Help with SPI SP12T!!!!!!
Results 1 to 6 of 6
    Feb 2004
    Germany
    rush-bh
    This is a PICBASIC Forum, not a MicroController Forum.
    If you don't care about a compiler, why don't you use PICBASIC?
    Please see also: This
    regards
    Ralph
    rush-bh's Avatar
    rush-bh Guest
    Worked fine RALPH, thanks 4 your help! hehehehe
    I used transistors to switch the 3.3v ( new voltage of SP12T ) and the 5V ( PIC ). The transistors were to slow for 312,5MHz! The CLOCK lost the syncronism with SDO and SDI!
    A tip for the guys who have problems with 3.3v <-> 5v :
    MAXIM MAX3392E
    Good luck for you guys, and sorry for the PIC and CCS problems in a PICBASIC forum.
    Feb 2004
    Germany
    Quote Originally Posted by rush-bh
    Worked fine RALPH, thanks 4 your help! ...
    You're welcome
    regards
    Ralph
  1. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 05:08
  2. 16-bit SPI problem
    Last Post: - 19th June 2008, 16:42
  3. SPI Interfacing
    By toofastdave in forum Serial
    Last Post: - 18th November 2007, 12:15
  4. SPI configuration PIC versus Atmel
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 10th July 2007, 20:17
  5. How to configure SPI in PICBASIC PRO?
