limiting to "no less than" zero
Results 1 to 31 of 31
    Oct 2009
    Utah, USA
    Default Re: limiting to "no less than" zero
    Here is my test code and the debug results below...
     DEFINE DEBUG_REGG PORTA        'set debug port to porta
     DEFINE DEBUG_BIT 0             'use pin a0 of porta for debug
     DEFINE DEBUG_BAUD 2400         'set baud rate to 2400
     DEFINE DEBUG_MODE 0            'communicate in true mode
    valA var byte
    valB var byte
    resultA var byte
    resultB var byte
    resultC var byte
    resultD var byte
       Carry var bit
       vala=51
       valb=50
    resulta=vala-valb
    Carry = STATUS.0
    debug "resultA : 51-50=",dec resulta," Carry=",dec carry,13,10
    resultb=valb-vala
    Carry = STATUS.0
    debug "resultB : 50-51=",dec resultb," Carry=",dec carry,13,10
    resultC=vala+valb
    Carry = STATUS.0
    debug "resultC : 51+50=",dec resultc," Carry=",dec carry,13,10
    vala=55
    valb=201
    resultD=vala+valb
    Carry = STATUS.0
    debug "resultD : 55+201=",dec resultd," Carry=",dec carry,13,10
    and the Debug results...
    resultA : 51-50=1 Carry=1
    resultB : 50-51=255 Carry=0
    resultC : 51+50=101 Carry=0
    resultD : 55+201=0 Carry=1
    Dwight
    Oct 2009
    Utah, USA
    DANG EDIT TIMER...
    Therefore
    If you subtract two BYTE variables and the result is NEGATIVE, the Carry Bit will be Cleared (0)
    If you add two Byte variables and the result is >255 then the Carry Bit will be SET (1)
    HEY!! I think that's what Darrel said earlier.
    Dwight
    Sweet!
    And you made your own test program ... Perfect!
    I'm sure it all seems much clearer now.
    Oops, sorry. I should have said borrow...
    Darrel was too polite! Thanks.
    @ Steve: I meant which audio chip are you controlling with the PIC©
    California, USA
    Audio chip? LM380
    Ah, you asked because I used "volume" as a variable in my question...
    Actually it's not an audio project. It's for FrankenGriddle.
    [img]http://www.weirdstuffwemake.com/blac...iddle_1450.jpg[/img]
    If anyone is really curious I guess I could start a thread about "The FrankenGriddle Project" in the OT forum.
    Hmmmm... is there a forum specifically for showcasing "Projects" that use PICs?
    The Wiki could be a nice place. You can even start your personnal group in your own profile... not sure how it works though.
