Quote Originally Posted by muddy0409 View Post
Sh1t, I'm getting too old to learn new stuff!!
At 70, I knows da feelin'. My nurse tells me the stuff falling out of my ears is earwax but I'm sure it's information overflow.
I have, for limited volume, made hardwood jigs which control the position of the object to be machined and then cut similar things by hand with a router bit in a drill press. That way, the router bit only contacts plastic. You need a stable base with a rectangular pocket (which you can assemble rather than machine) which is bigger than the fixture (securing your plastic enclosure by the dimensions of the cutout to be made. It needs a starter hole and only works for rectangular cutouts. Corners will have the radius of the router bit. You need a sturdy drill press as well - they are not designed for lateral forces like this. You can probably buy a suitable drill press or manual milling machine for much less than the cost of the Greenlee punch. (I was somewhat taken aback by its price. Way back when DIY electronics was done with tubes (probably valves to you), I had 3-4 round Greenlee punches for making holes in a sheetmetal chassis that cost very little - IIRC about $20 each.
