHz PLL divided by 2
                                ;              ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
                                ; No prescale (4 MHz oscillator input drives PLL directly)
        ;__CONFIG    _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H   '2
                                ;                  ;               ; Oscillator Switchover mode disabled
                                ;                  ; Fail-Safe Clock Monitor disabled
                                ; XT oscillator, PLL enabled, XT used by USB
        endasm
    DEFINE    OSC 48
    DEFINE LCD_DBIT 0
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    'RTC pins on 4550
    'SDA	Var	PORTB.0
    'SCL	Var	PORTB.1
        SD_WE        VAR    PORTA.4    ' SD card write protect
        SD_WE_TRIS   VAR    TRISA.4    ' SD card write protect direction
        SDI          VAR    PORTA.5    ' SPI data in SD #7
        SDI_TRIS     VAR    TRISA.5    ' SPI data in direction
        SCL          VAR    PORTA.3    ' SPI clock  SD #5
        SCL_TRIS     VAR    TRISA.3    ' SPI clock direction
        SD_CS        VAR    PORTC.2    ' SD card chip select SD #1
        SD_CS_TRIS   VAR    TRISC.2    ' SD card chip select direction
        SD_CD        VAR    PORTC.0    ' SD card detect
        SD_CD_TRIS   VAR    TRISC.0    ' SD card detect direction
        SDO          VAR    PORTC.1    ' SPI data out   SD #2
        SDO_TRIS     VAR    TRISC.1    ' SPI data out direction
    INCLUDE "SDFS.PBP"
    SDC_UseHardSPI = FALSE    ' Use hardware SSP port for SPI.
    '########################################################################################3
        INCLUDE "DT_INTS-18.bas"
        INCLUDE "ReEnterPBP-18.bas"
            INT_Handler   INT_INT,  _CNT_PLUS,   PBP,  yes
            INT_Handler   USB_INT,  _SERVICE_USB,  ASM,  yes
    'START USB AND INTERRUPTS
        PAUSE 100           'TIME TO SETTLE
        USBINIT             'INITIALIZE USB
        USBSERVICE          'SERVICE USB
        UIE = $7F           'ENABLE USB INTERRUPTS
        UEIE = $9F          'ENABLE USB ERROR INTERRUPTS
        PAUSE 500           'MORE TIME
        USBINIT
        USBSERVICE
        @   INT_ENABLE  USB_INT
     ADCON1 = %00001110
     LED      VAR PORTA.2
     TEXT_TIME VAR BYTE[6]
     TEXT_DATE VAR BYTE[6]
     CRON VAR     BYTE[11]
     CRON_D VAR   BYTE[11]
     TEXT_NO_CARD VAR BYTE[9]
     MAC_FileName VAR BYTE[11]
     T_BUFFER   VAR BYTE[8]
     T_ONES   VAR    BYTE
     T_TENS   VAR    BYTE
     T_HUNS   VAR    BYTE
     B0       VAR  BYTE
     B1       VAR  BYTE
     CNT      VAR  WORD
     CIU VAR     BYTE 'CARD IN USE
     'RTC DEFINES
        DS_SCL      VAR     PORTB.1    'CLOCK
        DS_SDA      VAR     PORTB.2    'DATA
        RTC CON     %11010000
        SEC_REG CON $00
        CONT_REG CON $0E
        CNTRL CON %00000000
    'RTC VARS
        sec VAR BYTE: mins VAR BYTE: hr VAR BYTE: day VAR BYTE
        date VAR BYTE: mon VAR BYTE: yr VAR BYTE
    'RTC DEC VARS
         SEC_O VAR BYTE: SEC_T VAR BYTE:
         MIN_O VAR BYTE: MIN_T VAR BYTE
         HR_O VAR BYTE:  HR_T VAR BYTE:
         MON_O VAR BYTE: MON_T VAR BYTE
         DATE_O VAR BYTE: DATE_T VAR BYTE:
         YR_O VAR BYTE: YR_T VAR BYTE
    'SD CARD FILE
         FILE_seconds VAR BYTE: FILE_minutes VAR BYTE: FILE_hours VAR BYTE
         FILE_day VAR BYTE: FILE_month VAR BYTE: FILE_year VAR BYTE
    'SETS FILE NAME TO THE TIME BOARD IS POWERED
        GOSUB READ_RTC
        MAC_FileName[0] = $30+HR_T
        MAC_FileName[1] = $30+HR_O
        MAC_FileName[2] = $30+MIN_T
        MAC_FileName[3] = $30+MIN_O
        MAC_FileName[4] = $30+SEC_T
        MAC_FileName[5] = $30+SEC_O
        MAC_FileName[6] = " "
        MAC_FileName[7] = " "
        MAC_FileName[8] = "T"
        MAC_FileName[9] = "X"
        MAC_FileName[10] = "T"
        FOR B0 = 0 TO 5
         LOOKUP B0,[" TIME "],B1
         TEXT_TIME(B0) = B1
        NEXT B0
        FOR B0 = 0 TO 5
         LOOKUP B0,[" DATE "],B1
         TEXT_DATE(B0) = B1
        NEXT B0
        FOR B0 = 0 TO 9
        LOOKUP B0,[" NO CARD",$d,$a],B1
        TEXT_NO_CARD(B0) = B1
        NEXT B0
    CMCON = %00000111                   ' Comparators = off
    ADCON1 = %00001111      ' A/D converter off
    ' Initialize LCD
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250
    Goto mainloop		' Skip over subroutines
    'ISRs
        CNT_PLUS:
             IF CIU = 1 THEN
             PWM LED,75,250
             IF (SD_WE = 0) AND (SD_CD = 0)  THEN
             TOGGLE LED
             LOW LED
             CNT = CNT + 1
        @ INT_RETURN
    ' Subroutine to read time from RTC
    READ_RTC:
        I2CREAD DS_SDA, DS_SCL, RTC, SEC_REG, [sec,mins,hr,day,date,mon,yr]
        SEC_T = sec & $70
        SEC_T = SEC_T>>4
        SEC_O = sec & $0F
        MIN_T = mins & $70
        MIN_T = MIN_T>>4
        MIN_O = MINs & $0F
        HR_T = hr & $70
        HR_T = HR_T>>4
        HR_O = hr & $0F
        MON_T = mon & $70
        MON_T = MON_T>>4
        MON_O = mon & $0F
        DATE_T = date & $70
        DATE_T = DATE_T>>4
        DATE_O = date & $0F
        YR_T = yr & $70
        YR_T = YR_T>>4
        YR_O = yr & $0F
        CRON[0] = " "
        CRON[1] = $30+HR_T
        CRON[2] = $30+HR_O
        CRON[3] = ":"
        CRON[4] = $30+MIN_T
        CRON[5] = $30+MIN_O
        CRON[6] = ":"
        CRON[7] = $30+SEC_T
        CRON[8] = $30+SEC_O
        CRON[9] = $d
        CRON[10] = $a
        CRON_D[0] = " "
        CRON_D[1] = $30+MON_T
        CRON_D[2] = $30+MON_O
        CRON_D[3] = "/"
        CRON_D[4] = $30+DATE_T
        CRON_D[5] = $30+DATE_O
        CRON_D[6] = "/"
        CRON_D[7] = $30+YR_T
        CRON_D[8] = $30+YR_O
        CRON_D[9] = $d
        CRON_D[10] = $a
        FILE_seconds = (SEC_T*10)+SEC_O
        FILE_minutes = (MIN_T*10)+MIN_O
        FILE_hours = (HR_T*10)+HR_O
        FILE_day = (DATE_T*10)+DATE_O
        FILE_month = (MON_T*10)+MON_O
        FILE_year = (YR_T*10)+YR_O
    mainloop:
    	Gosub READ_RTC		' Read the time from the RTC
            ' Display time on LCD
    	Lcdout $fe, 128,"Date:", CRON_D[1],CRON_D[2],CRON_D[3],CRON_D[4],CRON_D[5],CRON_D[6],CRON_D[7],CRON_D[8]
    	Lcdout $fe, $c0, "Time:", CRON[1], CRON[2],CRON[3],CRON[4],CRON[5],CRON[6],CRON[7],CRON[8]
    	Pause 500
        GOSUB USB_DISPLAY
    	Goto mainloop
        USB_DISPLAY:
        USBOUT 3, TEXT_TIME, 6, mainloop
        PAUSE 1
        USBOUT 3, CRON, 11, mainloop
        PAUSE 1
        USBOUT 3, TEXT_DATE, 6, mainloop
        PAUSE 1
        USBOUT 3, CRON_D, 11, mainloop
        PAUSE 1
    @ INT_RETURN
        SERVICE_USB:
            USBSERVICE
        @   INT_RETURN
    'SD CARD ROUTINES
        SD_WRITE:
        CIU = 1
        SDINIT:
        GOSUB FSInit
        IF (FAT_error != 0) THEN STOP
        GOSUB FINDfirst     ' Find first file on card
        WHILE (FAT_error = 0)
            GOSUB FINDnext  ' Find next file on card
        WEND
        SDFILENAME:
        FAT_FileName[0] = MAC_FileName[0]
        FAT_FileName[1] = MAC_FileName[1]
        FAT_FileName[2] = MAC_FileName[2]
        FAT_FileName[3] = MAC_FileName[3]
        FAT_FileName[4] = MAC_FileName[4]
        FAT_FileName[5] = MAC_FileName[5]
        FAT_FileName[6] = MAC_FileName[6]
        FAT_FileName[7] = MAC_FileName[7]
        FAT_FileName[8] = MAC_FileName[8]
        FAT_FileName[9] = MAC_FileName[9]
        FAT_FileName[10] = MAC_FileName[10]
        FAT_seconds = FILE_seconds
        FAT_minutes = FILE_minutes
        FAT_hours = FILE_hours
        FAT_day = FILE_day
        FAT_month = FILE_month
        FAT_year = FILE_year+20
        SDOPEN_W:
        FAT_mode = "A"      ' Write mode APPEND
        GOSUB FSfopen   ' Open file pointed to by Byte array FAT_FileName
        IF (FAT_error = 10) THEN STOP
        SD_WRITE_FILE:
        ' Write to file
        FAT_src[0] = "T"
        FAT_src[1] = "I"
        FAT_src[2] = "M"
        FAT_src[3] = "E"
        FAT_src[4] = $d
        FAT_src[5] = $a
        FAT_src[6] = $30+HR_T
        FAT_src[7] = $30+HR_O
        FAT_src[8] = ":"
        FAT_src[9] = $30+MIN_T
        FAT_src[10] = $30+MIN_O
        FAT_src[11] = ":"
        FAT_src[12] = $30+SEC_T
        FAT_src[13] = $30+SEC_O
        FAT_src[14] = $d
        FAT_src[15] = $a
        FAT_src[16] = "D"
        FAT_src[17] = "A"
        FAT_src[18] = "T"
        FAT_src[19] = "E"
        FAT_src[20] = $d
        FAT_src[21] = $a
        FAT_src[22] = $30+MON_T
        FAT_src[23] = $30+MON_O
        FAT_src[24] = ":"
        FAT_src[25] = $30+DATE_T
        FAT_src[26] = $30+DATE_O
        FAT_src[27] = ":"
        FAT_src[28] = $30+YR_T
        FAT_src[29] = $30+YR_O
        FAT_src[30] = $d
        FAT_src[31] = $a
        FAT_src[32] = " "
        FAT_src[33] = $30+T_HUNS
        FAT_src[34] = $30+T_TENS
        FAT_src[35] = $30+T_ONES
        FAT_src[36] = " "
        FAT_src[37] = "F"
        FAT_src[38] = $d
        FAT_src[39] = $a
        FAT_src[40] = $d
        FAT_src[41] = $a
        FAT_count = 42
        GOSUB FSfwrite
        SDCLOSE:
        ' Close file
        GOSUB FSfclose
        PAUSE 5000
        CIU = 0
        GOTO mainloop
    I'm using Pic4550, 4Mhz crystal, PBP2.60. Can you tell me what I'm doing wrong in my setup?
    thanks in advance,
    tacbanon
  17. #57
    Jun 2011
    Philippines
    Okay I missed this line of code in the main loop "GOTO SD_WRITE".
    The modified mainloop..
    mainloop:
        Pause 500
        GOSUB USB_DISPLAY
        GOTO SD_WRITE
        PWM LED,25,250
        USBOUT 3, TEXT_NO_CARD, 10, mainloop
        PAUSE 500
    Goto mainloop
    But this time even the rtc output is not displaying in the communication terminal and freezed on the lcd as well...I'm lost with the sdcard code part.
    tacbanon
  18. #58
    'SD CARD ROUTINES
        SD_WRITE:
        CIU = 1
        SDINIT:
        GOSUB FSInit
    Create a BLINK routine to blink an LED.
    Change the above THEN STOP to THEN BLINK.
    We need to see if you are getting an error. Better yet, send the error to a display to see what it is.
  19. #59
    Jun 2011
    Philippines
    Hi added the following code to SDcard routines as suggested..
    'SD CARD ROUTINES
        SD_WRITE:
        CIU = 1
        SDINIT:
        GOSUB FSInit
        IF (FAT_error != 0) THEN BLINK
        WEND
        BLINK:
        Toggle LED1
        Lcdout $fe, 1
        Lcdout $fe, 128,"I Blink"
    My observation, when powered Rtc displays infos in the lcd after a couple second it goes to the BLINK routine and toggled the LED1 and displays "Blink". But after 6 seconds the lcd goes blank. BTW from the start of the program I can not connect to communication port its says "Serial port not available"
    This my SDCARD Connection:
    SCLK -> PortA.3
    MOSI -> PortA.5
    SD_CS -> PortC.2
    MISO -> PortC.1
    regards,
    tacbanon
  20. #60
    Do you have a data sheet for the SD card module?
  21. #61
    Jun 2011
    Philippines
    Hi, I don't have data sheet. I tried to search on www.lcsoft.net but there was none. But I was able to test this module successfully on a separate program using the following code.
    asm
    endasm
    DEFINE    OSC 48
        Include "SDFS.PBP"
        ADCON1 = 15        ' All I/O pins digital    Pause 100
        Gosub FSInit
        Wend
        FAT_seconds = 5
        FAT_minutes = 30
        FAT_hours = 8
        FAT_day = 1
        FAT_month = 1
        FAT_year = 28
    ' Write to file
        FAT_src[0] = "P"
        FAT_src[1] = "r"
        FAT_src[2] = "0"
        FAT_src[3] = "t"
        FAT_src[4] = "o"
        FAT_src[5] = "t"
        FAT_src[6] = "y"
        FAT_src[7] = "p"
        FAT_src[8] = "e"
        FAT_count = 9
        Gosub FSfwrite
    ' Close file
        Gosub FSfclose
        Gosub FSfread
            Gosub FSfread
        Wend
    regards,
    tacbanon
  22. #62
    Jun 2011
    Philippines
    Hi, I'm trying to test the RTC module on pic16F877A, according to the pins assignment SDA is on RC4 and SCL on RC3.
    'RTC pins on 4550
    SDA    Var    PORTB.0
    SCL    Var    PORTB.1
    'The above code works
    'RTC pins on 877a
    SDA    Var    PORTC.4
    SCL    Var    PORTC.3
    But this does not
    What do you think I'm missing?
    this is the code I'm using
    DEFINE  OSC 20CLEAR
    ;----[LCD definitions]------------------------------------------------------
    DEFINE LCD_DBIT 0
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    'RTC pins on 877a
    SDA	Var	PORTC.4
    SCL	Var	PORTC.3
    ' Allocate variables
    RTCYear	Var	Byte
    RTCMonth Var Byte
    RTCDate	Var	Byte
    RTCDay	Var	Byte
    RTCHour	Var	Byte
    RTCMin	Var	Byte
    RTCSec	Var	Byte
    RTCCtrl Var	Byte
    TRISC= %11111111
    ;DB0 var byte[8]
    ' Initialize LCD
    ' Set initial time
    	RTCYear = $10
    	RTCMonth = $03
    	RTCDate = $23
    	RTCDay = $02
    	RTCHour = $19
    	RTCMin = $35
    	RTCSec = 0
    	RTCCtrl = 0
    'Gosub set		' Set the time
    ' Subroutine to write time to RTC
    set:
    	I2CWrite SDA,SCL,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCDay,RTCDate,RTCMonth,RTCYear,RTCCtrl]
    gettime:
    	I2CRead SDA,SCL,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCDay,RTCDate,RTCMonth,RTCYear,RTCCtrl]
    mainloop:
    	Gosub gettime		' Read the time from the RTC
        Lcdout $fe, 128,"Date:",  hex2 RTCDate, "/",hex2 RTCMonth, "/" , hex2 RTCYear
    	Lcdout $fe, $c0, "Time:", hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec
    	Pause 500
    	Goto mainloop
    regards,
    tacbanon
  23. #63
    My guess is to try it on pins that are not Schmitt triggered.
  24. #64
    Jun 2011
    Philippines
    Hi mackrackit, I was able to run the RTC on PortB.0(SCL) and PortB.1(SDA). I'm still confused. I tried PortA ports that has TTL but did not work. and I have read other thread that they were able to run their program using Pic16F877A to read RTC module on PORTC.1 and PORTC.0 (Post# 1 http://www.picbasic.co.uk/forum/showthread.php?t=12671) can you help me point out how it works? I'm amazed that my lcd is also using PortB.0 and PortB.1 at the same time with the RTC required pins. BTW now I'm on Pic16F877A, does this mean that my sdcard module will not work on this chip?
    thanks for the patients,
    tacbanon
  25. #65
    Jun 2011
    Philippines
    oops sorry for the typos(patients) what I meant is patience
  26. #66
    Well, I am not sure why your code is not working on PORTC.3 and PORTC.4. I just tried it here and it is running. The code I used is below.
    Port A. Did you turn the analog off? ADC
    You have to use an 18Fxx with SDFS as LONG variables are needed.
    ' 16F877A RTC
    ' 10/30/2011
        __config _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    LED     VAR PORTB.5
    TX      VAR PORTD.1  ' DATA SEND PIN
    BAUD    CON 18030	' 18030 = 600 BAUD
    'RTC pins on 877a
    SDA	Var	PORTC.4
    SCL	Var	PORTC.3
    RTCYear	Var	Byte
    RTCMonth Var Byte
    RTCDate	Var	Byte
    RTCDay	Var	Byte
    RTCHour	Var	Byte
    RTCMin	Var	Byte
    RTCSec	Var	Byte
    RTCCtrl Var	Byte
    TRISC= %11111111
    CMCON = %00000111
    ' Set initial time
    	RTCYear = $10
    	RTCMonth = $03
    	RTCDate = $23
    	RTCDay = $02
    	RTCHour = $19
    	RTCMin = $35
    	RTCSec = 0
    	RTCCtrl = 0
    set:
    gettime:
    mainloop:
        TOGGLE LED
        SEROUT2 TX, BAUD,["Date:",  hex2 RTCDate, "/",hex2 RTCMonth, "/" , hex2 RTCYear,13]
        SEROUT2 TX, BAUD,["Time:", hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec,13]
    '    Lcdout $fe, 128,"Date:",  hex2 RTCDate, "/",hex2 RTCMonth, "/" , hex2 RTCYear
    '	Lcdout $fe, $c0, "Time:", hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec
    	Pause 500
    	GOTO mainloop
  27. #67
    Jun 2011
    Philippines
    okay I think I know whats the problem, I found out that one my file I'm working has this code ADCON1 = %00001111 ' A/D converter off...which is different from the file I post. So this means I have to work on 18F.
    thanks again,
    tacbanon
  28. #68
    Jun 2011
    Philippines
    Hi, in the PIC pins and registers for SD/MMC card
    PortB.0. PortB.1,PortB.3 and PortB.4 is already in use by a keypad, can I move it to PortD instead?
    Like this...
    SDI        Var    PORTD.0    ' SPI data in
    SDI_TRIS    Var    TRISD.0    ' SPI data in direction
    SCL        Var    PORTD.1    ' SPI clock
    SCL_TRIS    Var    TRISD.1    ' SPI clock direction
    SD_CS        Var    PORTD.3    ' SD card chip select
    SD_CS_TRIS    Var    TRISD.3    ' SD card chip select direction
    SD_CD        Var    PORTD.4    ' SD card detect
    SD_CD_TRIS    Var    TRISD.4    ' SD card detect direction
    tacbanon
  29. #69
    That should not be a problem.
  30. #70
    Jun 2011
    Philippines
    Hi, before I change to my desired pins, I made a test(using the original code)...but gives me this "Init: 6 1 255". I don't understand the code I used for testing works before.
    Do you know what's causing it?
    regards,
    tacbanon
  31. #71
    Open the SDFS file and look at the CE_xxx .
    Your card did not initialize. Could be lots of things from a loose wire to a bad card. Bad as in file format corrupt to just wore out.
    If the connections are good see if the card can be read in a PC, check the format.
  32. #72
    Jun 2011
    Philippines
    Oh my, I think I broke my sdcard module. I double checked the wires I'm using and I reconnect and disconnect them to the devboard more than 10 times still the same result. The SDCard is okay (its in FAT format). I remembered I connect it to PortB earlier the same port where the keypad is also connected. this could have ruin the module...
  33. #73
    Jun 2011
    Philippines
    For the mean time while I'm waiting for my new sdcard module(will come within a week). I will try to study on eeprom(Pic18F4550's internal). Thank you again to this wonderful forum(people) and to macrackit for the precious time... until nextime.
    regards,
    tacbanon
  34. #74
    Jun 2011
    Philippines
    Hi, I've been playing some time with READ and Write command on the internal eeprom, I'm having trouble updating DATA @6,5,"54321". Probably I'm doing it the hard way. Can you help me out what I'm doing wrong?
    'My Tested Prototype with Pic18F4550 and EEPROMInclude "modedefs.bas"
    INCLUDE "C:\PBP\USB18\EE_Vars.pbp"           ; Include the EE_var routines
    asm
    endasm
    DEFINE    OSC 48
    INTCON2.7 = 0
    'EEprom data
    'U1    VAR WORD  :  @  EE_var  _U1, WORD, 9999 ' for later use
    DATA @0,5,"12345"
    DATA @6,5,"54321"
    DATA @13,5,"14332"
    DATA @19,5,"24432"
    DATA @25,5,"85921"
    TRISA = %00000000
    TRISD = %00000000
    PORTD = %00000000
    TRISB = %11110000    ' Set Keypad I/O
    PORTB = 0             ' Set columns LOW
    PortA = 0
    myvarkey    var byte
    ByteA        var Byte[6]
    B0          var byte[5]
    cnt         var byte
    x           var byte
    cnt = 0
    asciichar var byte
    address var byte
        '    ---------------------------------[Program Start]----------------------------------------------
    serout2 PortD.5,T9600,[$1B,$63,$30]
    pause 200
    serout2 PortD.5,84,[$1B,$45,"EEPROM"]
    serout2 PortD.5,84,[$D,"Studies"]
    serout2 PortD.5,84,[$1B,$63,$30]
    pause 2000
    Serout2 PortD.5,84, [$1B,$45]
    @ READKEYPAD _myvarkey
    lookup myvarkey,[0,"123A456B789C*0#D"],Key
    Serout2 PortD.5,84, [$1B,$45,"Key = ",Key]
    if Key = "#"  and cnt < 6 then
         if ByteA[0]="1" and ByteA[1]="9" then   ' wait 19 is pressed before updating
            Serout2 PortD.5,84, [$D, "Special Key"]
            pause 20
            serout2 PortD.5,84,[$D,str ByteA\cnt]
            READ 6,x
             for address=6 to x+6
                Write address+1, ByteA[address]
             next address
            cnt=0
         ByteA[cnt]=Key
         Serout2 PortD.5,84, [$D, ">" , ByteA[cnt]]
         cnt=cnt+1
    Endif
    if cnt > 5 then
    Serout2 PortD.5,84, [$D, "5Digits only"]
    cnt = 0
    ENdif
    if Key = "A" then
    READ 0,x
    serout2 PortD.5,84,[$D,Dec x," "]
    for address=0 to x
        READ address,asciichar
        serout2 PortD.5,84,[$D,asciichar]
    next address
    cnt = 0
    if Key = "B" then
    READ 6,x
    for address=0+6 to x+6
    next address
    cnt = 0
    if Key = "C" then
    READ 13,x
    for address=0+13 to x+13
    next address
    cnt = 0
    if Key = "D" then
    READ 19,x
    for address=0+19 to x +19
    next address
    cnt = 0
    if Key = "*" then
    READ 25,x
    for address=0+25 to x +25
    next address
    cnt = 0
    But updating Data @0 ,"12345" was not a problem, I'm stuck passed @0 location.
    regards,
    tacbanon
  35. #75
    This:
    DATA @0,"12345"
    DATA @6,"54321"
    produces this when the EEPROM is read back
    31 32 33 34 35 00 35 34 33 32 31 00 FF FF
    Is that what you want?
    Did you find out what went bad with the SD card module? You can always use the SD card socket without all the other stuff on the module, it is easy if the MCU is running ~3 volts.
  36. #76
    Jun 2011
    Philippines
    DATA @0,"12345"
    DATA @6,"54321"
    Sorry If I was not being clear... how can I rewrite them and read back as in the format of "56988" or "65431".
    Before overwriting DATA @6,"54321" I can read back as "54321". But after updating it gives me like Hex numbers.
    I don't know exactly what happened to sdcard it just dont work as before. But I will try to test it again later.
    thanks,
    tacbanon
  37. #77
    Jun 2011
    Philippines
    Hi mackrackit, sorry if was not making clear. I want to read back from eeprom in the format of example "12345" or "65432" and I can do this uisng the following code.
    if Key = "A" then
    READ 0,x
    for address=0 to x
    next address
    cnt = 0
    And I noticed that if I rewrite the value of DATA @6,5,"54321" by entering "19325" and read it back I get "QZu" not "19325"..how do I resolve this?
    I will try to test the sdcard tonight, hope something comes up....
    thanks,
    tacbanon
  38. #78
    Jun 2011
    Philippines
    Hi I finally got my eeporm problem solved..I figured that it needs 2 location space in between.
    DATA @0,5,"12345"
    DATA @7,5,"54321"
    DATA @14,5,"14332"
    DATA @21,5,"24432"
    DATA @28,5,"85921"
    works great...
    BTW just want to ask if there is a possible to press a key that consist of several characters, for example if I pressed key 1 in successive I can get a character 'a','b','c'. similar to a cellphone keypad.
    regards,
    tacbanon
  39. #79
    Jun 2011
    Philippines
    I found one link http://www.picbasic.co.uk/forum/showthread.php?t=11209 but not sure how to to do it...but I will try..
    regards,
    tacbanon
  40. #80
    Melanie's example is good, but the methods talked about at the start of this thread might be better.
    Timer/Counter from TIMER0.
    It should work well with all of the other stuff going on.
