If you look at what I think will be you your proper baseline readings (i.e. once you've addressed a couple of those issues mentioned by Darrel)...
they're only varying by about 0.00x% per sample period (interrupt)...and when your finger is pressed on the sensor, you should see the value drop by at least 20% (probably 50% or more if your sensor is decent enough), so there's really no need for averaging.Code:14409 14439 14437 14435 14432 14423 14433 14440 14432 14432 14426 14435 14434 14430 14429 14431
