Why this PBP code will blink PortB LED's but not the one on PortC?
Results 1 to 11 of 11
    Aug 2010
    Maryland, USA
    Default Re: Why this PBP code will blink PortB LED's but not the one on PortC?
    Really? I never thought about pbp doesn't support slave mode for I2C. This certiainly makes me re think so mtuff I am currently working on. Hmmmm shame.
    -Bert
    When using I2CREAD/WRITE the PIC is "in control" of the line, ie it supplies the clock and is therfor the master (same as with SHIFTIN/OUT). Because of this IC2READ/WRITE won't work for a slave type device, however the MSSP module setup in I2C mode will, you just have to "drive it manually".
    Aug 2010
    Maryland, USA
    Thanks henrik, just in time to fix what I was doing. I think I did some bit banging slave stuff a few (>5) years ago in ASM, no desire to repeat that!! Off to make sure chip selection supports slave mode I2C.
    -Bert
