GPIO.2 of 12F509 doesn't work.
Results 1 to 5 of 5
    Peter Oors's Avatar
    Peter Oors Guest
    Unhappy GPIO.2 of 12F509 doesn't work.
    At the first time of using the 12F509 instead of the 12F629 I discovered a problem.
    @ device INTRC_OSC,MCLR_OFF
    'cmcon=7 'for the 12F629 only
    trisio=%001000
    GPIO=%000000
    GPIO=%110111
    Pause 1000
    GPIO=%000000
    Stop
    All 5 outputs of the 629 went high for 1 second.
    The 509 GPIO.2 doesn't do anything, GPIO.0, 1, 4 and 5 went high for one second.
    Both PIC's are tested on the same PCB.
    What could be wrong or what do I do wrong?
    I use PBP2.46, MPLab7.1 and PICStart Plus.
    Try this... and tell us if it works...
    	TRISIO=%00001000
    Loop:
    	High GPIO.2
    	Pause 1000
    	Low GPIO.2
    	Pause 1000
    	Goto Loop
    Peter Oors's Avatar
    Peter Oors Guest
    Quote Originally Posted by Melanie
    	TRISIO=%00001000
    Loop:
    	High GPIO.2
    	Pause 1000
    	Low GPIO.2
    	Pause 1000
    	Goto Loop
    Hello Melanie,
    I tried and: GPIO.2 stays low, GPIO.0 , 1 , 4 and 5 are high.
    If I put GPIO=%00000000 after Trisio all outputs are low.
    I took a new PIC509 and the same happens, very strange.
    The 629 GPIO.2 works fine.....
    Datasheet, Datasheet, Datasheet!!!!!
    Really.... you gotta get this tatooed in some prominent place...
    Walk with me on this one...
    GPIO.2 is also the T0CKI pin...
    Table 6-1 on Page 34 Reference Note (3) at the bottom states "The TRIS of the T0CKI pin is over-ridden when T0CKS=1". There's also a great-big NOTE to this effect at the top of Page 22!
    T0CKS is part of the OPTION REGISTER.
    See Register 4-3 on Page 22 and cross-reference this with Table 7-3 (Reset Conditions) on Page 44... you will note that this register bit is set to '1' on Power-up, therefore TRISIO is over-ridden...
    So set OPTION_REG.5=0 before your TRISIO statement.
    Peter Oors's Avatar
    Peter Oors Guest
    Talking
    Thanks Melanie,
    It's all working now.
    Your explanation was very clear.
    I understand now why it didn't work, but I couldn't find it out by myself.
    Thanks a lot.
  1. 12F509 doesn't do anything
    By madphys in forum General
    Last Post: - 31st January 2010, 10:00
  2. Timer and 12F509
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 15:51
  3. 12F629 Strange interupt behavior
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 25th May 2007, 16:35
  4. blink.bas help cant make any 18f's work
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 13th December 2004, 22:28
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
