maximum oscillator trace length
Results 1 to 9 of 9
    Apr 2005
    Default maximum oscillator trace length
    I am working on a project using picbasic pro and have a question about the maximum trace length going to the oscillator. I am using a 18f252 that will be on a board with a display above it to save space. It is running at 4mhz currently. Everywhere I have looked I see "oscillator should be as close to the pic as possible". I may have to move mine as it will not fit under the display properly. Is there a more defininte answer to its maximum distance from the pic? Help is greatly appreciated, thanks.
    Greg
    never tested the maximum distance but 1-2 inch can be safe. can you solder your crystal or ceramic resonator under your PCB directly on your PIC pins???
    Apr 2005
    Steve, you must be on here all the time for me to get an answer that fast!!!
    I can put it on the bottom, but I have no components on the bottom now. I think I have room around the display to move it, and still be within 2 inches. I was just curious to what other people may have gotten away with. Thanks again for your quick response!
    Greg
    You're welcome.
    Quote Originally Posted by woodygjw
    I was in the past before i answer to too many redundant questions and lazy user that don't want to do some forum search and/or home work.
    Cheers!
    Feb 2004
    Germany
    Greg,
    it also depends on what type of clock source you are using,
    Resonator, Crystal, Oscillator (w. TTL Output)
    Oscillators are less critical than crystals with external Caps.
    If traces get too long you might have problems for the OSC to start up.
    I personally would never move a crystal 2 inch away from the MCU.
    If it is just the "height" of the crystal causeing the problem:
    a Crystal in HC49U-S package is less in height than a PIC in a DIP package,
    so you might be able to fit one of these.
    SMD crystals are even smaller.
    regards
    Ralph
    Apr 2005
    Hello Ralph,
    Thanks for the response. I am now about 1 inch away so I think all is good. I appreciate the response.
    Greg
  1. HSERIN for variable length string
    Last Post: - 19th February 2010, 05:58
  2. Maximun Cable Length for PIC to LCD
    By wildbilly in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 19:00
  3. Maximum Distance Without Driver
    By CocaColaKid in forum Serial
    Last Post: - 5th December 2007, 20:34
  4. Cable Length Between Micros
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 1st June 2006, 14:29
  5. Timer Prescales - maximum time before overflow
    Last Post: - 27th August 2005, 16:52
