pic controller doesn't work properly
Results 1 to 6 of 6
    Default pic controller doesn't work properly
    my PIC 18f452 doesn't simulate program in hardware it will blink the LED when i touch my hand to one of the pin of OSI1 & OSI0 (oscillator pins)..the progrram is simulated in proteous7.7..plz solved my problem..
    Default Re: pic controller doesn't work properly
    Hmm, OK, I solved it!
    Nov 2008
    Can you post the Code. Also What hardware are you using?
    Bombay, India
    nightrider
    Most likely source of your problem is you missed decoupling your circuit with 0.1uF capacitors. Second likely candidate is a noisy/bad switch mode power supply that you power your circuit with.
    ;Test Program
    LIST P=PIC18F452, F=INHX32, N=0, ST=OFF, R=HEX
    #INCLUDE P18F452.INC
    CONFIG OSC=HS, OSCS=OFF
    CONFIG WDT=OFF
    CONFIG BOR = OFF
    ;CONFIG BORV=0, PWRT=OFF
    CONFIG PWRT=OFF
    CONFIG DEBUG=OFF, LVP=OFF, STVR=OFF
    ;Equates Section
    TRISB EQU H'0F93'
    PORTB EQU H'0F81'
    R1 EQU 0x07
    R2 EQU 0x08
    ORG 0000H
    CLRF TRISB
    MOVLW 0x55
    MOVWF PORTB
    L3 COMF PORTB,F
    CALL QDELAY
    BRA L3
    ;------------1/4 SECOND DELAY
    QDELAY
    MOVLW D'200'
    MOVWF R1
    D1 MOVLW D'250'
    MOVWF R2
    D2 NOP
    NOP
    DECF R2,F
    BNZ D
    DECF R1,F
    BNZ D1
    Code seems ok, but you don't need to redefine PORTB & TRISB... this is what the INCLUDE line does for you.
    You want to check MCLR pin, must be tied to Vdd.
    ALL VDD, ALL VSS pins MUST be connected.
    Check your crystal connection... and your capacitors around the crystal.
    Last thing, this is a Melabs PICBASIC forum here... with some tolerence & expertise for assembler
