This fixed my problem. I did not notice I had ticked 16fl1847 not 16f1847 in MeConfig . I changed "OSCCON = %11100000" to "OSCCON = %01110000" and added "DEFINE OSC 8". I am glad I figured it out before anyone answered.
;----[16F1847 Hardware Configuration] From MeConfig--------------------------
#IF __PROCESSOR__ = "16F1847"
#DEFINE MCU_FOUND 1
cfg1 = _FOSC_INTOSC ; INTOSC oscillator: I/O function on CLKIN pin
cfg1&= _WDTE_OFF ; WDT disabled
cfg1&= _PWRTE_OFF ; PWRT disabled
cfg1&= _MCLRE_OFF ; MCLR/VPP pin function is digital input
cfg1&= _CP_OFF ; Program memory code protection is disabled
cfg1&= _CPD_OFF ; Data memory code protection is disabled
cfg1&= _BOREN_OFF ; Brown-out Reset disabled
cfg1&= _CLKOUTEN_OFF ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
cfg1&= _IESO_OFF ; Internal/External Switchover mode is disabled
cfg1&= _FCMEN_OFF ; Fail-Safe Clock Monitor is disabled
__CONFIG _CONFIG1, cfg1
cfg2 = _WRT_OFF ; Write protection off
cfg2&= _PLLEN_OFF ; 4x PLL disabled
cfg2&= _STVREN_OFF ; Stack Overflow or Underflow will not cause a Reset
cfg2&= _BORV_HI ; Brown-out Reset Voltage (Vbor), high trip point selected.
cfg2&= _LVP_OFF ; High-voltage on MCLR/VPP must be used for programming
__CONFIG _CONFIG2, cfg2
#ENDIF
;----[Verify Configs have been specified for Selected Processor]----------------
; Note: Only include this routine once, after all #CONFIG blocks
#IFNDEF MCU_FOUND
#ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
#ENDIF
ANSELA = 0 ' Turn off analog port A
ANSELB = 0 ' Turn off analog port B
CM1CON0 = 0 ' Comparators off.
CM1CON1 = 0
CM2CON0 = 0 ' Comparators off.
CM2CON1 = 0
CPSCON0 = 0 ' Capacitive sense module off.
TRISB = %00000000
OSCCON = %01110000
ADCON1 = %11111111
DEFINE OSC 8
