No.
Suppose that you have an input routine where a computer sends you a bunch of commands to parse, and you have to decode those commands. In my case, I have 45 different commands that I have to respond to. Two of those commands are "Status1?" and "Status2?". My incoming packet (it actually is a pre-processed Ethernet packet) is loaded into Data_Array.
Say the packet contains "Status2?"
In the first line in the code example above, I look for "Status1?" in the first 20 characters. Since it doesn't exist, I don't get a match and I jump to line 2 and search for "Status2?" in Data_Array. If it finds "Status2?" (which it will), then I jump to Foundit, and CMD = 2. A SELECT CASE structure using CMD then goes and performs the right thing.
Another tip for those of you who handle a lot of strings (or ARRAYS as they must sadly be called in PBP):
It is often very convenient to make the first element of the array (element 0) the length of the array.
