decoding quadrature encoders
Results 1 to 40 of 94
Threaded View
  1. #14
    cbrun17's Avatar
    cbrun17 Guest
    Default Re: decoding quadrature encoders
    Hi Henrik,
    No worries... I learn from mistakes as well. I appreciate all your help.
    I believe we're getting very close. I have the following code:
    if enc_counter <> enc_counter_old then 'see if value has changed
    enc_counter_old = enc_counter 'move new value to old
    Counter = enc_counter
    Sign = Counter.15 ' Save sign
    Counter = ((ABS Counter) * 5) ' Degrees is now 0 to 900
    If Sign THEN Counter = -Counter ' Restore sign, value is now -900 to 900
    lcdout $FE,1, sdec Counter / 10, ".", sdec Counter //10
    lcdout $FE,$C0, sdec Counter
    First, the counter increments by 5.
    Also, in the first LCD statement, the count increments to +90 as expected. However, the negative value shows as 6553.1, 6552.6, etc...
    The second LCD out statement displays +/- 900 as you explained.
    Seems the absolute value gets lost when trying to display negative after formatting.
    Is there maybe a way I can parse the decimal values prior to display statement to maintain the value?
    Chris
  1. Quick thoughts: DT Ints with encoders
    Last Post: - 7th January 2010, 01:01
  2. PMDC SERVO MOTOR WITH quadrature encoder DRIVE ?
    By phoenix_1 in forum Schematics
    Last Post: - 22nd November 2009, 19:45
  3. 32-bit Quadrature Counter With Serial Interface
    Last Post: - 10th June 2008, 02:49
  4. quad encoders
    Last Post: - 13th March 2007, 17:49
  5. "momentary" IR decoding
    By sporker in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 01:53
