Nice neat code posts
Results 1 to 40 of 40
    Apr 2003
    Cambridge - UK
    Default Re: Nice neat code posts
    OK, a few posts went through with HTML in them. BUT as the Moderators are aware and a few forum users are aware. there were one or two posts that had really badly bloated and badly formatted HTML in them, that caused the forum pages NOT to load or Crash when viewing those threads.
    HTML will not solve your problem, but WILL definitely allow users to crash certain pages and damage the smooth running of the forum.
    Sorry, but at present i don't have time to produce a tutorial on how to post code examples, formatted with colour. But if you google it you'll see that its quite faesable, if you really have to.
    For sure, I will not enable HTML posting for users, I don't have the time to sort out the issues that will arise !
    Hi Lester,
    No, I'm not particularly interested in the colours and I'm not asking you to enable/allow .html if that's a problem. My point was that many of the posts were they have already been used are no longer readable, like the ones in the thread I linked to. But if they wasn't supposed to be there in the first place then you've made your point.
    Again, I know how to format the code using BB-code but that's just it - simply cut'n'paste well formated code from an editor/IDE to a post usually needs quite a bit of touch-up afterwards. Again, disregard the colours, I'm talking about tabs, blank lines etc. Just what Charles mentioned in his original post. I'm not saying it's yours or the forums fault. I'm, like Charles, asking what's needed to preserve the formatting when copying code into a post.
    Sep 2005
    Campbell, CA
    Below is an unedited cut-and-paste from MCS. Even when I go back and try to clean it up, the final results look terrible. I'd post more code if it didn't look so bad.
    GetNum:
            Result =
    0
            MaxNum =
    5     ; set for max number of digits you will
    accept
            YY =
    1
    POSN=0
            IsNeg =
    0
            TimedOut =
    0
            ArrayWrite InputString,[Rep
    $FF\8]  ; Fill with
    $FF
    GetMoreN:
            HSERIN
    9000,InputTimeout,[Keyin]
    IF Keyin = ESC THEN
    ZeroNum
                If
    Keyin = CR THEN
    DunInputn
    If allowNeg
    then
                IF
    Keyin = "-" and Posn = 0 THEN
    IsNeg =
    1
    Hserout
    goto
    GetMoreN
                IF Keyin
    = BS
    THEN
    HSEROUT
    [BS,SP,BS]
    IF POSN > 0
    THEN
    POSN = POSN -
    1
    InputString [POSN] =
    $FF
    GOTO
    GetMoreN
            IF Keyin < "0" or Keyin
    > "9" THEN GetMoreN
            HSEROUT
    [Keyin]
            InputString [POSN] = Keyin
    - "0"
            IF POSN >= (MaxNum -1)
    THEN DunInputN
            POSN = POSN
    +1
            GOTO
    GetMoreN
    DunInputN:
            For xN = 7
    to 0 STEP - 1
    IF InputString[XN]= 255 THEN
    NoMoreNum
    Result = Result +
    (InputString[xN]*YY)
    YY = YY
    *10
    NoMoreNum:
            Next
    XN
            If Isneg
    then
              If result <
    32768
    then
    Result = 0 - Result
    Charles Linquist
    Charles,
    Attach your code (BAS/PBP) so I can try it if you do not mind.
    Mar 2009
    I have to agree with others here ...not only posting code snippets can be plain ugly....also reading others' old snippets with with the wrong (now incompatible) formatting renders them virtually unreadable.
    Just testing...
    Copy/Paste from Programmers Notepad
    ' 12F675
    ' 09/05/2011
    ' SET FOR INTERNAL OSC AND MCLRE OFF
        __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    ANSEL=%00000000         ' ADC SET FOR DIGITAL
    CMCON=7                 ' COMPARATOR SET FOR DIGITAL
    SWITCH_OFF  VAR GPIO.1  ' PUSH BUTTON FOR PUMP OFF
    SWITCH_RUN	VAR	GPIO.2  ' PUSH BUTTON FOR PUMP ON
    LED_RUN     VAR GPIO.0  ' INDICATE RUN SIGNAL SENT
    LED_OFF     VAR GPIO.5  ' INDICAT STOP SIGNAL SENT
    TX          VAR GPIO.4  ' DATA SEND PIN
    BAUD        CON 18030	' 18030 = 600 BAUD
    START:     ' SEND OFF SIGNAL AT POWER UP
        PAUSE  1000
        HIGH LED_OFF
        SEROUT2 TX, BAUD,["OFF",13]
    DO  ' LOOP TO CHECK PUSH BUTTONS
    	DO WHILE SWITCH_RUN = 1     ' CHECK ON PUSH BUTTON
    	   ' IF BUTTON PUSHED
    		HIGH LED_RUN          ' RUN INDICATOR ON
    		LOW LED_OFF           ' OFF INDICATOR OFF
    		PAUSE 50              ' SETTLE TIME
    		SEROUT2 TX, BAUD,["RUN",13]
    '		SEROUT2 TX, BAUD,[HEX CNT,13]
    	LOOP
    	DO WHILE SWITCH_OFF = 1    ' CHECK OFF PUSH BUTTON
    	   ' IF BUTTON PUSHED
            HIGH LED_OFF          ' OFF INDICATOR ON
    		LOW LED_RUN           ' RUN INDICATOR OFF
    '		SEROUT2 TX, BAUD,[DEC CNT,13]
    	LOOP
    LOOP
    Copy/Paste from MCS
    ' 12F675
    ' 09/05/2011
        PAUSE  1000
        HIGH LED_OFF
    	   ' IF BUTTON PUSHED
    	LOOP
    	   ' IF BUTTON PUSHED
    	LOOP
    LOOP
    Dec 2005
    The problem lies with most of the IDEs/editors. They use a varying number of spaces for tabs - some allow users to specify the value. As Mr. E noted, most have a convert tabs to spaces function but the simplest thing to do is to make your various editors agree on how many spaces make a tab or always use spaces rather than tabs.
