does anyone have a better way for this
Results 1 to 3 of 3
    Aug 2011
    Default does anyone have a better way for this
    i'm going to use a rotary encoder for RF channel selection, once the encoder is read for the channel number, i have to write 8 different bytes for each frequency to the tranceiver. they are sent with the MSSP, which i have never used. Just wondering if anyone has a better way? and if anyone can tell me how they make the code show up in the little window instead of with all this text that would be kool to!
    SEND_TO_TRANS:
    FOR CNT = 0 TO PACKETCOUNT
     SSP1BUF = TRANSTXPACKET[CNT]       ' TRANSFER TX DATA PACKET TO THE SSP1 BUFFER
       IF SSP1CON1.7 = 1 THEN TXERROR   ' CHECK SSP1CON1.7 TO SEE IF A WRITE COLLISION HAPPENED
      WHILE SSP1STAT.0 = 0
       PAUSEUS 2                        ' LOOK TO SEE IF SSP1STAT.0 IS A 1 - 1 = RECEIVE COMPLETE 0 = RECEIVE NOT COMPLETE
      WEND
     TRANSRXPACKET[CNT] = SSP1BUF       ' TRANSFER SSP1 BUFFER TO THE RX'ED DATA PACKET
    NEXT
    PACKETCOUNT = 0
    GOTO MAIN1
    FINDCHANNEL:
    CHANNEL.0 = CHANNELPIN0
    CHANNEL.1 = CHANNELPIN1
    CHANNEL.2 = CHANNELPIN2
    CHANNEL.3 = CHANNELPIN3
    IF CHANNEL = STORED_CHANNEL THEN GOTO MAIN1
    STORED_CHANNEL = CHANNEL
    SET_CHANNEL:
    FOR CNT = 0 TO 7
      ON CHANNEL GOTO LOADCHNL0,LOADCHNL1,LOADCHNL2,LOADCHNL3,LOADCHNL4,LOADCHNL5,LOADCHNL6,LOADCHNL7,LOADCHNL8,LOADCHNL9
       SET_CHANNELB:
      NEXT
     PACKETCOUNT = 7
    GOTO DONE_LOADING
    LOADCHNL0:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH0TO4,R1CREG,R1CREG_CH0,P1CREG,P1CREG_CH0,S1CREG,S1CREG_CH0],TEMP
    TRANSTXPACKET[CNT] = TEMP
    GOTO SET_CHANNELB
    LOADCHNL1:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH0TO4,R1CREG,R1CREG_CH1,P1CREG,P1CREG_CH1,S1CREG,S1CREG_CH1],TEMP
    GOTO SET_CHANNELB
    LOADCHNL2:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH0TO4,R1CREG,R1CREG_CH2,P1CREG,P1CREG_CH2,S1CREG,S1CREG_CH2],TEMP
    GOTO SET_CHANNELB
    LOADCHNL3:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH0TO4,R1CREG,R1CREG_CH3,P1CREG,P1CREG_CH3,S1CREG,S1CREG_CH3],TEMP
    GOTO SET_CHANNELB
    LOADCHNL4:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH0TO4,R1CREG,R1CREG_CH4,P1CREG,P1CREG_CH4,S1CREG,S1CREG_CH4],TEMP
    GOTO SET_CHANNELB
    LOADCHNL5:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH5TO9,R1CREG,R1CREG_CH5,P1CREG,P1CREG_CH5,S1CREG,S1CREG_CH5],TEMP
    GOTO SET_CHANNELB
    LOADCHNL6:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH5TO9,R1CREG,R1CREG_CH6,P1CREG,P1CREG_CH6,S1CREG,S1CREG_CH6],TEMP
    GOTO SET_CHANNELB
    LOADCHNL7:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH5TO9,R1CREG,R1CREG_CH7,P1CREG,P1CREG_CH7,S1CREG,S1CREG_CH7],TEMP
    GOTO SET_CHANNELB
    LOADCHNL8:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH5TO9,R1CREG,R1CREG_CH8,P1CREG,P1CREG_CH8,S1CREG,S1CREG_CH8],TEMP
    GOTO SET_CHANNELB
    LOADCHNL9:
    LOOKUP CNT,[GCONREG,GCONREG_RXCH5TO9,R1CREG,R1CREG_CH9,P1CREG,P1CREG_CH9,S1CREG,S1CREG_CH9],TEMP
    GOTO SET_CHANNELB
    DONE_LOADING:
    CNT = 0
    GOTO SEND_TO_TRANS
    Default Re: does anyone have a better way for this
    Not sure that I have a solution for the first question but the second..
    Place your code in between:
    [ code] code goes here [ /code]
    Just remove the spaces in the tags.
    Aug 2011
    thanks code the code tags i will remember it from now on and at least no one is laughing at the code
