Assign only odd numbers to the six different coins, so if two coins have no gap then they will produce an even number and you can detect it and work out as it has been generated.
Cheers
Al.
Cheers
Al.
The answer depends on how many coins a person could possibly have to insert. I assume that a user could insert multiples of the same type of coin. The number of
combinations gets larger if you buy something for $1, and you are allowed to enter 100 pennies or 20 nickels or any number of other combinations. Now there tree gets larger. So is there a maximum number of coins a user could use?
Charles Linquist
Why cant you assign a number of pulses for each coin depending of their value? Then you can just add all pulses together and get the credit and it would not matter if the person spent all day using 1 cent coins we would still around lunch reach 1 USD :-)
What are the coin values?
Hi Guys
aratti
I tried giving them odd numbers but with 6 coins if you write down all the possible coin combinations (which i did) you get diffrent coin combinations that add up to the same value.
Charles
I guess its a case of how many coins a person could phisicaly insert one after another at great speed, i would guess it wouldnt be more than 10 at the extreme.
Yes you would have multiples of the same coin.
Jumper
I can asign diferent pulses for diferent coins, but if they are inserted fast there is no space between pulses so we cant count them to decide which coin.
Reading the datasheet & understanding it are two different things.
5 cent coin = 1 pulse
10 cent coin = 2 pulses
25 cent coin = 5 pulses
50 cent coin = 10 pulses
1 dollar = 20 pulses
Then it is just to count all pulses.. when you get to 20 pulses you have a dollar.. no matter if the person have used small coins quickly after each other or just one and one. Count the pulses and eventually the pulses will stop and then they will make a purshase.
To get this to work with a coin machine that can only give out 1-50 pulses per coin you can not have a too big difference in value between the smallest coin and the biggest one.
And for every pulse you pic detect you increase the LCD with 0.05 USD. When the pulses stop you have the total value. Of course you still dont know what coins that was inserted but you do know how much in value they have inserted which would be enough to know before releasing the item.
Last time I went to the small store on the corner where I live, they did not count coins.. they counted the value of the coins until I had enough for the icecream and cookies.
Or?
Join the dark side - we have cookies!!
Can you change the width of the pulses for each coin? This might help you ID the coins.
Also do you have access to the inner parts of the coin acceptor?
There must be a coin detect device that triggers the coin recognition and pulse generating sequence.
Depending on the mechanics can you add a “Coin insert enable” system driven by your PIC?
This will let the user insert a new coin only after the pulses from the device are received so you will create your own gap between coins.
Can you elaborate a little more on this part of your machine (coin acceptor) on both aspects mechanical and electronics?
Does the machine separate and store the coins by type?
Do you have access to any other information from the coin acceptor that can be used in conjunction with the pulses?
Nick
Nicmus
No I cant change the pulse widths and the lockout option is unavalable as well, so..
I think Im going to abandon the idea of counting pulses and try the totalizing method (as Jumper said), i think this just gives me another math problem (floating point) but I remember a post I read a while ago that said you just multiply the sum by 10 (eg %0.3 x 10 = 3) and then divide by 10 again when output is needed, or something like that anyway.
So, I think the counting pulse idea is dead and I will give the percentage totalizer method a go (prepair for a new message when I fail lol)
