transferring word array to another pic
Results 1 to 13 of 13
    garret's Avatar
    garret Guest
    Cool using the usart
    good morning mel and all,
    So....setup the harware usart using pbp hserout command...done....
    initiate usart receiver...... but don't use pbp hserin command...right?
    It would seem that using the hserin command takes me back to software control and timeout periods.
    So....i poll pir1<5> to check for reception myself
    read the rcreg into a variable
    and go back to poll
    voila..... it's the question of not using pbp hserin that i'm after. yes...no....?
    We're just talking RECEIVE here...
    Avoid SERIN, SERIN2, HSERIN, DEBUGIN etc
    all these end up catching Data out of your control...
    Refer to the PICs Datasheet as to which flags within which registers pop-up anouncing that goodies have arrived.
    The nice thing is that there's a small buffer in the PICs USART... if your program is a bit lazy picking up data, then no worries, it just holds it for you and stacks another byte behind...
    garret's Avatar
    garret Guest
    Default u'sart right
    thanx for everything mel. I'm off to jam it together.
    -first i'm going to try and poll for an arrival and then use hserin...knowing that there is something there...shouldn't lose any time.
    -Second, i'll try polling and then go straight to the registers and transfer in...no hserin. Mind you here there is no control on assignment to variables and control bytes. I liked what you showed me the other day with an ending confirmation byte...
    -third...everything working well....place the usart reception bit into interrupt status and run it as an interrupt....
    mel...u'sart the bestest...garret
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  2. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 18:42
  3. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  4. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  5. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
