decoding quadrature encoders
Results 1 to 40 of 94
    Default Re: decoding quadrature encoders
    Great job! The problem with the display routine is, again, that PBP doesn't handle math with negative numbers properly so the result of the Counter / 10 operation gets messed up when Counter is negative.
    You can probably make that snippet a bit more efficient, somelike like this perhaps:
    if enc_counter <> enc_counter_old then 'see if value has changed
    enc_counter_old = enc_counter 'move new value to old
    Counter = enc_counter
    Sign = Counter.15 ' Save sign
    Counter = ((ABS Counter) * 5) ' Degrees is now 0 to 900
    LCDOUT $FE, 1  ' Clear screen
    IF Sign THEN
      LCDOUT "-"    ' Print a minus sign if the value is negative
    LCDOUT SDEC Counter / 10, ".", SDEC Counter // 10   ' now print the value
    I must admit that I can't really follow the ASM code for the interrupt but since it's using Interrupt on change I think it "should" do x4 decoding so you "should" get 1440 counts per revoultion on a 360CPR encoder. I don't know why that's not happening. Hopefully someone else is able to help with that part.
    cbrun17's Avatar
    cbrun17 Guest
    Thank you Henrik.
    I couldn't have made it this far without you're help. The displayed number is perfect. As you said, the counts aren't making much sense. I'll continue to experiment with this to see if I can figure out how to get the correct resolution.
    Thanks again and kind regards....
    Chris
    you have some isr issues
    1.
    ; Not Necessary for Chips with >2k of Codespace
    ; movwf wsave
    ; swapf STATUS, W
    ; clrf STATUS
    ; movwf ssave
    ; movf PCLATH, W
    ; movwf psave
    ; Not Necessary for Chips with >2k of Codespace what ?
    yet at the end of your isr pclath and status are restored
    all isrs need to save and restore mcu status
    2.
    the chip you are using has more than 1 code pages ,your isr is located in page 0 ,
    pclath should be set accordingly
    USUAL
    ISR BEGIN
    movwf wsave
    swapf STATUS, W
    clrf STATUS
    movwf ssave
    movf PCLATH, W
    movwf psave
    CLRF PCLATH
    YOUR CODE
    3.
    a RE stream moving clockwise goes phase 1 - 2 - 3 - 4 -1 -2 .......
    where phase 1=00
    2=10
    3=11
    4=01
    your code
    ;check to see if encoder has moved
    movf _enc_old,W ;move enc_old to W
    movwf _enc_tmp ;put W to enc_tmp
    movf _enc_new,W ;move enc_new to W for XOR
    xorwf _enc_tmp,F ;XOR enc_tmp to detect encoder movement
    btfsc _enc_tmp,7 ;if bit is clear, encoder moved.
    goto Continue ;no movement exit isr
    say enc_old=01 ,enc_new=00 ; ie clockwise move
    your xor would yield 0b01000000
    and bit 7 is clear so no move is recorded , wrong it did move .it may also cause the 0 point to creep as direction
    changes occur
    the test should be is the result 0 not is bit7 0
    4. bank sel ?
    your isr forces bank0 the chip has more than one bank available
    all vars used in isr need to be assigned to bank 0
    ie enc_old VAR BYTE bank0 .
    etc
    5. enc_counter a word a non atomic entity
    any non atomic entity that can be changed in an isr and is used outside the isr needs to be handled
    correctly to prevent glitches caused by rollover/under of the low byte.
    best way is to use a buffered copy or that entity
    eg
    enc_counter VAR WORD bank0
    buffered_enc_counter VAR WORD
    gosub get_enc_count
    get_enc_count:
    intcon.3=0 ; rbc_int off
    buffered_enc_counter=enc_counter
    intcon.3=1 ; rbc_int on
    cbrun17's Avatar
    cbrun17 Guest
    Hi Richard,
    Thank you very much for the information. It's a little over my head at this point with regard to asm. I'm still very new to asm coding, but I'm going to try working through your suggestions and see what I can accomplish.
    Chris
    cbrun17's Avatar
    cbrun17 Guest
    Hi Richard,
    Here is what I've done so far. Since I'm just learning asm (and coding in general), I made the changes you suggested as I understand them (haven't tried to compile yet). The part I am still not too sure about is the reference to is testing bit7. Are you saying I should not be testing bit7 (btfsc _enc_old,7)? How do I reference this in the asm code?
    I've tried going through this step by step and it's starting to make a little sense. I guess until I've done this a few times, I'll have to ask some lame questions....
    Again, I really appreciate your input.
    'Read Quadrature Encoder and display value on LCD. for ****pic16f876****
    '************************ DEFINES HERE *************************************
    DEFINE OSC 20               ' set to 20mhz
    DEFINE LCD_DREG PORTA       ' Set Data Registers port
    DEFINE LCD_DBIT 0           ' Set starting data bit
    DEFINE LCD_RSREG PORTB      ' Set LCD RS Port
    DEFINE LCD_RSBIT 1          ' Set LCD RS Bit
    DEFINE LCD_EREG PORTB       ' Set LCD Enable Port
    DEFINE LCD_EBIT 2           ' Set LCD Enable Bit
    DEFINE LCD_BITS 4           ' Set LCD 4bit Mode
    DEFINE LCD_LINES 2          ' Set number of LCD Lines
    DEFINE LCD_COMMANDUS 2000   ' Set Command Delay time in uS
    DEFINE LCD_DATAUS 60        ' Set Data delay time in uS
    clear                       'clear out variables
    '*********************** CHIP REGISTER SETUP *******************************
    ADCON0 = 7              ' turn off analog porta, set to digital IO
    ADCON1 = 7              '
    CMCON =  7              ' Turn off Port A Comparator
    TRISA = 0               ' output ports
    TRISB = %11000001       ' set input and output ports
    TRISC = 0               ' output ports
    '************************ PROGRAM VARIABLES HERE ***************************
    symbol led = portc.2         ' status led
    symbol led2 = portc.0       ' status led2
    symbol lcdbkl = portc.7     ' lcd pannel backlight
    symbol sw1 = portb.0       ' encoder switch
    enc_old 	          VAR     BYTE
    enc_new 	          VAR     BYTE
    enc_tmp 	          VAR     BYTE
    enc_counter_old  	  VAR    WORD bank0
    enc_scaler 	  	  VAR    WORD bank0
    '*********************** ASSEMBLY INTERUPT VARIABLES ***********************
    wsave     VAR     byte $20 system
    wsave1    VAR     byte $a0 system  ' Necessary for devices with RAM in bank1
    wsave2    VAR     byte $120 system ' Necessary for devices with RAM in bank2
    wsave3    VAR     byte $1a0 system ' Necessary for devices with RAM in bank3
    ssave     VAR     byte bank0 system
    psave     VAR     byte bank0 system
        goto start			'skip over interupt handler
    '*********************** ASSEMBLY INTERUPT HANDLER *************************
    define  INTHAND myint
    Asm
    myint
    	; Save W, STATUS and PCLATH registers
    	; ****Changed from original isr initialization settings****
            ;movwf   wsave
            ;swapf   STATUS, W
            ;clrf    STATUS
            ;movwf   ssave
            ;movf    PCLATH, W
            ;movwf   psave
    ; Changed from original isr initialization settings
    	movwf wsave
     	swapf STATUS, W
     	clrf STATUS
     	movwf ssave
     	movf PCLATH, W
     	movwf psave
     	CLRF PCLATH
    	;====== BEGINNING OF THE ROTARY ENCODER CODE ========
    	;The Rotary Encoder is connected to PORTB
    	;The A signal of the encoder connected to the PIN portB.7
    	;The B signal of the encoder connected to the PIN portB.6
    	;The 4 variables used are declared in the PicBasic code.
    	;	enc_new VAR BYTE
    	;	enc_old VAR BYTE
    	;       enc_tmp VAR BYTE
    	;	enc_counter VAR WORD
    	   ;Read latest input from PORTB & put the value in _enc_new.
         	movf    PORTB,W
         	movwf  _enc_new
         	;Strip off all but the 2 MSBs in _enc_new.
         	movlw	0xc0    	     ;Create bit mask (bits 7 & 6). b'11000000' ?
         	andwf   _enc_new,F       ;Zero bits 5 thru 0.
            btfsc   _enc_tmp,7         ;if bit is clear, encoder moved.       ************Not sure what needs to happen here**************
         	;Determine the direction of the Rotary encoder.
         	rlf     _enc_old,F     	 ;left shift it into _enc_old to align bit 6 of
                                     ;_enc_old with bit 7 of _enc_new.
         	movf    _enc_new,W     	 ;Move the contents of _enc_new to W in order to XOR.
         	xorwf   _enc_old,F    	 ;XOR previous inputs (in _enc_old) with latest
                                     ;inputs (in W) to determine CW or CCW.
          	btfsc   _enc_old,7     	 ;Test bit 7 of result (in _enc_old).  Skip next line ************Not sure what needs to happen here**************
          	                         ;if it is 0 (direction is CCW).
         	goto    Up               ;Bit is 1 (direction is CW).  Go around Down
                                     ;and increment counter.
    Down
         	;Decrements _enc_counter because the rotary encoder moved CCW.
    	    ;Decrements _enc_counter (16 bit value), sets Z on exit.
            decf    _enc_counter,F      ; Decrement low byte
            incfsz  _enc_counter,W      ; Check for underflow
            incf    _enc_counter+1,F    ; Update
            decf    _enc_counter+1,F    ; Fixup
            movf    _enc_counter,W
            iorwf   _enc_counter+1,W    ; Set Z bit
    	    ;Add here code for the CCW LED if needed.
         	bsf     _led		    ;turn on led
         	goto    Continue  	    ;Branch around UP.
    Up
            ;Increments _enc_counter because the rotary encoder moved CW.
            ;Increments _enc_counter (16 bit value), sets Z on exit.
            incfsz  _enc_counter,W      ; Add one to low byte
            decf    _enc_counter+1,F    ; No carry (negates next step)
            incf    _enc_counter+1,F    ; Add one to high byte
            movwf   _enc_counter        ; Store updated low byte back.
            iorwf   _enc_counter+1,W    ; Set Z flag
    	   ;Add here code for the CW LED if needed.
    	   bsf     _led2		    ;turn on led
    Continue
         	;Assign the latest encoder inputs (in _enc_new) to _enc_old.
         	movf 	_enc_new,W
         	movwf   _enc_old
            ; Restore saved registers
            movf    psave, W
            movwf   PCLATH
            swapf   ssave, W
            movwf   STATUS
            swapf   wsave, F
            swapf   wsave, W
            bcf     INTCON, RBIF		  ; Clear the Interupt Flag
            RETFIE                 	  	  ; Return from interrupt
    endasm
    '************************* PROGRAM STARTS HERE *****************************
    START:              ' Main Program starts here
       LCDOUT $FE,1		'Init The LCD
          pause 500		    'wait for LCD to start
       LCDOUT $FE,1,"ENCODER"	    'display splash screen
       LCDOUT $FE,$C0," TEST "
         high lcdbkl                 ' turn on backlight
    '************************** SET DEFAULT SETTINGS HERE **********************
    pause 1000		    ' just wait a bit to read splash screen
    enc_counter = 0	' set default encoder value
    enc_counter_old = 0
            ' Initial display
        LCDOUT $FE,1,"ENCODER"  ' Initial display
        LCDOUT $FE,$C0, "00.00"
    INTCON = %10001000      ' Enable PortB Change Interupts
    '************************** TESTING ROUTINES HERE **************************
    test:
                if buffered_enc_counter <> enc_counter_old then 'see if value has changed
                   	'enc_counter_old = enc_counter 'move new value to old ******Removed this line and replaced with*******
                    gosub get_enc_count                                  '******this line******************************
     		 Counter = buffered_enc_counter
     	If Sign THEN Counter = -Counter ' Restore sign, value is now -900 to 900
     	   If NOT sign then
     		LCDOUT $FE,1, sdec Counter /10 , ".", sdec Counter // 10
     		LCDOUT $FE,1, "-", sdec -Counter /10 , ".", sdec -Counter // 10
                    low led		                        'turn off CCW led
                    low led2	                        'turn off CW led
    goto test
    get_enc_count:
    this should correct the quadrature decoding ,the big problem with this technique for quadrature decoding is that its is completely intolerant to noise.
    given that you encoder is optical I would expect noise problems would be minimal
            btfsc   STATUS,Z         ;if result is not zero, encoder moved.
    Hey guy's, Why not just use 2 external interrupt lines (int0 & int1) in high priority mode, and just increment or decrement a counter? I have used this approch for years on my mill and I haven't lost a count yet. I have attached a URL for the front end circuit I used. I have NO problem a tracking 1000 Rpm, 720 CPR encoder using LONG's.
    Here is the URL: http://electronicdesign.com/analog/s...ation-encoders
    I eliminated the caps and just use 10k resistors. Read the artical as it is informative.
    EN82fn
    Because INT0 and INT1 trips on EITHER the rising OR falling edge which means that you either get x1 decoding or that you need to reconfigure the interrupt edge every interrupt. The IOC feature handles that automatically since it interrupts on change - any change.
    The circuit in your link provides up/down count but still only x1 decoding, see the pink trace only pulses on the rising edge of the yellow trace, same thing for the green trace. It's effectively using only 25% of the encoders available resolution. A 720CPR encoder, when "properly" read will give you 2880 "pulses" per revolution.
    If that's enough resolution it's perfectly fine but in that case I probably wouldn't use interrupts to count the pulse. I'd have hardware timer/counters in the PIC count the pulses and periodically update the position register.
    cbrun17's Avatar
    cbrun17 Guest
    Hi Dave,
    I did see this article, however, as Henrik mentioned, the circuit described does not interpret quadrature encoding (grey code) to gain accurate angle measurement. I also looked at another solution using an LS7183 which does interpret the output to two separate clock signals (see datasheet here: http://www.lsicsi.com/pdfs/Data_Shee...083_LS7084.pdf), this looks promising if I can't successfully make my code work properly.
    I truly appreciate your suggestion.
    Chris
    cbrun17's Avatar
    cbrun17 Guest
    Thank you Richard. I will test this and let you know the results.
    Also, though the encoder is optical, I am going through a 74C14 hex Schmitt trigger with rc filtering to remove any stray noise. all cabling from the encoder is shielded. Monitoring the output results in clean square wave with fast rise and fall times.
    Chris
    cbrun17's Avatar
    cbrun17 Guest
    Hi Richard,
    The asm change you suggested worked like a charm. I now get the correct counts!
    Just had to make one other change that I hoped you could explain to me. Once I made the change to check the STATUS instead of _enc_tmp,7 bit, my counting was all backwards.
    By changing the direction test from "btfsc _enc_old,7" to "btfss _enc_old,7", the issue was resolved. So basically the bit value for _enc_old,7 is set rather than clear on cw.
    I can't express how grateful I am for all the help from both you and Henrik.
    Here is the working code. I hope others will find this useful.
    'Read Quadrature Encoder and display value on LCD in .25 increments. for pic16f876
     ADCON1 = 7 '
     CCP1CON = 0
     CCP2CON = 0
     TRISA = %00000000 ' output ports
     TRISB = %11000000 ' set input and output ports
     TRISC = %00100000 ' output ports
     portB.4 = 0
     portB.5 = 0
     symbol   ledUp     = portC.2 ' status led
     symbol   ledDown = portC.3 ' status led2
     symbol   lcdbkl     = portC.4 ' lcd pannel backlight
     symbol   sw1        = portC.5 ' encoder switch
     symbol   ledTest   = portC.6
     enc_old                VAR BYTE
     enc_new              VAR BYTE
     enc_tmp              VAR byte
     enc_counter         VAR word bank0
     enc_counter_old   VAR word bank0
     enc_scaler            VAR word
     enc_dir                VAR enc_old.bit7
     Counter               VAR word bank0
     enc_SIGN            VAR counter.bit15
     Sign                    VAR BIT
     Asm
    myint
     ;movwf wsave
     ;swapf STATUS, W
     ;clrf STATUS
     ;movwf ssave
     ;movf PCLATH, W
     ;movwf psave
     ;CLRF PCLATH
     ; enc_new VAR BYTE
     ; enc_old VAR BYTE
     ; enc_tmp VAR BYTE
     movf PORTB,W
     movwf _enc_new
        ;Check to see if encoder has moved
     rlf _enc_old,F ;left shift it into _enc_old to align bit 6 of _enc_old with bit 7 of _enc_new.
     goto Up ;Bit is 1 (direction is CW). Go around Down and increment counter.
    Down
     movf _enc_counter,W
     bsf _ledDown ;turn on led
    Up
     bsf _ledUp ;turn on led
    Continue
     movf _enc_new,W
     movwf _enc_old
     movf  psave, W
     movwf PCLATH
     swapf ssave, W
     movwf STATUS
     swapf wsave, F
     swapf wsave, W
     endasm
     lcdout $FE,$80,  "TEST ANGLE DISP " 'display splash screen
     LCDOUT $FE,$C0,  "Initializing... "
     pause 2000 ' just wait a bit to read splash screen
     lcdout $FE,1
     enc_counter_old = 0
     Counter = 0
     lcdout $FE,$80, "Measurement   "
     lcdout $FE,$C0,"TST ANGLE: "
     test:
       If portC.5 = 0 then clearall
            Counter = enc_counter '(enc_counter */ 250)/2
            Counter = ((ABS Counter) * 25) ' Degrees is now 0 to 900
    If not sign AND (-Counter > 0 or Counter < 0) then
        lcdout $FE,$C0,"TST ANGLE:", "-",sdec Counter /100 , ".", sdec Counter // 100, " "
        lcdout $FE,$C0,"TST ANGLE:", " ", sdec -Counter /100 , ".", sdec -Counter // 100, " "
     low ledUp 'turn off CCW led
     low ledDown 'turn off CW led
     goto test
     ClearAll:
        enc_counter = 0
        enc_counter_old = 0
        Counter = 0
        clear
        lcdout $FE,$C0,"TST ANGLE:", " 0.00 "
            high ledtest
            low ledtest
     goto test
    @INT_RETURN
    cbrun17's Avatar
    cbrun17 Guest
    Hi Richard,
    Here is the working code. I home others will find this useful.
     ADCON1 = 7 '
     CCP1CON = 0
     CCP2CON = 0
     portB.4 = 0
     portB.5 = 0
     enc_old                VAR BYTE
     enc_new              VAR BYTE
     enc_tmp              VAR byte
     enc_scaler            VAR word
     Sign                    VAR BIT
     Asm
    myint
     ;movwf wsave
     ;swapf STATUS, W
     ;clrf STATUS
     ;movwf ssave
     ;movf PCLATH, W
     ;movwf psave
     ;CLRF PCLATH
     ; enc_new VAR BYTE
     ; enc_old VAR BYTE
     ; enc_tmp VAR BYTE
     movf PORTB,W
     movwf _enc_new
    Down
     movf _enc_counter,W
    Up
    Continue
     movf _enc_new,W
     movwf _enc_old
     movf  psave, W
     movwf PCLATH
     swapf ssave, W
     movwf STATUS
     swapf wsave, F
     swapf wsave, W
     endasm
     lcdout $FE,1
     enc_counter_old = 0
     Counter = 0
     test:
    If not sign AND (-Counter < 0 or Counter > 0) then
     goto test
     ClearAll:
        enc_counter = 0
        enc_counter_old = 0
        Counter = 0
        clear
            high ledtest
            low ledtest
     goto test
    @INT_RETURN
    Quote Originally Posted by cbrun17 View Post
    Chris
    Out of curiosity, what R/C values did you find to be optimal on your schmitt triggers?
    Picster
  1. Quick thoughts: DT Ints with encoders
    Last Post: - 7th January 2010, 01:01
  2. PMDC SERVO MOTOR WITH quadrature encoder DRIVE ?
    By phoenix_1 in forum Schematics
    Last Post: - 22nd November 2009, 19:45
  3. 32-bit Quadrature Counter With Serial Interface
    Last Post: - 10th June 2008, 02:49
  4. quad encoders
    Last Post: - 13th March 2007, 17:49
  5. "momentary" IR decoding
    By sporker in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 01:53
