Input routine and command parser
Results 1 to 4 of 4
    Sep 2005
    Campbell, CA
    Default Input routine and command parser
    This should probably be moved to the 'Examples' section, but I'll post it here for awhile so it will get noticed.
    This routine takes keyboard input, including backspaces, and processes them through a command parser. It converts all chars (but not numbers) to uppercase before processing.
    Enjoy.
    ;Name    : Code Example
    '*  Author  : Charles Linquist
    '*  Date    : 9/10/2011
    '*  Version :1.0
    '*  Notes  :  For the Forum
            DEFINE OSC 40
            DEFINE NO_CLRWDT 1
            DEFINE _18F8723 1
            DEFINE HSER_RCSTA 90H
            DEFINE HSER_TXSTA 20H
            DEFINE HSER_BAUD 9600
            DEFINE HSER_CLROERR 1
            DEFINE LOADER_USED 1
            TRISC = %10111111
            MaxChars var byte
            Inputstring var byte [12]
            Timeout var word
            X var byte
            CharInput var byte
            InputString_Len Var Byte
            CMD VAR BYTE
            MaxChars = 10
            InputString_Len = MaxChars
            Timeout = 9000
            BS con 8
            CR CON 13
            LF CON 10
            ESC CON 27
            SP CON 32
    topp:
        Gosub GetCharInput
         Gosub ConvertToUpper
        Gosub Parseit
        goto topp
    GetCharInput:
    HSEROUT [CR,LF,"Input ? "]
    TextIn:
            ArrayWrite InputString,[REP 0\MaxChars] ; zero out the string to start with
            X = 0
    TextIn2:
            HSERIN Timeout,NoInput,[CharInput]
            IF CharInput = CR Then Goto DoneInput
            If CharInput = ESC THEN goto NoInput
               IF CharInput = BS THEN
                   IF X = 0 THEN
                    Goto TextIn2
                    HSEROUT [BS,SP,BS]
                   X = X - 1
                  InputString[x] = 0 ; zero out the backspaced char
                  GOTO TextIn2
    InputString[X] = CharInput
            HSEROUT [CharInput]      ; Show what we got
            IF X >= MaxChars then goto DoneInput
            X = X + 1
            GOTO TextIn2
    DoneInput:
    NoInput:
            ArrayWrite InputString,[REP 0\MaxChars]  ; wipe everything
    out
            hserout [CR,LF,"No Input!",CR,LF]
    ConvertToUpper:
         For X = 0 to MaxChars
           IF InputString[X] > 96 and INputString[X] < 123 then
              InputString [X] = Inputstring[X] & %11011111
         Next X
    Parseit:
    Parse01: Cmd=01 : ARRAYREAD InputString,InputString_Len,Parse02,[WAIT("AGE")] : GOTO Foundit
    Parse02: Cmd=02 : ARRAYREAD InputString,InputString_Len,Parse03,[WAIT("BIRTHDAY")] : GOTO Foundit
    Parse03: Cmd=03 : ARRAYREAD InputString,InputString_Len,Parse04,[WAIT("CITY")] : GOTO Foundit
    Parse04: Cmd=04 : ARRAYREAD InputString,InputString_Len,Parse05,[WAIT("STATE")] : GOTO Foundit
    Parse05: Cmd=05 : ARRAYREAD InputString,InputString_Len,Parse06,[WAIT("COUNTRY")] : GOTO Foundit
    Parse06:
    Cmd=255
    Foundit:
      Select Case Cmd
          Case 1
            Hserout [CR,LF,"You typed 'AGE'",CR,Lf]
          CASE 2
            Hserout [CR,LF,"You typed 'BIRTHDAY'",CR,Lf]
          CASE 3
            HSEROUT [CR,LF,"You typed 'CITY'",CR,Lf]
          CASE 4
            HSEROUT [CR,LF,"You typed 'STATE'",CR,Lf]
          CASE 5
            HSEROUT [CR,LF,"You typed 'COUNTRY'",CR,Lf]
          CASE ELSE
            HSEROUT [CR,LF,"Invalid command",CR,LF]
       END SELECT
    Charles Linquist
    Default Re: Input routine and command parser
    Thanks Charles,
    Would you happen to have a schematic to go with this? Looks like it would make a good article for the projects section.
    Sep 2005
    Campbell, CA
    Not really. It does run on hardware, of course, but that hardware is really proprietary. But no hardware is needed for this. It will run on your PICDem board.
    This example is actually 3 parts in one.
    Part number 1 (GetCharInput) is a routine that allows you to type and send text to the PIC. It echoes back valid characters, and lets you backspace if you make an error. It "rubs out" the backspace(d) characters, and it terminates when you hit <ENTER> or <ESC>. If you hit <ENTER> it returns the input in an array. If you hit <ESC> it wipes out the array and returns. If you do nothing for 9 seconds, it returns with an empty string.
    Part number 2 (ConvertToUpper) takes the input in mixed-case and converts all the alpha characters to upper case. It leaves numbers and punctuation "as-is". This is handy when you do compares, since people may or may not capitalize the right letters when they type something in.
    Part number 3 (ParseIt) takes the array and searches for any number of strings. When it finds a match, it returns a number that indicates which of the strings matched. This is really useful if you get random data from something like a GPS receiver, or from a network port - or anything.
    I figured that lots of people use things like this (or maybe I'm the only one). At any rate, I use similar routines a lot. They are modified to protect the innocent, and the copyright property of the company I work for.
    Charles Linquist
    Aug 2011
    Guadalajara, México
    Thanks for sharing "Master" Charles, this code is very useful indeed, in fact should be great to see this sort of capabilities bundled with PBP.
    I'll try it in the first chance...
    Regards!
    My English doesn't sucks, it's just fugly...
