18F4520 A/D working weird
Results 1 to 18 of 18
    TurboLS's Avatar
    TurboLS Guest
    The analog signal is coming from a sample and hold op amp that is sampling an analog video signal coming from a CCD chip. Please click on the following link and look at the Vout signal on page 13 of the PDF. That is the signal we are getting before we attach the PIC chip.
    http://www.kodak.com/global/plugins/...2ELongSpec.pdf
    Then when we attach it, the signal gets loaded down and all we get is noise in the A/D. thanks again for takin a look.
    TurboLS's Avatar
    TurboLS Guest
    Question
    I also tried putting the signal through a buffering op amp and that doesn't seem to help. For some reason, the A/D input of the PIC does not like the signal coming from output of the buffer, nor does it like the input of our sample and hold circuitry, nor the signal coming directly from the CCD. So we tried to amplify the signal before buffering it and the output just becomes noisy as hell with or without the PIC connected.
    HELP!
    TurboLS's Avatar
    TurboLS Guest
    Question
    Is there any way to set PORTA.0 as a low impedance input???
    Feb 2004
    Germany
    So it's not a PIC problem, it's more a problem with the output of your sensor.
    With external hardware.
    It's still not really clear to me what you are trying to achieve.
    What does the timing of the analog signal look like?
    regards
    Ralph
    TurboLS's Avatar
    TurboLS Guest
    I would post the picture from that PDF file if I could. But the signal I get before the PIC is just like the one on page 13 labeled "Vout" and it is in phase with the horizontal clocks and the reset clock in that same corner of the page. I figured that putting the signal through a buffer would take care of the low impedance issue, but it doesn't. What external hardware would you recommend for lowering the impedance??
    opamp, transistors, mosfet, fet.... usually opamp
    TurboLS's Avatar
    TurboLS Guest
    that's what i figured, but i tried an LF411 and an LM741 and it doesn't seem to make a difference at the input to the PIC.
  1. 12f675 A/d Miseries
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2008, 02:16
  2. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 14:39
  3. Need advice on A/D
    By james in forum mel PIC BASIC Pro
    Last Post: - 24th August 2007, 19:30
  4. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
  5. Replies: 2
    Last Post: - 13th September 2005, 18:23
