Config & Oscon settings 16F1825
Results 1 to 8 of 8
    Default Config & Oscon settings 16F1825
    I'm migrating from my trusty 12F683 to a 16F1825 and am confused by the config and oscon settings. I'm using PBP3 of course
    With 12F683 I have the following.
    #config
     __config _FCMEN_ON & _IESO_ON & _BOD_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_OFF & _WDT_OFF & _INTOSCIO
    OSCCON = 01110101  'Sets internal osc to 8 Mhz (Default) and stable
    I just want to make that work with the 16F1825 but using the 16mhz int oscilator. I don't need anything fancy. I appreciate the 16F1825 has two config words.
    I was thinking something like
    #config
     __CONFIG _CONFIG1, _FCMEN_ON & _IESO_ON & _FOSC_INTOSC & _WDTE_SWDTEN & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
     __CONFIG _CONFIG2, _LVP_OFF
    Does the config need to be in CAPITALS? Does the above look comparable to what I have for the 12F683.
    With the Oscon reg I'm very confused and am reading the datasheet. I just want it to run at 16mhz on the into osc but all the other settings are making my brainhurt!
    I'm also confused about the relationship between the config words and the oscon reg PLLEN etc etc ARRGHHH!!
    Mar 2009
    Default Re: Config & Oscon settings 16F1825
    I use its larger sibling (16f1828), and have it set something like this for 16Mhz
    @ __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF & _LVP_OFF
    @ __CONFIG _CONFIG2, _LVP_OFF
    DEFINE  OSC 16
    Osccon = 111010   'sets the internal oscillator to 16Mhz
    Re the PLL...it confused me too, I haven't got access to the config settings I used (I certainly had it working at 32Mhz at one stage) , but the jists seems to be if you haven't got any refereence to PLLEN_ON in you config, then bit 7 of the Osccon register turns on the PLL
    Edit: I don't know what's going on thereshould be a percentage sign and a leading 0 at the front of that Osccon entry...they are both disappearing when I click 'post reply'
    Try this
            __CONFIG _CONFIG1, _FCMEN_OFF & _IESO_OFF & _FOSC_INTOSC & _PLLEN_OFF & _WDTE_SWDTEN & _MCLRE_OFF & _CP_OFF & _BOREN_OFF & _PWRTE_OFF
            OSCCON = 1000
                    ' x------- SPLLEN: don't care when _PLLEN_OFF in config fuse
                    ' -1111--- Internal clock = 16MHz
                    ' -----x-- Unimplemented
                    ' ------00 System Clock Source = Determined by Config Word
            DEFINE OSC 16 ' Tell PBP we use a 16MHz Clock
    MPASM is case sensitive, IF the config are not in capital you'll receive some Symbol not previously defined error message.
    EDIT: Yup, there should indeed have a percent sign ... Looks like the new vBulletin have new "Features"
    Above the above OSCCON should be
    OSCCON = % 01111000
    without the space between percent signe and the first 0
    Out to do more test in the test area...
    last test, sorry ....
            OSCCON = %01111000
    Was ok the first time I posted it, messed when use the QuickEdit... so before posting it again, I switched to Advanced Moxe...paste the code again and we're up! Damn
    Mar 2008
    I am trying to use a 16f1847 and can not get it to blink an led I am sure this is a config problem but just can't make it work. this is my config and blink program below.
    Thanks!
    ;----[16LF1847 Hardware Configuration]------------------------------------------
    #IF __PROCESSOR__ = "16LF1847"
    #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_ON ; WDT enabled
    cfg1&= _PWRTE_OFF ; PWRT disabled
    cfg1&= _MCLRE_OFF ; MCLR/VPP pin function is digital input
    cfg1&= _CP_OFF ; Program memory code protection is disabled
    cfg1&= _CPD_OFF ; Data memory code protection is disabled
    cfg1&= _BOREN_ON ; Brown-out Reset enabled
    cfg1&= _CLKOUTEN_OFF ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_ON ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON ; Fail-Safe Clock Monitor is enabled
    __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF ; Write protection off
    cfg2&= _PLLEN_OFF ; 4x PLL disabled
    cfg2&= _STVREN_ON ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_19 ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LVP_OFF ; High-voltage on MCLR/VPP must be used for programming
    __CONFIG _CONFIG2, cfg2
    #ENDIF
    #IFNDEF MCU_FOUND
    #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    OSCCON = %00001111
    ADCON1 = %11111111 'PROBABLY NOT RIGHT??
    ANSELA = 0 'PROBABLY NOT RIGHT??
    MainLoop:
    LED VAR PORTA.0
    LED2 VAR PORTA.0
    HighLED
    High LED2
    Pause 500
    Low LED
    Low LED2
    Pause 500
    Goto MainLoop
    OK
    Just a casual observation; you're posting to a 9 year old thread instead of starting your own. In this 9 year old thread you can plainly see the working examples listed in previous posts:
    #CONFIG        __CONFIG _CONFIG1, _FCMEN_OFF & _IESO_OFF & _FOSC_INTOSC & _PLLEN_OFF & _WDTE_SWDTEN & _MCLRE_OFF & _CP_OFF & _BOREN_OFF & _PWRTE_OFF        __CONFIG _CONFIG2, _LVP_OFF        #ENDCONFIG
    You list your own thing and wonder why it doesn't work for you. Am I being overly critical?!?
    Mar 2008
    This fixed my problem. I did not notice I had ticked 16fl1847 not 16f1847 in MeConfig . I changed "OSCCON = %11100000" to "OSCCON = %01110000" and added "DEFINE OSC 8". I am glad I figured it out before anyone answered.
    ;----[16F1847 Hardware Configuration] From MeConfig--------------------------
    #IF __PROCESSOR__ = "16F1847"
    #DEFINE MCU_FOUND 1
    cfg1&= _WDTE_OFF ; WDT disabled
    cfg1&= _BOREN_OFF ; Brown-out Reset disabled
    cfg1&= _IESO_OFF ; Internal/External Switchover mode is disabled
    cfg1&= _FCMEN_OFF ; Fail-Safe Clock Monitor is disabled
    cfg2&= _STVREN_OFF ; Stack Overflow or Underflow will not cause a Reset
    cfg2&= _BORV_HI ; Brown-out Reset Voltage (Vbor), high trip point selected.
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ; Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
    #ENDIF
    ANSELA = 0 ' Turn off analog port A
    ANSELB = 0 ' Turn off analog port B
    CM1CON0 = 0 ' Comparators off.
    CM1CON1 = 0
    CM2CON0 = 0 ' Comparators off.
    CM2CON1 = 0
    CPSCON0 = 0 ' Capacitive sense module off.
    TRISB = %00000000
    OSCCON = %01110000
    ADCON1 = %11111111
    DEFINE OSC 8
