Help on lCD and PIC18F4550 setup
Results 1 to 12 of 12
    Jun 2011
    Philippines
    Default Re: Help on lCD and PIC18F4550 setup
    Okay no luck yet on the LCD but I managed to run the USBdemo(by mister_e) on 8Mz using..
    __CONFIG _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    Define LCD_DREG  PORTB
    Define LCD_DBIT  0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 4
    Define LCD_EREG  PORTB
    Define LCD_EBIT  5
    DEFINE LCD_LINES 2         ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    Jun 2011
    Philippines
    Thanks for the responce mister_e and scalerobotics. I tried your suggestions but still have no text display on the LCD...
    I make sure that in the configuration setting Oscillator is HS..any idea what I'm doing wrong?
    regards,
    tacbanon
    Mar 2009
    Colorado
    I always put these reminder comments in my code when attempting to program to my EASYPIC6. Are you sure you have the switch settings correct on your EASYPIC6 according to these instructions?
    ' * NOTES for use with EasyPic6 development board:
    'For use with COG 2x16 LCD:
    ' - Turn on Port Expander switches SW6.1, SW6.2, SW6.3, SW6.4 and SW6.5.
    ' - Turn on COG LCD 2x16 switches SW10.1, SW10.2, SW10.3, SW10.4, SW10.5
    ' and SW10.6.
    Jun 2011
    Philippines
    Hi jellis00, thanks for the tip..
    regards,
    tacbanon
    Jun 2011
    Philippines
    Hi, I'm trying to run this example code using the Matrix keypad routine from Mister_e
    INCLUDE "KeyPad.bas"    asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
        endasm
    DEFINE    OSC 48
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
        '    Hardware connection
        DEFINE KEYPAD_ROW        4       ' 8 row
        define KEYPAD_ROW_PORT   PORTD   '   on PORTB
        DEFINE KEYPAD_ROW_BIT    4       '
        DEFINE KEYPAD_COL        4       ' 4 col
        DEFINE KEYPAD_COL_PORT   PORTD   '   on PORTA
        DEFINE KEYPAD_COL_BIT    0       '
        DEFINE KEYPAD_DEBOUNCEMS 200     ' debounce delay = 200 mSec
        define KEYPAD_AUTOREPEAT 1       ' use auto-repeat
        '    Serial Communication definition
        'DEFINE HSER_TXSTA 24h            ' enable transmit, BRGH=1
        'DEFINE HSER_SPBRG 129            ' 9600 Bauds
        '    Variables definition
        myvar                    var byte
        '    ---------------------------------[Program Start]----------------------------------------------
    start:
        @ READKEYPAD _myvar
        Lcdout $fe, 128,"Key=",dec myvar
        goto start
    But the program just freeze on my easypic6, initially displays "Key=20", I'm using PortD for my keypad(4x4) and I made sure I have pull down-PortD. I set DEFINE KEYPAD_COL_BIT 0 and DEFINE KEYPAD_ROW_BIT 4 (I also tried to inverse them 4-0) but the same problem. Can you tell me what I'm doing wrong on my setup?
    thanks,
    tacbanon
