Ok, I'm just about onboard with the PIC/W5100 setup. I'm still kicking around the thought of using the ENC28J60 chip. To me right now I'm thinking the only main difference is that the ENC28J60 doesn't do stack and the pic will have to handle it. That is a disadvantage because I don't really want to deal with the stack. And the W5100 will handle all stack and handshaking. I'm wondering what the disadvantage of using the W5100 is? Maybe the through put is not as good when using the ENC28J60. Both are spi devices so they should both work as fast as you can dump data to them.
Yes I am going to order some W5100 Monday.
I am going to jump on the band wagon. However I may trip and fall off.
Shawn
