limiting to "no less than" zero
Results 1 to 31 of 31
    California, USA
    Default limiting to "no less than" zero
    Greetings all,
    Too many interests and hobbies have kept me away from electronics for a while, but I'm back again and trying to re-learn what little I knew about PICs....
    Todays question is how to easily limit a number to "not less than zero".
    I have a number... lets call it "volume" and I want to increment or decrement that number by "step", which could be from 1 to 9.
    I want to limit "volume" to no more than 350 at the upper end and no "less" than zero at the low end.
    So if I press buttonA then volume increments by the step amount, and if I press buttonB then volume decrements by step amount.
    Here's a simple example (of what doesn't work):
     volume = 100        'set a default level
     step = 3               'This could be ANY NUMBER FROM 1 TO 9
     if buttonA  then volume = (volume + step) min 350     'this works fine to limit the top end to 350
     if buttonB  then volume= (volume - step)  max 0        'but of course THIS fails, because it's hard to go lower than zero
     LCDOUT $fe, $c0, dec volume
     pause 50
    So I'm sure that there must be an easy way to limit a number from decrementing "below" zero... ?
    Help please?
    Thanks much!
    Sep 2005
    Campbell, CA
    Default Re: limiting to "no less than" zero
    if buttonB  then
        if step > volume then
              volume = 0
    Charles Linquist
    Oct 2009
    Utah, USA
    This Should (untested as of yet) work...
    One thing about programming... there is always more than one way to do the exact same thing... some are more elegant than others... Mine usually falls into the "less elegant, but gets the job done" category
    The extra "IF" test should eliminate the need to test for below zero or the "max 0" test.
     if buttonB and (volume < 3) then
          volume = 0
          goto Skip1
     if buttonB  then volume= (volume - step)         'but of course THIS fails, because it's hard to go lower than zero
    Skip1:
     pause 50
    Dwight
    Oct 2009
    Utah, USA
    Hey Charles... you beat me to it
    When I started my reply, you had not posted yet. I am not sure I like the new code posting window... it gave me fits and I had to start over.
    I think I like yours better... but it is fun and informative to try different bits of code and compile each and see how the byte count changes. I have been surprised at times in finding that what you think should be more compact code ends up being more bloated.
    Dwight
    Yup, there are always lots of ways.
    if buttonB then
        volume = volume - Vstep        ; subtract the step
        if volume.15 then volume = 0   ; zero if it went negative
    Last edited by Darrel Taylor; - 17th September 2011 at 05:45. Reason: step is a reserved word
    Jan 2006
    Istanbul
    if buttonB then
     if volume - Vstep >= vstep then
      volume = 0
    Mar 2009
    Straying a little off...
    I'm never more than a couple of threads away from having it underlined that I'm still woefully underskilled in this programming melarkey - where's the condition here...
    if buttonB then
    to my n00b eyes, I'd have thought there should be a condition like "if buttonB = 0 then" or "if buttonB = 1 then"
    If buttonB means If buttonB=1.
    Is a default.
    A pure boolean logic.
    Darrel gets the most elegant so far coding
    Mar 2009
    I'd figured as much (on account everyone was doing it!)....can the default be changed to 0? (I'd imagine that switches get used with weak pullups or external pullups ....so the switch pressed condition would be a 0).
    Re Darrel's entry..
    how does bit 15 of 'volume' being a '1' indicate negative? Can someone shine a little more light on this one please?
    Related to the "default" just use the ! before your variable:
    If !buttonB then.... meaning If buttonB=0 then...
    The 15th bit is the sign bit in two's complement. When the most significant bit is 1, it indicates a negative sign. Just Binary maths...
    But is relative. If you use 8-bits then the 8th (most significant bit) is considered the sign bit. As long as you are thinking of positive and negative numbers. So at the end you have from -128 to +127 (1000 0000 to 0111 1111).
    http://en.wikipedia.org/wiki/Two's_complement
    California, USA
    Thanks guys!
    Well... I guess the answer to my question is that there isn't really a way that's as easy as using "min" to limit the upper end.
    The method that Charles posted is what I've been using. But I was hoping for something that was... simpler.
    I guess I'd hoped there was some way as clean and easy as "MAX" but that worked all the way down to zero.
    Darrels method using volume.15 is great, but it "wastes" half of a variable.
    Most of the variables that I need to limit are declared as bytes, and I need the full 255 step range for some of them.
    I *can* use it for my temperature setpoint because that needs a word anyway and I can afford to "lose" part of it.
    I'm starting to run low on code space on this project so hoping to find more efficient ways to do a few things...
    Thanks for the input!
    Quote Originally Posted by Byte_Butcher View Post
    With 8-bit values, the CARRY flag is valid after addition or subtraction.
    So it can be ...
    if buttonB then
        Volume = Volume - Vstep
        IF !STATUS.0 THEN Volume = 0   ; Zero if BORROWED
    California, USA
    STATUS ?
    STATUS.0 ?
    Ahhh, Darrel, you confuseth me. From whence comes... STATUS ?
    steve
    STATUS is a register in the PIC that contains the results (status) of arithmetic operations.
    Depening on the chip family, it may also have Watchdog Timer status and FSR/page bits.
    STATUS.0 is the CARRY flag.
    After an addition, if the result is larger than 255 the carry bit will be set (1).
    After a subtraction, if the result is less than 0 (BORROW), the carry bit will be cleared (0).
    The carry bit is only valid after addition/subtraction with 8-bit values.
    After math with WORD values, the carry bit cannot be used because not all of the math is done by the hardware.
    If the previous subtraction produced negative results, bit 0 of STATUS is set (to 1). Then you check this condition and if true, set Volume to 0.
    By the way which chip are you controlling?
    California, USA
    Wow... thanks Darrel. THAT is an interesting item to know about.
    I'm sure I can make good use of that!
    Ioannis, I'm using a 16F887. And thanks for helping explain the STATUS thing!
    steve
    Oct 2009
    Utah, USA
    Darrel = After a subtraction, if the result is less than 0 (BORROW), the carry bit will be cleared (0).
    Ioannis = If the previous subtraction produced negative results, bit 0 of STATUS is set (to 1)
    OK guys(gals?)
    if I read those two statements correctly... they are contradictory. You can't have it both ways... which is it??
    Dwight
    Don't believe anything just because somebody said so.
    Especially when there's conflicting information.
    Check the datasheet, and test it for yourself. Then you will know the truth.
    This program will help with the testing part.
    Volume   VAR BYTE
    Vstep    VAR BYTE
    Result   VAR BYTE
    Carry    VAR BIT
    HIGH PORTD.0     ; initialize serial line
    PAUSE 100
    FOR Volume = 5 TO 0 STEP -1
        FOR Vstep = 5 TO 0 STEP - 1
            Result = Volume - Vstep
            Carry = STATUS.0
            SEROUT2 PORTD.0,84,[DEC Volume," - ",DEC Vstep," = ",DEC Result,"   C = ",DEC Carry,13,10]
        NEXT Vstep
    NEXT Volume
    STOP
    California, USA
    Darrels way works with a 16F887.
    Can't vouch for any other chips...
    May 2008
    Italy
    Darrel, what is the value of STATUS.0 at start up? I assume it should be zero (no borrow no carry) , are you going to set it at start up, in order to have your snippet @ post #12 working?
    Cheers
    Al.
    Aug 2010
    Maryland, USA
    Not that Darrell needs it, but I feel compelled to jump in here and row his boat. To my knowledge, borrow/carry flag in the status reg is the same across ALL PIC's. It is not a compilier thing. It is a basic hardware reg no different then any other. It exists the same as W. That said, I believe it is cleared at POR, but it doesn't matter. it only has value directly after an addition or subtraction. Well it is also used on rotate R/L through carry, but PBP doesn't support that. Some devices even have 1 for borrow or carry between nibbles, but again only used during math.
    So startup value makes no difference for the snippet in post 12 as it follows a math operation.
    -Bert
    Oct 2009
    Utah, USA
    Here is my test code and the debug results below...
     DEFINE DEBUG_REGG PORTA        'set debug port to porta
     DEFINE DEBUG_BIT 0             'use pin a0 of porta for debug
     DEFINE DEBUG_BAUD 2400         'set baud rate to 2400
     DEFINE DEBUG_MODE 0            'communicate in true mode
    valA var byte
    valB var byte
    resultA var byte
    resultB var byte
    resultC var byte
    resultD var byte
       Carry var bit
       vala=51
       valb=50
    resulta=vala-valb
    Carry = STATUS.0
    debug "resultA : 51-50=",dec resulta," Carry=",dec carry,13,10
    resultb=valb-vala
    Carry = STATUS.0
    debug "resultB : 50-51=",dec resultb," Carry=",dec carry,13,10
    resultC=vala+valb
    Carry = STATUS.0
    debug "resultC : 51+50=",dec resultc," Carry=",dec carry,13,10
    vala=55
    valb=201
    resultD=vala+valb
    Carry = STATUS.0
    debug "resultD : 55+201=",dec resultd," Carry=",dec carry,13,10
    and the Debug results...
    resultA : 51-50=1 Carry=1
    resultB : 50-51=255 Carry=0
    resultC : 51+50=101 Carry=0
    resultD : 55+201=0 Carry=1
    Dwight
    Oct 2009
    Utah, USA
    DANG EDIT TIMER...
    Therefore
    If you subtract two BYTE variables and the result is NEGATIVE, the Carry Bit will be Cleared (0)
    If you add two Byte variables and the result is >255 then the Carry Bit will be SET (1)
    HEY!! I think that's what Darrel said earlier.
    Dwight
    Sweet!
    And you made your own test program ... Perfect!
    I'm sure it all seems much clearer now.
    Oops, sorry. I should have said borrow...
    Darrel was too polite! Thanks.
    @ Steve: I meant which audio chip are you controlling with the PIC©
    California, USA
    Audio chip? LM380
    Ah, you asked because I used "volume" as a variable in my question...
    Actually it's not an audio project. It's for FrankenGriddle.
    [img]http://www.weirdstuffwemake.com/blac...iddle_1450.jpg[/img]
    If anyone is really curious I guess I could start a thread about "The FrankenGriddle Project" in the OT forum.
    Hmmmm... is there a forum specifically for showcasing "Projects" that use PICs?
    The Wiki could be a nice place. You can even start your personnal group in your own profile... not sure how it works though.
    California, USA
    OK, curiosity got me so I tried it with WORD values and it still seems to work...
    x = 32768
    Y = 32769
    x = x + y
    Result: X = 1, STATUS.0 = 1
    x = 32768
    Y = 32765
    x = x + y
    Result: X = 65533, STATUS.0 = 0
    x = 32768
    Y = 32765
    x = x - y
    Result: X = 3, STATUS.0 = 1
    x = 32765
    Y = 32771
    x = x - y
    Result: X = 65530, STATUS.0 = 0
    I thought it was only 'sposed to work with 8 bit numbers?
    Try it with ...
    X = 32768
    Y = 65523
    California, USA
    Try it with ...
    X = 32768
    Y = 65523
    Nope, that didn't work.
    OK, 8 bit math then....
    Thanks!
    Sep 2005
    Campbell, CA
    Since PBP handles the 16 (31) bit math, and certainly knows the results of the 8 bit operation, the writers of PBP *could* provide us with an overflow/underflow flag (PSTATUS?). If they really wanted to.
    Charles Linquist
