Sorry, yes I did have a type. It looks for STATUS2? in the second line. My apologies.
Charles Linquist
Dear Charles,
Today i try to debug the command code u suggest,
1) serin2,PORTC.4,16390,1000,NotFound,[WAIT ("CB2E")] --- Result OK.....can detect the string.
2) my code,
GET_DATA:
' SERIN2 PORTC.4,16390,5000,NotFound,[wait ("C82F")]
serin2 PORTC.4,16390,5000,notfound,[DATA_array]
ARRAYREAD data_array,256,NOTFOUND,[wait ("C82F"),serstring1,serstring2]
debug serstring1
debug serstring2
goto REV_DATA
NotFound:
debug "Not Found",10,13
goto RESET_
Data stream:
A5 5A C0C05E
A5 5A 0E2E 21 00 00 00 00
A5 5A 0E70 26 FE 00 00 00 00 FF
A5 5A C870 26 FE 00 00 00 00
A5 5A C82F
A5 5A 0E2E 20 00 00 00 00
A5 5B 0CC2 00
A5 5A C2D2
A5 5A 060F 00
Result: i get "Not Found" but not the serstring1,serstring2 that i debug. I wonder why this happen to the command "Arrayread"?
TQVM
I don't know exactly what you are trying to do, but the code below works.
Code:CR CON 13 LF CON 10 Data_Array VAR BYTE [30] AfterString1 var byte [10] AfterString2 var byte[10] ArrayWrite AfterString1,[REP 0\10] ; Zero out the strings ArrayWrite AfterString2,[REP 0\10] ArrayWrite Data_Array,"A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S",0] Arrayread Data_Array,20,NotFound,[Wait ("CDE"),STR AfterString1 \6,STR AfterString2 \6] hserout [CR,LF,"AfterString1 ",STR AfterSTring1,CR,LF] hserout [CR,LF,"AfterString2 ",STR AfterSTring2,CR,LF] goto home notfound: hserout["Not Found"] home: goto home
Charles Linquist
