Anyway a simple LDR is by far more reliable and is as cheap as an LED, you can connect the LDR in series with a 1K resistor and use it as a voltage divider.
Regards.
Regards.
My English doesn't sucks, it's just fugly...
Dwight:
Have you seen my design? Pictures, schematics, description, and code are posted in the WIKI under Projects - Solar - My Small Solar Tracker. Two posts appear, the second one has a PDF of the schematic. I have been using this tracker a lot, it is reliable and very accurate.
Thanks Ozark,
I may have seen the article but never did find the schematic... I went back to your original post after you mentioned it and found the .pdf. That is what I was looking for... how to hook up the led's and some sample code on reading the light values.
Is there a way to add the .pdf with the SCHEMATIC to the Wiki project page, you might also want to mention in the article where to find the schematic ?? I went back to the article and searched for the word "schematic" and could not see where to view the schematic. Then at the bottom of the page I found a link to the original thread and finally found the .pdf there.
How did you determine that it was necessary to add the capacitors in parallel to the LED's?
@Ivanrosales... I know an LDR is probably a more standard way of measuring light... but I did not have one on hand and wanted to try using an LED as others have mentioned is possible. thanks for your help also
Dwight
Dwight:
I have a lot to learn regarding posting schematics. Sorry for the confusion.
As far as adding the capacitors - I'm sure they are not needed, the signal from the LED's is very stable, no noise or "jitter". Since a high speed response was not required here, I thought "what the heck", I'll just add them anyway. I did not test the circuit without the capacitors, but it would probably work just fine without them.
The change in signal level from the LED's is very smooth, kind of neat to see how the value changes as the shadow moves across the LED.
Ken
Moved from Schematics.
