limiting to "no less than" zero
Results 1 to 31 of 31
    California, USA
    Default limiting to "no less than" zero
    Greetings all,
    Too many interests and hobbies have kept me away from electronics for a while, but I'm back again and trying to re-learn what little I knew about PICs....
    Todays question is how to easily limit a number to "not less than zero".
    I have a number... lets call it "volume" and I want to increment or decrement that number by "step", which could be from 1 to 9.
    I want to limit "volume" to no more than 350 at the upper end and no "less" than zero at the low end.
    So if I press buttonA then volume increments by the step amount, and if I press buttonB then volume decrements by step amount.
    Here's a simple example (of what doesn't work):
     volume = 100        'set a default level
     step = 3               'This could be ANY NUMBER FROM 1 TO 9
     if buttonA  then volume = (volume + step) min 350     'this works fine to limit the top end to 350
     if buttonB  then volume= (volume - step)  max 0        'but of course THIS fails, because it's hard to go lower than zero
     LCDOUT $fe, $c0, dec volume
     pause 50
    So I'm sure that there must be an easy way to limit a number from decrementing "below" zero... ?
    Help please?
    Thanks much!
    Sep 2005
    Campbell, CA
    Default Re: limiting to "no less than" zero
    if buttonB  then
        if step > volume then
              volume = 0
    Charles Linquist
    Oct 2009
    Utah, USA
    This Should (untested as of yet) work...
    One thing about programming... there is always more than one way to do the exact same thing... some are more elegant than others... Mine usually falls into the "less elegant, but gets the job done" category
    The extra "IF" test should eliminate the need to test for below zero or the "max 0" test.
     if buttonB and (volume < 3) then
          volume = 0
          goto Skip1
     if buttonB  then volume= (volume - step)         'but of course THIS fails, because it's hard to go lower than zero
    Skip1:
     pause 50
    Dwight
    Oct 2009
    Utah, USA
    Hey Charles... you beat me to it
    When I started my reply, you had not posted yet. I am not sure I like the new code posting window... it gave me fits and I had to start over.
    I think I like yours better... but it is fun and informative to try different bits of code and compile each and see how the byte count changes. I have been surprised at times in finding that what you think should be more compact code ends up being more bloated.
    Dwight
    Yup, there are always lots of ways.
    if buttonB then
        volume = volume - Vstep        ; subtract the step
        if volume.15 then volume = 0   ; zero if it went negative
    Last edited by Darrel Taylor; - 17th September 2011 at 04:45. Reason: step is a reserved word
    Jan 2006
    Istanbul
    if buttonB then
     if volume - Vstep >= vstep then
      volume = 0
    Mar 2009
    Straying a little off...
    I'm never more than a couple of threads away from having it underlined that I'm still woefully underskilled in this programming melarkey - where's the condition here...
    if buttonB then
    to my n00b eyes, I'd have thought there should be a condition like "if buttonB = 0 then" or "if buttonB = 1 then"
