How would you do this?
Results 1 to 24 of 24
    Jan 2010
    Default How would you do this?
    Hi Guys,
    I am trying to trigger an input on a PIC16F687 using an external 12 volt source. The circuit will be using this same supply. Would you have the 12 volt source control a transistor which the transistor will be connected to the input of the pin (either pull up or down, haven't decided yet) or have the 12 volt source go to the input pin via resistors?
    I thought about doing it via directly to the pin using resistors, such as in a voltage divider setup, but wasn't sure if that was the best way. Your thoughts?
    Tony
    Sep 2005
    Campbell, CA
    Default Re: How would you do this?
    A voltage divider on the input will work fine. How about 5K from the input pin to GND and 7.5K from the input pin to your 12V source. If you need a little noise
    immunity, you can add a .1uF cap across the 5K resistor.
    Charles Linquist
    May 2008
    Italy
    I would suggest optocoupler as TLP504 or similar.
    Al.
    Jan 2010
    Quote Originally Posted by aratti View Post
    Al.
    Hi Al,
    Just out of curiosity, why would you use the optocoupler?
    Tony
    May 2008
    Italy
    With optocoupler you will obtain Total isolation from the 5 volts rail and total immunity to noise.
    Cheers
    Al.
    Feb 2011
    Michigan, USA
    Actually the picbasic pro manual shows under the serin command, you
    can input 12 volts directly through a current limiting resistor. (22k in example)
    But if you truly need a reliable trigger, without false triggers, I agree with aratti
    and use optocoupler and caps.
