decoding quadrature encoders
Results 1 to 40 of 94
    Apr 2011
    León
    Question Re: decoding quadrature encoders
    Hi Ioannis exactly i'm using PIC16f877a i have the same problem that ice i cant see my count on my LCD and i cant see using pbp
    only add my count never sub my count do you know what's my problem?
    i tried all in my hands but i continue with same errors
    My code is:
    '*  Author  : .                                                            *
    '*  Notice  : Copyright (c) 2011 [Ing..]  *
    '*  Date    : 19/04/2011                                        *
    'Parte de configuraciÛn de LCD
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT  4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG  PORTB
    DEFINE LCD_EBIT  3
    contador var byte
    ON INTERRUPT GOTO SUMA
    INTCON.4 = 1
    INTCON.7 = 1
    OPTION_REG.6 = 1
    CMCON=7
    CVRCON=0
    TRISB = %00000101
    CONTADOR = 12
    principal:
    lcdout $FE,1,"ENCODER= ",#CONTADOR," VALOR "
    goto principal
    DISABLE
    SUMA:
    IF PORTB.0 = 1 THEN
        OPTION_REG.6 = 0
        IF PORTB.2 = 1 THEN
        contador = contador + 1
        OPTION_REG.6 = 1
        IF PORTB.2 = 1 THEN
        CONTADOR = CONTADOR - 1
    INTCON.1 = 0
    RESUME
    ENABLE
    Default Re: decoding quadrature encoders
    After interrupt you reset Option_Reg.6.
    And then never set it again. Is it that what you want?
    Apr 2011
    León
        OPTION_REG.6 = 1
        IF PORTB.2 = 1 THEN
    INTCON.1 = 0
     OPTION_REG.6 = 0 'Here???
    RESUME
    ENABLE
    My problem is the count never sub only add and add if the encoder turn left add and if the encoder turn right add too that's my problem
    I'm working with
    http://www.bourns.com/data/global/pdfs/pec11.pdf
    Apr 2011
    León
    Thumbs up Re: decoding quadrature encoders
    Thank you so much Ioannis!!
  1. Quick thoughts: DT Ints with encoders
    Last Post: - 7th January 2010, 02:01
  2. PMDC SERVO MOTOR WITH quadrature encoder DRIVE ?
    By phoenix_1 in forum Schematics
    Last Post: - 22nd November 2009, 20:45
  3. 32-bit Quadrature Counter With Serial Interface
    Last Post: - 10th June 2008, 03:49
  4. quad encoders
    Last Post: - 13th March 2007, 18:49
  5. "momentary" IR decoding
    By sporker in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 02:53
